Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 05-12-2006, 01:55 AM   #1
Keith
Member#: 191
2012 J train
Brown
Default USDM STi injectors fit in a 98 2.5rs
I had a hard time finding a direct answer to this quesiton, so this post is only to inform everyone that I put USDM sti injectors (yellow top) in my 98RS (with ej22t shortblock) and all is well. Put down 254hp on a dyno dynamics today at 16lbs on a t3/t4 turbo and linkplus ecu.
search terms:
1998 98rs my98 2.5rs ej22t side feed sidefeed rst rs-t
Keith is offline   Reply With Quote
Old 05-12-2006, 02:00 AM   #2
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
are you runnin the stock trans?
civic2scooby is offline   Reply With Quote
Old 05-12-2006, 05:23 AM   #3
NicFunkadelic
Member#: 35330
1999 RSTi + 4.44 = )
Silverthorn... for now
98 RS's have sidefeed injectors? interesting... I just sold my STi injectors.
Nick
NicFunkadelic is offline   Reply With Quote
Old 05-12-2006, 11:06 AM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Yes 98s have Side Feeds. Holy crap, that makes finding injectors sooooo much easier for me. Thank you for this information.
Old 05-12-2006, 11:41 AM   #5
NicFunkadelic
Member#: 35330
no highjacking intended, but I have turbo legacy sidefeeds for sale...
Old 05-12-2006, 11:48 AM   #6
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Can all the side feed subarus use USDM STI injectors? Anybody have a list of all side feed subarus? Obviously all the EJ257 cars but what about older vehicles?
dexterous is offline   Reply With Quote
Old 05-12-2006, 11:51 AM   #7
NicFunkadelic
Member#: 35330
1991 - 1994 Legacy Turbo's use side-feeds, hence me selling them since I need top-feeds.
Nick
Old 05-12-2006, 12:27 PM   #8
turboed22
Member#: 93364
1998 '98 Impreza RST
'14 BRZ
good numbers! It gives me something to shoot for. I am dynoing in a week with pretty much the same set-up as you but fmic and a vf39. What were your injectors duty cycle at?
turboed22 is offline   Reply With Quote
Old 05-12-2006, 12:58 PM   #9
NicFunkadelic
Member#: 35330
I'm in the final stages of my swap... I made a few last minute changes, like buying a VF-30 and 3 inch up/down pipes. I'm going to be running the Greddy Emanage Ultimate, which is installed already. I have placed my FMIC for sale, but I may still use it if noone bites on it. Otherwise I'll be using a stock top-mount.
Summary of parts i've installed during my swap:
Cometic Headgaskets
new timing belt, tensioner, water pump, etc.
Emanage Ultimate
Greddy boost pressure sensor
GM boost control solenoid
Innovate LC-1 Wideband
STi Pink Injectors
VF-30 turbo
AEM cold air intake
3 inch up / down pipes (catless)
clutchnet.com upgraded pressure plate / clutch disc
new throw-out and pilot bearings
new STi group n engine mounts
1 step colder NGK iridium plugs
Old 05-12-2006, 02:00 PM   #10
Aphex28
Member#: 11506
2015 WRX
Nice numbers kief!
i'm actually pondering right now on whether or not to toss a 16g wheel into my td04 after i port it.
Nic, did you tune the Emanage Ult yourself? or did you get somebody to do it? I will be installing my parts soon and am just looking for some options.
http://www.rs25.com/forums/vbgarage.php?do=view&id=4564
Aphex28 is offline   Reply With Quote
Old 05-12-2006, 02:17 PM   #11
NicFunkadelic
Member#: 35330
Damn Aphex, your car is looks sweet...
I haven't tuned my Emanage Ultimate yet, I'm not quite done with my swap. I will be attempting to myself though, hopefully if I'm done soon I'll have the help of Hitokiri, since I don't really know what I'm doing... = )
Nick
Old 05-12-2006, 02:35 PM   #12
Aphex28
Member#: 11506
2015 WRX
ah there seems to be nobody better than him for the emanage best of luck
Old 05-12-2006, 02:38 PM   #13
NicFunkadelic
Member#: 35330
Thank you sir... Maybe if I can absorb some of his wisdom, I will be able to give you a hand... Damn rain, I gotsta work on my car!!!
