Old 05-11-2006, 09:45 AM   #1
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
Default I'm burning 2 QUARTS of OIL :(
just changed my oil the other day...im running mobil one synethic for about 5k and changed it...barely have 2 quarts....changed the oil when the motor was cold....odd...anyone else have this problem?
illegal2.2 is offline   Reply With Quote
Old 05-11-2006, 10:03 AM   #2
skunkfifty
Member#: 73102
1998 legacy outback
white
mobil one is a pretty 'thin' oil, and slips past things pretty easily. what oil were you running before?
skunkfifty is offline   Reply With Quote
Old 05-11-2006, 08:20 PM   #3
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
I have this same issue. My oil light came on and I'm only 2k into my current Mobil 1. No leaks on the floor. I'm switching back to dino next change.
MYfirst00 is offline   Reply With Quote
Old 05-11-2006, 11:53 PM   #4
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
i had my car since 100k, now it's 135k and it's been mobile one since i bought the car.
MYfirst00
-what is dino? never heard of it?
Old 05-11-2006, 11:56 PM   #5
skunkfifty
Member#: 73102
1998 legacy outback
white
dino refers to non-synthetic oils.
has it been using this much oil since you switched it to mobil 1? and have you replaced any seals or anything on the engine? any noticable leaks under the hood?
the 2 main places to look are on the front of the engine, and the valve covers.
Old 05-12-2006, 12:36 AM   #6
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Dino oil referes to oil that has been around since the land of the dinosours. Others say that the fermenting corpses of all those dinosours created the vast oil reserves that we have now. Take your pick.
Jonathan is offline   Reply With Quote
Old 05-12-2006, 12:39 AM   #7
ducmaan748
Member#: 86518
2004 WRX STi
Stage 2
my car burns a qt. every 3 weeks
ducmaan748 is offline   Reply With Quote
Old 05-12-2006, 07:52 AM   #8
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
My engine has been bored .02 over so I don't know if the rings that came with the pistons are holding up inside there. The only leaks I see on mine are from where the turbo oil return line is tapped into the valve cover. Not enough leakage to accumulate to anything tho.
Old 05-12-2006, 10:41 AM   #9
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
ahhhh nice info. for a noob like me lolz...but ya...i noticed a little oil leak on my passenger side valve cover...i thought that it was always there but doesn't seem like a biggy....and when i did my clutch....i noticed it was leaking by the rear main seal...to the right...we sealed it again but that was about 2 months ago...that's the only thing i can think of..
Old 07-09-2006, 01:14 PM   #10
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
I used M1 5W30 Extended Performance which proven to protect my engine for 15000 miles... Yeah Right!
I felt the car has rough idel about a week ago so I took the car in for 60K service at local speed shop (They do majorly subies)
Its about 5K after my last oil change and when they drain the oil out its "BLACK" and only about 2Qts only...
If I drove my car for 15000 miles, M1 need to buy me a new motor!
I switch to Motul 6100 Synergie 15W50, hope this will solve the problem...What an expensive oil
I have a WRX by the way...
Just realized this is a Legacy Forum
ImpreziveWRX is offline   Reply With Quote
Old 07-09-2006, 01:32 PM   #11
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Mine has been run almost exclusively on M1 since new, and it uses a little bit, but not enough to be worried about after 5000 miles.
ImpreziveWRX: It's all good
DLC is offline   Reply With Quote
Old 07-09-2006, 02:54 PM   #12
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
WHISKEY TANGO FOXTROT....... Know much about oil? No I dont think so.. Read and learn before you post...
Alex
BajaT05 is offline   Reply With Quote
Old 07-09-2006, 02:56 PM   #13
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
I guess you have had some bad luck.... Even before the whole EXTENDED LIFE M1 came out, I was putting about 12K in a 7.8K RPM engine without any issues... I have been using M1 in the BAJA since 3K miles and I have no issues
so far. The Baja has 20K miles now... I change the oil at about 5K and I drive the the car hard....
Alex
Old 07-09-2006, 07:02 PM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Oil use has very little to do with the brand of oil from what I've seen. Using a different oil isn't going to magically make your rings seal better or that rear main seal stop leaking or whatever.
If you only check your oil once every 5000 miles, ImpressiveWRX, then you deserve to have the thing seize up on you.
My car burns/leaks 1-2qt of oil between oil changes, and it has for a long time. It still revs right to redline, does track days and auto-x events without complaint, and is about to roll 170,000 miles.
Pat
Old 07-09-2006, 07:32 PM   #15
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
Yeah, I should have checked my oil constantly...
I have always used M1 synthetic oil and change every 3000 miles w/o any problem...
Don't get me wrong, I do take care of my car
By switching to M1 extended performance and advertised it last 15000 mile guaranteed, I assume check/change at 5000 is probably good enough...
I don't think there is a leak, however I was told using 5W30 in hot SoCal weather and upgraded turbo is not good...
By switching to a heavier weight, I hope this can reduce amount of burning oil
Old 07-09-2006, 07:40 PM   #16
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
Whiskey Tango Foxtrot kind of analogy is that?... So you change it to extended life oil and you think that now you dont have to check the oil levels... Some people I just dont know about...
Alex
Old 07-09-2006, 08:02 PM   #17
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
My 2.2 doesn't burn a drop of the M1 0w40 that i've been running in it. Just changed the filter after 3000 milesand didn't have to top it off or anything.
MCarp22 is offline   Reply With Quote
Old 07-09-2006, 11:22 PM   #18
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
turns out that my valve cover(passenger side) is gone...
Old 07-10-2006, 11:13 AM   #19
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I'm losing a bit of oil now, but for the last 180k, I really didn't lose any.
the car has been on Castrol Syntech/Mobil 1 synthetic oils its whole life. usually 5W-30 or 10W-30.
Wiscon_Mark is offline   Reply With Quote
Old 07-10-2006, 12:33 PM   #20
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
Alex
I check my oil now every week...
I guess I learned
Old 07-10-2006, 12:54 PM   #21
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
Since I know my cars well and they dont burn oil, I check the level every once in a while, specially before long trips.... Now, my VW does burn about a QT every 3K miles or so I keep and eye on it (No leaks, just thats how ZEM Germans do it......).
Alex
Old 07-10-2006, 01:50 PM   #22
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I hope you mean the gasket has failed, not that your valve cover has come off. The gasket leak can make a big dent in your oil supply if you drive a lot of miles.
Old 07-10-2006, 01:53 PM   #23
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
^ looks like it...i'll see this weekend what is actually is the problem. my subie machanic said it was the gasket so we'll see
Old 07-10-2006, 01:54 PM   #24
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Cheer up, the gaskets shouldn't be too expensive or hard to replace. No head removal is necessary or anything so drastic.
Old 07-10-2006, 02:07 PM   #25
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
yeah, this isn't HG failure, just a simple valve cover. Most people can do that themselves with the right tools and guidance/knowledge. Well, if that's the case, anyone can
My STi burned 2 and half quarts of oil in 800 miles??? Catch can = full elitescouter Newbies & FAQs 35 04-02-2010 07:46 PM
So I'm spraying a quart of oil per week through the bottom of my motor =P AcquaCow Mid Atlantic Impreza Club -- MAIC 55 10-11-2005 05:05 PM
burned a quart of oil.... yergi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-29-2004 05:02 AM
No Biggy....its just 2 quarts of oil thats missing 96Imprezadent Impreza Forum 0 09-24-2004 07:30 AM
Anyone else burn a quart of oil in the first 3000 miles? Zoso STi Forum Archive 17 07-26-2003 10:33 AM
