Old 05-13-2006, 03:51 AM   #1
azn2nr
Member#: 35276
dust collector
Default fuel pump not turning on.
tried to start the swap today and it would turn over but not fire. havent checked the spark yet but i know for sure that there is no fuel. there is no pressure in the hose and no fuel in it either.
everything else so far is going good. no door chime, or airbag, or cel lights but batery and oil stay on. everything else is pluged in that i can find mates to. all others are asumed to be accsories that have yet to be pluged in. ie cruise, radio, ect.
how do i fix this? sugestions??
For reference this is a legacy ej22t into a 95 impreza. matt monson did a full harness merge for me and i have not clue what im doing when it comes to wiring which is why i outsourced that part of the swap. please help me.
azn2nr is offline   Reply With Quote
Old 05-13-2006, 10:07 AM   #2
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
theres a wire going to the old ecu, that u must cut and relocate to a ground. forget which wire. lol
fuses?
use a meter and check the power and ground at the pump
ImprezaRSfan! is offline   Reply With Quote
Old 05-13-2006, 01:22 PM   #3
azn2nr
Member#: 35276
dust collector
the car is being ran by the ej22t ecu. do i still need to find a wire to ground?
Old 05-13-2006, 07:47 PM   #4
azn2nr
Member#: 35276
dust collector
bump i need help. conector isnt getting any power. i think i found the relay in the main box but i cant be sure. switched out the relay i thought was it and now my fans wont turn on as they did before.
Old 05-13-2006, 09:40 PM   #5
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
the fuel pump relay is under the dash in the upper left. should be right under your main relay (big brown thing)
if your pump isn't kicking on then that's the 1st place to check
XENONSVX is offline   Reply With Quote
Old 05-13-2006, 10:52 PM   #6
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
If your check engine light isn't coming on, thats a good indication that the ecu is not getting power. Check that first.
subbyspeed is offline   Reply With Quote
Old 05-13-2006, 11:01 PM   #7
azn2nr
Member#: 35276
dust collector
check engine light wasnt kickin on but now it does and the temp gauge goes haywire adn the fuel gauge doesnt work anymore. ill check ecu next.
ps how does the fuel pump work ie what electric connections need to be completed before it works.
Old 05-14-2006, 01:40 AM   #8
azn2nr
Member#: 35276
dust collector
checked spark tonight to see if i had that. dont have it either
Old 05-14-2006, 11:50 AM   #9
kbahus
Member#: 70256
2000 STI V2 Swapped
I just got my swap to run and had a similar situation to yours. I pulled all the plugs out of the ecu. Then checked every ground first to make sure they were grounded. Then checked all the power wires. One is constant, the rest are switched. I then discovered it was not getting switched power from main relay. I then just worked backwards from the relay and found my problems. You will need a voltmeter to test the grounds and voltages. I don't know the differences between my ej20g harness and yours but I am sure it is similar.
kbahus is offline   Reply With Quote
Old 05-14-2006, 04:35 PM   #10
azn2nr
Member#: 35276
dust collector
whats the difference between a constant and switched voltage readings. adn where can i find a normal reading list?
Old 05-15-2006, 12:19 AM   #11
azn2nr
Member#: 35276
dust collector
bump.
Old 05-15-2006, 03:01 AM   #12
kbahus
Member#: 70256
2000 STI V2 Swapped
Constant power is a wire that will be providing power constantly without the key switch in the "on" position. Switched power is with the key on. 12v is a what the voltage should be, I wouldn't try this stuff unless you know how to use a voltmeter.
Old 05-15-2006, 04:11 AM   #13
azn2nr
Member#: 35276
dust collector
maybe its late but i dont understand what you mean by the difference between the key in the on position and the key on. also i can test volts on most of the connections but the only problem is on one connection from the fuel pump back there is no ground pin to connect the circut therefore its untestable.
Old 05-15-2006, 01:37 PM   #14
azn2nr
Member#: 35276
dust collector
bump
Old 07-07-2006, 02:42 PM   #15
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I needs helps too! My pump isn't turning on.
'91 EJ22T harenss/ECU into '99 Impreza L. I have everything taken apart, did a few things.......
fuel pump doesn't turn on, dash lights are not on.....
I DON'T HAVE THE ENGINE IN YET, so all the plugs are not connected to the engine harness yet....that might explaine a few things too....we tried unpluggin the bulkharness plugs on my friends Impreza w/ 2.5L swap and his pump stays on in "ON" postion. Maybe I just have to put in my engine first.....
FuJi K is offline   Reply With Quote
Old 07-07-2006, 07:21 PM   #16
crazyGC8
Member#: 107421
MY00 RSTi-SOLD BUILT
MY04 STi-SOLD AG2 S13-DD
Constant power= ignition turned off, power even when switch off. Notice "without switched turned on" in his post. Always constant either way on or off.
Switched= power when switch is turned on. Only when switch is turned on.
Like how the clock in the radio works while your key's are not in the car. Same thing. Good Luck.
crazyGC8 is offline   Reply With Quote
Old 07-07-2006, 07:23 PM   #17
crazyGC8
Member#: 107421
I would definatley put the motor in first, you might find your waisting your time trying to troubleshoot when it's not even needed.
Fuel Pump Relay not turning on DeusExMachina Electrical & Lighting 7 10-04-2006 09:08 PM
Help! Fuel Light NOT Turning On! cyrus951 Service & Maintenance 9 10-02-2006 01:48 PM
Fuel Pump not turning on chinoWRXL Factory 2.0L Turbo Powertrain 19 12-09-2005 12:51 PM
fuel pump wont turn on after motor install. oldbluwrx Factory 2.0L Turbo Powertrain 7 07-15-2005 11:01 AM
Friends fuel pump not turning on? kaos200 Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-14-2004 10:25 PM
Message Board Statistics All times are GMT -4. The time now is 06:00 AM.