Old 05-12-2006, 03:04 PM   #14
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Did you need to mod the wiring clips? You didn't have to mod gaskets or anything? They just swap in and work?
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 05-12-2006, 07:20 PM   #15
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
good to know, I have been on the fence between outback motors injector and rail setup.... and going with nissan injectors...
what is the flow rate of the sti injectors? can you do the injector mod to them like the wrx injectors? I'm gona be running a gt30r so I need a bunch of fuel...what size should I use?
IllNastyImpreza is offline   Reply With Quote
Old 05-13-2006, 03:33 PM   #16
Keith
Member#: 191
2012 J train
Brown
the wiring clips I had were already modded as I had 440s on my car before (unknown manufacture, i bought it that way). I'm sorry, i forgot to mention that, so there is a little work inviovled but it wasn't that difficult (just crimping on little connectors and shoving them in ).
We took the gaskets off my injectors (again, not stock) and put them on the sti's and literally just popped them in at that point.
for those interested
Old 05-13-2006, 05:07 PM   #17
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
only 13 psi?
???i am suprised you had to mod the clips .. as the sti injectors matched up perfectly to ej20G harness
Old 05-13-2006, 05:34 PM   #18
Keith
Member#: 191
2012 J train
Brown
jaxx, i ddin't have stock clips in there (rallispec modded them when the 440s were in), so you may not have to.
I"m running about 15psi now bcause I don't have any cash to fix stuff that may break. Figure this is safe + still fun to drive.
how much boost are people running with this setup?
Old 05-14-2006, 02:22 AM   #19
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
so will I need to mod the clips?
Old 05-14-2006, 11:05 AM   #20
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Maybe.....
Nobody has tried yet, I'm guessing we'll know soon enough
Old 05-14-2006, 12:05 PM   #21
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Thats a great tune!!!
250 at KTR is huge man congrats. Is that Franz? Did you run out of fuel at 16psi is that why you stopped? or just looking for a nice safe tune?
Hitokiri is offline   Reply With Quote
Old 05-14-2006, 03:16 PM   #22
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
congrats dude, must be fun!
darioc is offline   Reply With Quote
Old 05-14-2006, 04:00 PM   #23
Keith
Member#: 191
2012 J train
Brown
nope, I had enough fuel but I want the car to be safe
i should have went for the "bragging" run, 22psi or something just to show off, but I think I'm good now. Car feels fantastic and knowing Franz, i don't have much to worry about in terms of reliablity.
So overall, i'm pretty damn happy
In terms of the clips, I honestly don't know if you need to mod them. If anyone is going to the Wickedbigmeet, feel free to take a look at it.
keith
Old 05-17-2006, 10:11 PM   #24
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
For the record, NISMO side feed injectors fit subie side feed apps for those that are looking for cheap huge injectors.
no-coast-punk is offline   Reply With Quote
Old 05-18-2006, 04:28 PM   #25
Keith
Member#: 191
2012 J train
Brown
yeah but those are more expensive than the STis (used).
i think I paid $150. For $150 I got 50 more hp at the wheels
Does an 04sti alternator fit into a 98 2.5RS? Keith Car Audio, Video & Security 17 01-22-2008 10:15 PM
will a 2k MT fit in a 98 2.2 L MT? rufracer Transmission (AT/MT) & Driveline 3 03-24-2007 07:18 PM
So it begins, USDM STI Engine into a 2000 Impreza 2.5RS latinskllz Subaru Conversions 72 08-03-2005 08:37 AM
Will 04 USDM STI seats fit in a 03 USDM WRX?? Dracon Interior & Exterior Modification 2 03-04-2004 12:54 PM
I need to know if the STI RA gears would fit in my 2000 2.5RS casing billyr2.5 Transmission (AT/MT) & Driveline 1 02-25-2004 10:02 PM
