Old 03-29-2006, 08:46 AM   #1
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
Default 5mm spacers...
i put 5mm spacers in the rear of my 02 impreza. do i need to install the extended studs, or should i be good with the stock studs?
darioc is offline   Reply With Quote
Old 03-29-2006, 09:55 AM   #2
subieworx
Member#: 47769
5mm should be fine without longer studs.
subieworx is offline   Reply With Quote
Old 03-29-2006, 10:20 AM   #3
darioc
Member#: 35695
02 RST
thats what i was hoping!
Old 05-08-2006, 10:33 PM   #4
kcook
Member#: 78074
2005 STi
whoa whoa.. u put just spacers on the rear? i thought u cant do that cause ull mess up the diff?
kcook is offline   Reply With Quote
Old 05-08-2006, 11:07 PM   #5
darioc
Member#: 35695
02 RST
that doesnt have anything to do with the diff! its not like my wheels are going to be spinning any faster or slower because they are further away from the diff. you cant have a big difference in the circumferance of one tire to another because the larger tire will be spinning slower than the smaller, thus causing damage.
Old 05-09-2006, 03:56 PM   #6
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
You need to be able to get 8 full turns of the lugnut on the stud for it to be considered "safe"
I run a 1/4" spacer in the front for my race wheels and I bought the Nismo 50mm studs. They work perfectly. I get about 10 turns with them.
SloRice is offline   Reply With Quote
Old 05-09-2006, 03:58 PM   #7
darioc
Member#: 35695
02 RST
yeah i have the extended studs. ill put them on when i do my brakes.
Old 05-09-2006, 06:27 PM   #8
shwoop_soobie
Member#: 102323
99 power poles
beware
do the spacers cause any extra wear on wheel/ axel components (bearings etc.) i am looking into wheels and think i will need to space to clear my brakes but dont want to hurt nething
shwoop_soobie is offline   Reply With Quote
Old 05-10-2006, 02:06 AM   #9
Sub2ner
Member#: 103725
2005 Wrx
how do the spacers feel?
(and why not the front as well?)
Sub2ner is offline   Reply With Quote
Old 05-10-2006, 08:27 AM   #10
darioc
Member#: 35695
02 RST
i didnt notice any difference having them on there. i have read that many people have run these for quite some time without any problems.
Old 05-10-2006, 06:50 PM   #11
gc835
Member#: 78080
2001 impreza
red biatch
yeah why not fronts widen that track man
gc835 is offline   Reply With Quote
Old 05-10-2006, 09:37 PM   #12
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Okay, take it from experience. GET THE STUDS!!!! I lost a wheel during an autox competition. I had 6mm spacers on 17x8.5 ET48 wheels. Take a look at my posts in the "motorsports" section under the title, "Official wide tire talk thread....255 and growing"
There is a good pic of the new wheel studs I installed.
Jose
Pacobeagle is offline   Reply With Quote
Old 05-11-2006, 12:35 AM   #13
totalburnout
Member#: 72861
How much where the spacers and where did you get them?
totalburnout is offline   Reply With Quote
Old 05-11-2006, 07:21 AM   #14
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
as pacobeagle said, put the studs in.
the last thing you want is to lose a wheel at an event or even worse on the street.
WRX8XB is offline   Reply With Quote
Old 05-11-2006, 08:24 AM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I am using 5mm spacers in the front and have no installed longer studs yet. I have 7.5 turns of thread engagement before properly torqued, but I would like a little more especially since making the switch to 255's.
We had ours made by the guys at wheelspacers.com. Really nice guy that does beautiful work. He will custom make any thickness or style you want. Ours were around $40 retail a piece.
Old 05-11-2006, 08:50 AM   #16
Howl
Member#: 57830
I've seen a Subaru FAQ that said your offset should stay within 5mm of OE. Most Subies are +53, so anything down to +48 is fine. Beyond that and you start to get into a grey area. You're trading off fitting wider tires (more grip, better looking) for bearing wear. The farther you go the sooner you'll have to get your bearing replaced. For some people that's a trade worth making. For others it's not.
Howl is offline   Reply With Quote
Old 05-11-2006, 02:14 PM   #17
darioc
Member#: 35695
02 RST
$40 each or a pair?
Old 05-11-2006, 02:25 PM   #18
subieworx
Member#: 47769
40 each.
Old 05-11-2006, 11:49 PM   #19
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
is that all just 8full turns?
ChAi is offline   Reply With Quote
Old 05-12-2006, 01:01 AM   #20
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
You want at least 1cm of thread engagement (8 turns x 1.25 mm pitch)
H&R makes a Subaru-specific 5mm 5x100 kit that includes 2 spacers and 10 extended lugs. I'm trying to get rid of mine
kennyvb is offline   Reply With Quote
Old 05-12-2006, 01:44 AM   #21
totalburnout
Member#: 72861
You only have two spacers though, correct?
If it were (4), I'd take them off your hands. I just don't want to throw the rears wider than the fronts.
Old 05-12-2006, 02:11 AM   #22
kennyvb
Member#: 70234
MY86 BMW E30 325
yes, only two
Old 05-12-2006, 02:29 AM   #23
ChAi
Member#: 1277
1999 Minnam Stage 2
for how much? how thick is it?
Old 05-12-2006, 05:48 AM   #24
Mojambo
Member#: 102581
2006 STI-USDM
SGM
the rears are narrower than the fronts. adding spacers in the rear, will only make the track closer.
Mojambo is offline   Reply With Quote
Old 05-12-2006, 11:34 AM   #25
totalburnout
Member#: 72861
How are the rears narrower?
WTB: 5mm spacers (2) and 10 mm spacers (2) 5x100 thatkhmer SCIC Private Classifieds 3 11-20-2009 02:36 AM
Autometer gauges, diff lock bolts, H&R 5mm spacers, and dead pedal... CreoWRX Private 'For Sale' Classifieds 14 03-15-2004 03:56 PM
Will WRX wheels fit over sti 4 pots with 5mm spacers?? Rallyspec Tire & Wheel 4 01-22-2004 09:01 AM
Will 5mm spacers require longer studs? Evegan Brakes, Steering & Suspension 2 04-04-2003 03:42 PM
STi 4-pots fit with 5mm spacers w/ stock WRX wheels? CP Brakes, Steering & Suspension 1 05-30-2001 05:08 PM
