Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-16-2006, 10:02 AM   #1
xolosis
Member#: 103373
Default CLB Boost values after Perrin EBCS Install
For those of you who use the Perrin EBCS with UTEC I'm wondering what your CLB values are?
Currently I running up to 400 in my boost map to hit 18psi with the stock solenoid and resitrictor pill in the compressor hose going to the T piece.
I've seen maps as low as 240 CLB whilst running 3 Port Solenoid hitting 20psi. I'm looking to start at 200 CLB and work up. Will need to ajust boost gain a suspect just to combat spiking. Does 56 sound about right?
xolosis is offline   Reply With Quote
Old 05-16-2006, 09:52 PM   #2
Strng1dah
Member#: 7053
13.1@104
Start the gain around 55, and adjust until you find what works for your setup...
Strng1dah is offline   Reply With Quote
Old 05-16-2006, 11:18 PM   #3
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
I use 350clb for 17psi on an 18g.
gaby is offline   Reply With Quote
Old 05-16-2006, 11:19 PM   #4
gaby
Member#: 94097
11.2@130.7
O 48 the gain value with .5psi of spike
Old 05-18-2006, 03:35 PM   #5
Freon
Member#: 88322
2009 BMW 135i
~360 peak at 4250rpm for 16.5psi, 330 at redline for 15 psi. BG at 55. I get a small amount of spiking sometimes, but I deem it acceptable. Just an STI with a FMIC, TBE. I am using a GM solenoid, though, but the 3ports aren't going to vary all that much.
Freon is offline   Reply With Quote
Old 05-18-2006, 03:49 PM   #6
Xman23
Member#: 50224
2004 WRX
360 max value. 50 gain
Hits 16.5 mostly, occasionally up to 17.
Xman23 is offline   Reply With Quote
Old 05-18-2006, 04:29 PM   #7
TurbojonLS
Member#: 38772
2 Cars, No Bling
46 Gain, I don't remember what my values are, but I took about 100 off the values I was using with the stock solenoid & tweaked it a bit to peak at 20 psi & taper to 13.
TurbojonLS is offline   Reply With Quote
Old 05-19-2006, 02:46 AM   #8
xolosis
Member#: 103373
Much appreciated guys! Low values to start with should keep it safe.
FYI - I'm using 46 Boost Gain and 380 CLB's to hit 17psi max tapering down to 15 by redline.
Old 05-27-2006, 01:07 AM   #9
xolosis
Member#: 103373
Well I got the Perrin EBCS, Larger Turbo and Fuel bits to play it safe.
Now I used to use 380CLB it hit 17psi but with the EBCS the value has come down to 180CLB to hit 17psi. This doesn't sound right to me and if almost 1/2 the value. On the Perrin instuctions for UTEC users it says lower your values by 30%. I've got it hooked up for fast reponse.
Its hitting boost no problems with a gain of 50. Still baffled why my values are so slow but the only answer could be that the Acentuator on the turbo might have a larger spring.
Cheers!
X
Old 06-06-2006, 10:16 PM   #10
9d2TSi
Member#: 84852
2007 WRX TR
CGM
Good stuff, thanks all.
9d2TSi is offline   Reply With Quote
CEL/Bucking after AOS/EBCS install? tenchu Pre-2002 Factory Turbo Powertrain 5 05-28-2010 10:07 PM
FS: Omori Boost Gauge, ECU, Perrin EBCS RicerJim MAIC Private Classifieds 4 08-05-2008 07:17 PM
Quickie: Perrin EBCS install Panic Factory 2.0L Turbo Powertrain 5 09-29-2006 08:06 PM
Boost Gain = 0 / Perrin EBCS xolosis UTEC 11 07-20-2006 04:35 PM
Boost problem after Perrin downpipe install, how can I fix it? JDWRX02 Factory 2.0L Turbo Powertrain 12 02-10-2003 11:58 AM
Message Board Statistics All times are GMT -4. The time now is 09:05 AM.
