Old 05-13-2006, 04:22 AM   #1
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Obsidian Black Pearl
Default Can I put different width of rims on front and rear?
I've got rota 17x8.
Can I put 225/40/17 for front and 235/40/17 for rear on my wagon?
cinemaster is offline   Reply With Quote
Old 05-13-2006, 05:53 AM   #2
silentbob343
Member#: 57307
The 40 isn't the height, but rather a ratio to the width.
I.e. the 225/40 has a 90mm tall sidewall or 3.54"
The 235/40 has a 94mm side wall or 3.7"
Good tool to help you see the difference in various tire sizes
http://www.miata.net/garage/tirecalcold.html
As you can see the circumference has changed. Now the 225s are going 837revs/mile to the 235s 827revs/mile. This difference will have to be sorted out via the center diff and depending on the size/amount of the difference this would not be good for it, i.e. overheat and cook the diff. The difference in your case is very small, but you should check with manual IIRC it states no more than a 1 or 2mm difference in which case you would be over. Is this a case of Subaru being over cautious and just trying to CYA.......
Food for thought; some tuners suggest using the same size tire, but using a wider rim on the front. This is what your thread title says, but you ask about tire in your post. A 255/35 would be closer to the 225/40 than the 235/40.
I'm no expert so take what I say with a grain of salt.
silentbob343 is offline   Reply With Quote
Old 05-13-2006, 06:06 AM   #3
seth_man
Member#: 73008
well you shouldnt. with some quick math the 225 tire has a 24.08" height and the 235 tire has a 24.4" height. now i know somebody is going to say that within 3 or so % of each other is ok. you CAN put them on but it will cut the life of your center diff down an unknown amount. i would try to get tires that are the same height.
the math: section width = W, aspect ratio = A, rim size = R
((W*A)/25.4)*2+R = tire height
tire manufacturers will also have all their tires specs on their website so you can compare sizes.
seth_man is offline   Reply With Quote
Old 05-13-2006, 10:38 AM   #4
waktasz
Member#: 86356
The circumference has to be within 3%...not diameter.
His original question was about wheel widths, and there are people who have done that...but different tire sizes are baddd.
waktasz is offline   Reply With Quote
Old 05-13-2006, 11:26 AM   #5
BIGSKYWRX
Member#: 7958
09 GH B+
You've also got the wrong relationship front and rear. With a AWD car you would generally want a wider combo up front, not rear (like a RWD)- ths will help dial out uneersteer.
The "easiest" way to accomplish this is to run the same tire front/rear- but run a wider rim up front say 8" front/7.5" rear- this gives you a little wider package up front (as a general rule section width increases ~ .2" per .5" of rim width increase).
You can run a different tire size combo, but you must be very cautious and get the heights very, very close (f/r)- proceed w/ caution w/ this endeavor.
Question on Front and Rear Diff Service meridock Transmission (AT/MT) & Driveline 3 11-12-2004 02:58 PM
FS:Complete set of v7 STI Front and Rear seats redcoupe Mid West Subaru Owners Club Forum -- MWSOC 2 11-01-2003 02:34 AM
can I put tire load of 85v on my Legacy? etam Tire & Wheel 0 09-12-2003 06:46 PM
where can i find a pictures of rims on a black wrx uwilllose Member's Car Gallery 2 04-07-2002 04:22 PM
install on front and rear links, anyone do it? Keith Technical Forum Archive 5 05-18-2000 05:23 PM
Message Board Statistics All times are GMT -4. The time now is 09:19 PM.
