Old 05-15-2006, 05:32 PM   #1
neoncrazy101
Member#: 113685
1990 Legacy
blue
Default short shifting?
Hey i've been wondering if short shifting in a mtx hurts the transmission or the engine or any part of the drivetrain?
neoncrazy101 is offline   Reply With Quote
Old 05-15-2006, 06:35 PM   #2
sha_zapple
Member#: 41012
1998 Legacy L
the actual short shifter does not hurt anything. However, the way youll want to drive with it installed might
sha_zapple is offline   Reply With Quote
Old 05-15-2006, 06:40 PM   #3
supermarkus
Member#: 6971
2008 WRX STi
SSM
Short shifting or short shifter? There IS a difference.
supermarkus is offline   Reply With Quote
Old 05-15-2006, 06:47 PM   #4
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
Excessively short shifting, say, at 2000rpm, while running the motor at full throttle, can put a lot of load on the connecting rod bearings.
MCarp22 is offline   Reply With Quote
Old 05-15-2006, 07:36 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
If you're short shifting and putting a lot of load on the engine, then yes, you can damage the engine in the long run. It's called "lugging" the engine, and it's not a good thing to do. Think of riding a 10-speed bike - what puts more load on your legs (aka your connecting rods), starting from a slow roll in 10th gear or in 1st gear?
If you're short shifting and using gentle throttle application (to just ease your way up to speed) then it shouldn't damage anything. It's not going to gain you anything either, though, as it's an inefficient way to drive.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 05-15-2006, 10:40 PM   #6
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
2000 rpms is lugging?
Not on my car.
below 1500 is though.
Wiscon_Mark is offline   Reply With Quote
Old 05-15-2006, 10:45 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well, if you shift at 2000rpm, your RPMs in the next gear are going to be under 1500rpm (except on the 3-4 shift, in which case you'd be right at 1500rpm).
And again, lugging isn't just driving at low RPM, it's putting a large load on the engine at low RPM. Cruising along at 1500rpm may be fine, but I certainly wouldn't go WOT at 1500rpm - I'd downshift instead.
Pat
Old 05-15-2006, 11:00 PM   #8
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
oh, gotcha
With my 3.9 FD, I find that I might just lug it a tad, keeping every shift under 2000...1->2 and 4->5.
Old 05-15-2006, 11:04 PM   #9
neoncrazy101
Member#: 113685
1990 Legacy
blue
ok good yea cause i was doing this MPG test with my Neon to see which way would give me better gas milage and i found out today that i lost 5MPG by shifting at 2k-2.3k. so its back to shifting between 2.5k-3k.. the reason why i didn't do this in my Legacy is because its an automatic and has some problems that needs attending 2.
Old 05-16-2006, 10:07 PM   #10
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
I drive AT Legacy and I tell it when to shift.. Usually you can train uself on AT cars so the trany switches when you want it to... I've gotten really good at that and usually 2500 and hardly over 3000 is optimal place to shift.
NiTRoN is offline   Reply With Quote
wtb kartboy short shifter/sti short shift kit 5MT mcyyy123 SCIC Private Classifieds 5 10-18-2009 08:16 PM
Oem short shifter vs. aftermarket short shift? SubeN'Siren Transmission (AT/MT) & Driveline 5 02-17-2008 11:23 AM
Kartboy Short shift, Subaru short shift and knobs 49erRider Interior/Dressup/Audio & Security 7 04-30-2007 07:20 AM
Short shifted short shifter Fubaru General Community 10 05-15-2004 05:04 PM
Difference between STi short shifter and dealer install short shift kit? tsay Transmission (AT/MT) & Driveline 6 12-29-2001 05:12 AM
