Old 05-14-2006, 06:13 PM   #1
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars ej22t bore or sleeve?
I was wondering what my best option would be with my ej22t. I want to fit pistons that are .02 inches (not mm) over sized. Should I get the blocked bored out or sleeved? Any opinions and options would be great thanks
*edit*
Sorry, I mean .02 inches...i dont know why i said .02 mm
tonzo is offline   Reply With Quote
Old 05-14-2006, 08:53 PM   #2
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
I was also wondering if anyone can give me a general price for both professional boring and/or sleeving
Old 05-14-2006, 11:52 PM   #3
ejsportcom
Member#: 88905
quirt crawford has said that .02" is pretty much all you can do if you decide to bore it.... really what it comes down to is what kind of power you want to make.....
Eric
ejsportcom is offline   Reply With Quote
Old 05-15-2006, 12:03 AM   #4
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
rrriigght, well i knew that already. I was looking for information on which would be more effective but also costworthy, boring or sleeving.
Old 05-15-2006, 12:49 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
0.02 mm you can 'hone' out. That's not much. Even 0.020 inch you could probably 'hone' out.
Sleeve if you want in increase displacement substantially.
Old 05-15-2006, 03:30 PM   #6
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
yea but i know i hone the cylinder out for real cheap but is the cost of sleeving worth the performance increase?
Old 05-21-2006, 07:41 AM   #7
LegacyJones
Member#: 48791
02 bugeye
wagon
I belive some local shops that boreing is $50- $100 A hole.
LegacyJones is offline   Reply With Quote
Old 05-21-2006, 12:43 PM   #8
Legacy Rally Guy
Member#: 104066
1976 1976 Leone GSR
With boring you can go up to 400 HP (bored within reason)
With sleeving you can go up to 700 HP
With boring, you are not in a very cost-preventative upgrade zone, but you can fairly inexpensively get the right parts ALONG with the boring to build some major horse power and still be reliable and not too pricey.. With sleeving, you had better go with major internal components to take advantage of the money you spent, which can be around 8 thou for complete built long block. However I'm not sure how much sleeving alone would cost... But sleeving just for the sake of durability... is quite costly, and unless you're running high ponies, like 400+ The fully closed, over engineered EJ22t block will handle it with the proper components and builder...
Legacy Rally Guy is offline   Reply With Quote
Old 05-21-2006, 03:08 PM   #9
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
Thanks for the reply. im going to look into sleeving i think. get some prices ranges. im doinga build that i think will actually take a while to get all the parts together anyway so I figure I may as well just go all out. We'll see what I can do. Again, thanks a lot
Old 05-31-2006, 11:56 AM   #10
subie4me
Member#: 89218
I ran a 2.2t block bored out to 99.5 for 3 seasons in a sandrail. It almost always was running 22 psi on 111 fuel. Last year I found a small crack in one cylinder and had the block sleeved with dartons.
subie4me is offline   Reply With Quote
F/S: Big Bore Darton Sleeves (WI) 0225wrx Engine/Power/Exhaust 8 09-28-2009 09:01 PM
New EJ25 Big Bore Darton Sleeves F/S (Madison, WI) 0225wrx MWSOC Private Classifieds 3 09-28-2009 08:52 PM
EJ22t cylinder wall/sleeve thickness... Homemade WRX Built Motor Discussion 24 07-04-2007 07:37 AM
pictures of my ej22, bored, stroked, sleeved STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 04-23-2003 12:45 PM
EJ22T bore & stroke? jeff22 Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-25-2002 12:07 PM
