Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Old 05-16-2006, 05:53 AM   #1
QwikRex
Member#: 40284
2007 370z sport 6MT
Magnetic Black
Default How much variance in tire diameter is bad for center diff?
I decided to rotate my tires today and figured I might as well check out the tread depth on my Yokohama AVS ES100's. Tread depth of the front tires were at 4/32 of an inch and the rears were at 5/32 of an inch. I checked the circumference of the front vs. rear tires and the difference between them was about 0.197 inches. Is this within spec enough to not damage the center diff?
QwikRex is offline   Reply With Quote
Old 05-16-2006, 07:03 AM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
1/4" is the max according to subaru.com and your owner's manual.
Old 05-16-2006, 11:20 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That's 1/4" rolling circumference, not diameter.
Old 05-16-2006, 06:10 PM   #4
QwikRex
Member#: 40284
2007 370z sport 6MT
Magnetic Black
Cool, then I should be ok then.
Old 05-17-2006, 12:41 AM   #5
Silverpike
Member#: 92399
OMG seriously? 1/4" is a very small difference.
I searched NASIOC for exactly this info when I needed new tires, and couldn't find jack (My car didn't come with an owner's manual). Now 2 months later I see this.
I have a set of 235/40/17 on rear and 225/45/17 on front.
Is the damage serious? How much of a concern is this?
Silverpike is offline   Reply With Quote
Old 05-17-2006, 09:30 AM   #6
Hayes
Member#: 11808
1/4" circumference equals approximately 2/32" difference in tread depth on a 215/60/16 tire. I think the 1/4" difference may be consider may be conserative but, do we really know?
Hayes is offline   Reply With Quote
Old 05-17-2006, 10:10 AM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
http://www.subaru.com/common/faq/tech_info.jsp#4
UkNuck is offline   Reply With Quote
Old 05-17-2006, 07:01 PM   #8
Silverpike
Member#: 92399
Originally Posted by UkNuck
That doesn't exactly help, especially since the relevant question now is: what sort of damage is possible to the diff?
Won't the diff just get a little hotter? It is a viscous unit, which should be tolerant of F/R bias.
Old 05-17-2006, 10:02 PM   #9
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
It will blow your center diff and yes it does happen. Just like when your car is towed by two wheels.
Old 05-18-2006, 11:33 AM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it's absolutely ridiculous. it makes the donut spare a failure waiting to happen.
if you keep your speed low there shouldn't be a problem. the lower the better.
i suspect soa is covering their asses so that they do not have to provide warranty coverage for ANY vc failures.
Originally Posted by some dealer
ok, we checked it out, and we found some stuff that's broken. problem is, your tires have more than 0.25" rolling circumference differential. i know you don't want to hear it, but sorry, we can't warranty that. your total cost comes to $500 for a new diff, and $700 for the labor.
Old 05-18-2006, 12:39 PM   #11
birukun
Member#: 52801
1999 Legacy Wagon L
Green 30th Anniv.
I believe the owner's manual has specific directions on the use of the spare, ie. you must enable FWD only with the fuse under the hood (for the 4EAT at least) and I think that the spare goes on either the front or back in an ideal situation.
I carry AAA and would insist on a flatbed for towing.
Bill in SD
birukun is offline   Reply With Quote
How much trade in value can I get for my baby? Dystinct Off-Topic 9 03-02-2007 11:12 AM
How much oil in the exhaust is normal? stevenh Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 08-20-2004 09:16 PM
different size rear tires... 0.5% too much for center diff? idealrides Tire & Wheel 4 05-10-2004 06:34 PM
How much difference in tread depth is OK? leecea Tire & Wheel 2 07-18-2003 11:41 AM
How much - camber in the rear is too much? ebeck Brakes, Steering & Suspension 10 05-31-2003 02:10 PM
