Old 05-12-2006, 07:43 AM   #1
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
Default cold start rough idle with helix 820cc injectors
need some ecutek tuner advice . i have an 03 wrx with a 2.5l forged sti motor with cp pistons,wrx heads p&ped with helix cams and valvetrain. other mods are helix 820cc injectors ,aps 70mm cold air intake ,aps sr55,aps turbo inlet pipe and turbo back exhaust. i do have 2 cats in the down pipe. just breaking inn the motor . it know has 700 miles. my issue is when i start the car up it goes to high idle and about 30 secs after the idle starts bouncing up and down. the car has to be almost fully warm before i can even drive it otherwise it falls on it's face. and in colder weather 40 degrees it hardly wants to go to high idle on start up. it is only on starts after the car has cooled off completely 6- 8 hours. i am lookingfor some input. i know you can't solve but i am almost at wits end with this thing.
sonic rx is offline   Reply With Quote
Old 05-19-2006, 12:31 AM   #2
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
how close is the maf from the front of the turbo?
the maf should be approximately the same distance
from the turbo as stock.
Old 05-19-2006, 09:02 AM   #3
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
here is 2 pics one with the 2.0l motor,and an aps short ram intake. no coldstart issues
and here with the aps 70mm cold air intake on the 2.5l i also went from 650cc injectors to 820cc injectors. maf looks like it is the same spot though
Old 05-24-2006, 10:45 AM   #4
tmarcel
Member#: 7555
You need to scale your MAF table in the low load cells. With Ecutek, you probably have to get reflashed for that. Also you probably need to change tip-in enrichment.
tmarcel is offline   Reply With Quote
Old 05-30-2006, 08:56 AM   #5
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
well i am giving my tuner the car from wed 31st to sat the 3rd . i am hoping the start issue will be cured by thursday. then i get tuned for power on the 3rd.i am just second guessing my choice in mods. i think the 70mm coldair is going top be a problem
Old 05-30-2006, 09:11 AM   #6
tmarcel
Member#: 7555
It'll be fine. Just tune for it.
Rough cold starts and idle problems WorldRallyRedneck Service & Maintenance 6 03-25-2008 05:55 AM
18g with Helix 820cc injectors - any experience? FCmaniac Factory 2.0L Turbo Powertrain 4 02-07-2008 03:41 PM
Helix 820cc injectors and UR 600cc injectors CHEAP!!! ilivas Engine/Power/Exhaust 24 06-08-2007 01:03 AM
cold engine Poor idle w. Helix injectors barry0164 Factory 2.0L Turbo Powertrain 7 01-02-2007 09:09 AM
Best injectors for STi in terms of idle/mileage/cold start when tuning with UTEC only RossWRX Engine Management & Tuning 1 12-26-2005 03:11 PM
Message Board Statistics All times are GMT -4. The time now is 11:22 PM.
