Old 05-15-2006, 12:27 PM   #1
ttatsumi
Member#: 85763
Default Replacing headers
i own a 02LGT. I was wondering how difficult it is or easy it is...for a newbie to install a header? suggestion of time/ tools/ difficulty level will be much appreciated. thank you.
ttatsumi is offline   Reply With Quote
Old 05-15-2006, 12:52 PM   #2
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
I'll be disconnecting my headers this weekend to get to my O2 sensors, but it looks pretty simple after spending a while under my car this past weekend.
I'd imagine your access to it is about the same as my 97, but you should be able to get to the headers where they bolt to the exhaust ports. A couple bolts on each exhaust port should take it off the block and then a couple more bolts that connect it to the cats. Now if you have a turbo I'd imagine that will change somewhat.
Really just get under your car and look, it should all be in plain sight. I'd recommend soaking the bolts you'll be working on in PB Blaster the night before or a few days before to loosen then up a bit. Also torque them back down properly using factory specs.
GTWagon_Phreak is offline   Reply With Quote
Old 05-15-2006, 04:53 PM   #3
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I've heard that some good RTV and new gaskets are recommended. It should be three bolts per side, and two on the connector to the cat section. As GTWagon_Phreak mentioned, take a look and then soak the bolts in PB, even if they look ok.
DLC is offline   Reply With Quote
Old 05-15-2006, 04:56 PM   #4
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
What's RTV?
Old 05-15-2006, 04:59 PM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
It's a silicone sealant that'll make up for where the gaskets can't. This stuff has been recommended over in the NA forums more than a few times:
Ultra Copper RTV
Old 05-15-2006, 05:02 PM   #6
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
That's what I thought it was. So do you just put this stuff on either side of the gasket and then bolt everything up?
Old 05-15-2006, 05:11 PM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I'm not certain, but that makes good sense to me.
Greddy Profec B-spec 1 solenoid replacement sum0325 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2010 04:55 PM
Replacing Headers on 05 Sti CFaz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-24-2009 06:10 PM
Replacing headers on my '02 WRX... StiNV76 Newbies & FAQs 29 05-15-2007 09:47 AM
Gaskets when replacing headers... Reciprocity Normally Aspirated Powertrain 2 11-01-2000 07:18 AM
Replace header but keep CD? Sammy Car Audio, Video & Security 6 05-23-2000 01:34 AM
