Old 05-15-2006, 01:22 PM   #1
playball0331
Member#: 114921
Default Fuel injectors
Hey,
You guys have been very helpful with my Legacy problem.
Another question-----
How do I replace the fuel injectors? I can see them and removed the two screws, but I don't want to start yanking on what appears to be a plastic injector.
It is threaded? Is it held w/a gasket? Do I need a special tool?
Sorry to be an idiot.
JD
playball0331 is offline   Reply With Quote
Old 05-15-2006, 04:27 PM   #2
LegacyJones
Member#: 48791
02 bugeye
wagon
Make sure to remove all the bolts. I think there's 4 on each side. MY00 has 5 on the drivers side.The bolts are 12mm. Remove all the bolts and gently pull up. The rail and injectors will come out. Undo the wire clip and pull them out. Their held in by o-rings.
Jason
LegacyJones is offline   Reply With Quote
Old 05-15-2006, 05:24 PM   #3
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
Any complications with engines that have a lot of miles on them? I'm pretty sure the original injectors are in my car, although they may have been removed/reinstalled around 173K when the HG's went & the engine was rebuilt.
GTWagon_Phreak is offline   Reply With Quote
Need rubber wrx fuel injector o-ring or fuel injector Shaitiger Private 'Wanted' Classifieds 2 02-11-2004 10:17 AM
MA: 02 WRX Fuel Injectors and Fuel Pump K2Skier Private 'For Sale' Classifieds 0 09-20-2003 12:33 AM
Fuel Rail, and Fuel Injector Questions. blindclown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-11-2003 01:10 PM
Stock Max Fuel Rate on Fuel Injectors -=Ph/\t WRX=- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-22-2002 11:51 AM
Fuel Injectors / Fuel system JC SPORTS Technical Forum Archive 75 07-14-2000 09:51 PM
