Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 05-15-2006, 09:55 AM   #1
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Default Best place to buy wbo2
I think we can only use the NTK L2H2 UEGO with the Hydra. I'm having trouble finding one at all, let alone finding one cheap. Anyone have a hook up?
rjrutzky is offline   Reply With Quote
Old 05-15-2006, 11:00 AM   #2
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Try contacting Phil at Elemenet Tuning. I got mine as part of the Autotune option.
offset
offset is offline   Reply With Quote
Old 05-15-2006, 12:00 PM   #3
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Yeah I have one, I just need a backup to keep around. I just need the sensor, not the harness.
Old 05-15-2006, 01:14 PM   #4
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Well besides the harness, I would believe Phil could source just the sensor for you.
offset
Old 05-15-2006, 04:53 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
http://www.wbo2.com/
but I'd buy it from Phil. He's not going to gouge you on a maintainance part.
Old 05-15-2006, 05:46 PM   #6
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
THanks, that's not too bad ($220 shipped, US) Not sure what harness it comes with though.
Old 05-22-2006, 02:28 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
That's not a bad price but it will have the wrong connector on the end so you will have to splice the old connector back on.
I have spare WBs with the correct connector for $250 if you just can't handle wiring in your own
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-04-2006, 06:26 PM   #8
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
I bought one from http://www.oxygensensor.net/l1h1.html for $185 shipped. The price has gone up to $199 shipped but it is still the cheapest I found. It is an L2H2 and has a different plug but is easy to rewire. Paypal only. ships from Canada. I will buy from then again.
CK02WRX is offline   Reply With Quote
Old 10-31-2008, 08:14 AM   #9
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
Old thread, but neither of the sites suggested sell the L2H2 sensor. I have searched, and haven't come back with much. Any suggestions on where to buy a replacement sensor?
Would this be a possible replacement?
http://www.bmotorsports.com/shop/pro...roducts_id/352
Rizzo314 is offline   Reply With Quote
Old 10-31-2008, 09:01 AM   #10
gumby647
Member#: 2532
2001 2.5RS-T
BRP
I believe that is the right sensor.
gumby647 is offline   Reply With Quote
Old 10-31-2008, 10:04 AM   #11
Rizzo314
Member#: 42215
Right on, thanks. I'll get one ordered today.
Old 10-31-2008, 03:24 PM   #12
sean18337
Member#: 135588
2007 STI *SOLD*
I see the connector is different for this sensor:
Can you just pop the pins out and pin in the Hydra connector?
sean18337 is offline   Reply With Quote
Old 10-31-2008, 03:30 PM   #13
Rizzo314
Member#: 42215
If that doesn't work, you can cut off your current plug and solder it onto the new sensor.
I replied to your message, btw.
Old 11-12-2008, 08:39 AM   #14
sean18337
Member#: 135588
2007 STI *SOLD*
Did you get the sensor in yet?
Old 11-12-2008, 11:29 AM   #15
Rizzo314
Member#: 42215
Yea. It reads the AFR, but is acting really weird. Sometimes it will be in the neighborhood of the reading on my AEM wideband, and sometimes it will stick at 22.20 and then oscillate between 22.20 and 9.X. I have redone the connections, and they are secure. I have also recalibrated it twice.
Old 11-16-2008, 07:02 PM   #16
chrisbmx68
Member#: 194489
1984 VW rabbit gti
jazz blue
its possible its a bad sensor but it sounds like a grounding issue of some sort. Does it matter if the car is warmed up or not when you get the sporadic readings?
chrisbmx68 is offline   Reply With Quote
Old 11-18-2008, 12:23 PM   #17
Element Tuning
Member#: 54918
673 WHP Element
Or this sensor is not compatible with the Hydra EMS system. There are many versions of the NTK sensor with various resistor values.
Old 11-19-2008, 10:33 AM   #18
gumby647
Member#: 2532
2001 2.5RS-T
BRP
So is the Hydra only compatible within a certain range of resistor class? I would have thought that if it was out of range you wouldn't be able to calibrate it.
Old 11-19-2008, 02:20 PM   #19
Caballero_STi
Member#: 122711
05 STi
Caballero_STi is offline   Reply With Quote
Old 11-20-2008, 12:51 PM   #20
Element Tuning
Member#: 54918
673 WHP Element
I don't know unfortunately as I'm supplied with the correct version. The numbers are on it but apparently on some of the WBs purchased from that website they XXXXXXX all the numbers so who know what you are buying.
With the 2.6 Hydra you can use an external input from a WB kit so read up on the manual if anyone is interested. Also this is for data logging purposes only and doesn't allow closed loop fuel control or Autotune.
Best place to buy a sti in the bay - also where to get it for invoice? maaw Bay Area Impreza Club Forum -- BAIC 9 06-27-2008 03:15 PM
('93-'01) the best place to buy rally videos online Prog Impreza Forum 6 04-18-2001 12:55 AM
Where is the best place to buy NGK VX in E-town? V6 Canada Region Forum 1 03-10-2001 12:22 AM
Best place to buy a helmet in SF Arnie Bay Area Impreza Club Forum -- BAIC 7 02-20-2001 12:32 AM
Where is the best place to buy an Impreza? Racer X Mid West Subaru Owners Club Forum -- MWSOC 6 09-30-2000 07:56 PM
