Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 05-15-2006, 11:52 AM   #1
brama
Member#: 114994
Default dies going uphill and hard acceleration
92 subaru legacy 2.2l auto awd 250000km
The problem is when I load down the engine going uphill or accelerate the car will start to miss and then die. I pull over to the side of the road , wait for a minite and it will start. This happens on every hill if I load down the engine to much. If I don't load the engine down and am careful with the throttle I can make it up the shorter hills but not the long one. I was having a problem with detonation happening just before it died but I think I have that fixed by putting in colder plugs. Now I don't have any pinging or knocking but it still dies. To me it feels and sounds like a fuel starvation problem.
Things I have done:
-seaform
-Tko injector cleaner(not cheap stuff)
-plugs and wires
-O2 sensor new
-knock sensor new
-fuel pump and filter
-91 octane fuel
-compression is 1,2,3, 175psi 4 190psi
-air filter
The car idle smooth and accelerates smoothly. But after a 3 or 4 seconds I can feel it starting to miss then I know it's going to die.
This happen every day, not just once in a while.
Any ideas Please
brama is offline   Reply With Quote
Old 05-15-2006, 12:06 PM   #2
Rice & Gravy
Member#: 39569
09 Acura TSX 6spd
Sounds like an injector to me. Any CEL (check engine light)?
Rice & Gravy is offline   Reply With Quote
Old 05-15-2006, 12:07 PM   #3
brama
Member#: 114994
No codes
Old 05-15-2006, 12:08 PM   #4
Rice & Gravy
Member#: 39569
09 Acura TSX 6spd
Originally Posted by brama
No codes
Hmm, strange. If it was an injector you would definitely have a misfire at that cylinder and a code. Sounds like you have ruled out everything else though. I had an old Sentra that did something similar to this and noone could ever figure out why. I eventually traded it in. Not that any of this helps...
Old 05-15-2006, 12:15 PM   #5
brama
Member#: 114994
Thats the stange thing. I get no codes and no cel. I am going to try changing the fuel regulator and the MAF. But I am just guessing. This is starting to drive me nuts. And getting a little expensive.
Old 05-15-2006, 03:57 PM   #6
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The MAF sounds like the leading candidate. If it's not reading the amount of air properly, then you're leaning out the car badly and not making any power. It is odd that you're not hearing any pinging, but it might be so bad that it can't get enough load to be noticeable.
DLC is offline   Reply With Quote
Car revs but doesn't go under hard acceleration mrgreen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-04-2010 12:10 AM
Mystery Sound when turning and going uphill andrewt461 Brakes, Steering & Suspension 18 11-07-2009 01:59 PM
Toe and stability during hard acceleration question Ziggyrama Brakes, Steering & Suspension 26 10-24-2006 03:39 PM
squat durring hard acceleration and shifts hendo2.5 Brakes, Steering & Suspension 3 10-10-2005 07:29 PM
('93-'01) long, hard left turn + hard acceleration + shifting = 2nd gear grind? beachbum Impreza Forum 6 07-27-2001 10:25 PM
