Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 07-31-2006, 10:56 PM   #1
Brady12
Member#: 80923
2008 FXT (XT Sport)
Default Stock snorkel and boost problems...
Hey guys..
I'm running a SZ55 set up on Alcohol @ 25psi.
I recently swapped out the black stock crinkle snorkel section of my intake for a Samco. Its conncected to a Smaco inlet and TurboXS intake.
She doesn't seem to be boosting very well in 1st and 2nd @ 22psi. Will get up to 25psi in 3rd and over.
I was told that with the Utec, you NEED to have that stock crinkel part for it to read right?? It creates some kind of vortex that the Utec reads, is this true
Let me know if anyone has had similar problems or suggestions
Thanx
Brady12 is offline   Reply With Quote
Old 08-01-2006, 07:18 AM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Not at far as I know. I'm pretty sure that the sensor which detects pressure doesn't take flow into account(since it's a pressure sensor and not a flow sensor). Ie-A "vortex" shouldn't make the boost any higher unless it was put there by moses.
peace
hippy is offline   Reply With Quote
Old 08-01-2006, 08:10 AM   #3
2phless
Member#: 69343
1998 TransAm cnvrtbl
I've never heard of anything like that. The stock tube is supposed to flow well to a point. Perhaps the 55 is past that point.
What numbers were you hitting in 1st and 2nd with the "Smako" hose still installed? ( I like that typo... I'm calling them Smako from now on.)
I don't know of too many setups that'll make full boost in 1st or 2nd anyway, and with a big turbo like that... when is the soonest you can hit peak if you do a 3rd gear pull from a low rpm? (Not that it'll tell me much but I'm curious (<--> jealous) about the SZ55.
2phless is offline   Reply With Quote
Old 08-01-2006, 01:47 PM   #4
Brady12
Member#: 80923
2008 FXT (XT Sport)
Well my Smako hose looks great much bigger, what I think is happening is that I'm redlining it and not getting up to boost, but ok after 3rd. This makes sence, from what your pointing out.
What I think i may need to do is reprogram it to enable a bigger reline past 7k. I'm not quite sure how to do that.
This info about the read from the rippled black stock portion was from a tune I had in the past @ TurboXS. I don't think it was the right assesement of the problem. It was later realized that my i/c was not big enough and flowing enough air for the SZ55
btw the Smako hoses are a bitch to fit and replace....
Thanks, going take er out for another spin see how she feels.
Old 08-01-2006, 02:19 PM   #5
2phless
Member#: 69343
The redline with the DBW throttle is stuck at 7k for a while. I don't think the new firmware will even help there. The Cobb tuning package might. But after splitting my motor in half twice now though... I don't wanna go over 7k.
They all are. Getting rid of the stock fuel lines and re-routing the wiring under the intake somewhat helps. I just make my own intakes though. Cheaper, work great and have little chance of collapse.
Help w/16G and boost problems BrentS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-14-2006 06:05 PM
hesitation,rough idle, and boosting problem USMARINE24M Pre-2002 Factory Turbo Powertrain 3 06-11-2006 05:29 PM
EBC out and boost problems, help please Agkelos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-07-2005 11:13 PM
Acceleration and boost problems. jwease Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-06-2004 12:44 AM
rough idle and boost problem 2002wrxstock Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-19-2004 08:04 PM
