Old 05-13-2006, 04:14 AM   #1
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Default What would you do? - help with HGs
Im lookin to perhaps upgrade my powertrain. I have a 97 outback with the EJ25 that has its HGs going already.. . looking to do a new motor but not sure what to do yet... any suggestions? to get my HG's repaired, ive seen that it will cost up to about 2200 dollars to get both HG's done at the dealer. I am unable to find other places around me to get this done. Think i could do an engine swap for about that same price with my own labor? any comments or suggestions? Would getting both HGs fixed be worth the 2k or so ? 1 HG will run me 1500.
vitai0 is offline   Reply With Quote
Old 05-13-2006, 05:58 AM   #2
Kraziken
Member#: 38629
1999 Legacy GT (STI)
My HG repair was around $1500.
For $2200, I would rather invest a little more and buy a new engine. If you do the labor yourself, depending on the engine you select, it might be in the same ballpark.
Kraziken is offline   Reply With Quote
Old 05-13-2006, 09:34 AM   #3
98_soobie
Member#: 17071
just get a ej20t... and install it yourself...if you like wiring you'll be ok. if not... just get a new set of gaskets and intall them yourself...
98_soobie is offline   Reply With Quote
Old 05-13-2006, 11:07 AM   #4
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
A friend of mine got his hg repaired for $900. Just keep looking around
MYfirst00 is offline   Reply With Quote
Old 05-13-2006, 11:41 AM   #5
spdracr00
Member#: 65823
1996 Impreza L
Red
i just went this route in fact. I bought a newer 2.5 SOHC motor but there were some install issues so i ended up selling it for what i paid $1400 and just repairing my HG's myself. it seems a daunting task, but its pretty easy and parts will run you $300-600 depending on what you replace. i replaced my clutch and waterpump while i was in there.. and all the gaskets. the reason the repair is so expensive is the time involved. i was kinda lazy and only did work on the weekends and it took me a month. but i know i could have done it all in a long weekend if i wanted. I pulled my engine and its the best way IMO
spdracr00 is offline   Reply With Quote
Old 05-13-2006, 01:37 PM   #6
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Default cool thanks...
Great thanks guys, I think if i take out about 4 days or so of long work and have all the parts, i could get this done myself. , just need to find the time and place. .. . .
Old 05-16-2006, 10:20 AM   #7
98_soobie
Member#: 17071
dont forget to machine the heads and have them checked for cracks..
Old 05-16-2006, 01:38 PM   #8
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Is that necessary to have done? how much will that run me? Has everyone else done this . . or just the gasket kit ?
Old 05-16-2006, 02:19 PM   #9
98_soobie
Member#: 17071
yup.. aluminum heads tend to warp/crack when overheated... but its up to you to take the chance that they are "Fine".
Old 05-16-2006, 06:24 PM   #10
spdracr00
Member#: 65823
1996 Impreza L
Red
its cheap to have the heads done, just call around to amchine shops.. i got both mine done along wiht my flywheel for $80.
Old 05-18-2006, 06:59 AM   #11
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Default :-( it finally happened.
Well it looks like it final happened to me yesterday. My cars temp gauge went up to H and my air blew cold, and the res. was overflowing with coolant. So ive come to the conclusion that my HG's are under way. I believe its because in the compression stroke that its push air into the coolant line, causing a 'block' in the system, so coolant exits but not enters basically. Well I found a place to have both HGs done with water pump, timing belt, and heads done for around 1100. So im taking him up on the deal and wont see my car until next week. . . but atleast it will get done.
Should I have anything else done while he's fixing that?
ALSO what specifically did you guys have done to your heads? just machined? or new springs and valves and such?
t.i.a.
m.
Old 05-18-2006, 08:14 AM   #12
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
if he's doing water pump, you might as well have the timing belt done.
Have him do any other gaskets that he can while he's in there.
Wiscon_Mark is offline   Reply With Quote
Old 05-18-2006, 08:51 AM   #13
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
t.i.a.
m.
To my knowledge, the previous owner who had the HG's go at 173K had the heads machined and all gaskets replaced; I don't believe any new hardware was required.
GTWagon_Phreak is offline   Reply With Quote
What Would You Do (Or What Do You Think Will Happen) TBOD Off-Topic 39 03-07-2006 02:00 PM
02-05 WRX owners. If you had to do it all over again what would you do? SinhCredible General Community 29 08-13-2004 06:28 PM
What should I do? What would you do? WiredWRX Southern California Impreza Club Forum -- SCIC 14 08-01-2004 06:08 PM
What would you do if you won the Big Game? DonA Tri-State Area Forum 13 04-09-2002 09:28 PM
What would you do if someone handed you the keys to a Pontiac Grand Prix? Bankheist Texas Impreza Club Forum -- TXIC 45 02-05-2002 04:03 PM
