Old 05-16-2006, 02:28 PM   #1
crosta21
Member#: 72341
Default buying 93 legacy!! anything to check for??
im lookin at buying a 93 subary legacy sedan. Its a 5 speed with 83k on it. Any common problems i should check for? I guess i could just pay the 100 bucks and have a subby dealership check her out but i figured i'd ask on here 1st. The car is at a dealership btw...
crosta21 is offline   Reply With Quote
Old 05-16-2006, 04:52 PM   #2
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Watch out for leaking sunroofs. Otherwise, my 93 was a turbo so it didnt share much else in common with the non turbo 93 your looking at. If you dont have a sunroof, cant think of much else. Although the 2.2 are somewhat prone to oil leaks later on in life. But then again, what isnt?
Samirr76 is offline   Reply With Quote
Old 05-16-2006, 05:10 PM   #3
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
the most common problem on the older legacies is that the door locks and window electrics start acting up and not working right all the time.
rust is the only other thing you really have to worry about on them.
nothing different from any other car.
if the timing belt hasnt been replaced it should be soon but it isnt that much of a worry as the ej22 is not an interference motor.
the drivetrain on those legacies was designed to last at least 250,000 miles.
my 95 has 246,000 and is still going strong.
you may need to replace the cam seals and valve cover gaskets at some point in the next 20,000 but that isnt too hard or too expensive.
look for oil on the timing cover below the crank pulley. that is a sign that the front crank seal or the little o-ring in the oil pump is leaking and should be replaced at some point. but leaks like this shouldnt be viewed as a deal breaker.
greg donovan is offline   Reply With Quote
Old 05-16-2006, 05:12 PM   #4
greg donovan
Member#: 60743
'95 Impreza L
oh and you should head on over to http://bbs.legacycentral.org/index.php that is the site to be on for 90-94 legacy info.
most of the members there are members here as well.
Old 05-16-2006, 06:36 PM   #5
ninethreeeleven
Member#: 99777
I had a 1993 Legacy Wagon. Things I had problems with (from memory)...
Rust under the rear bumper. My rear bumper was harldy held on because the screws rusted through. This may not apply to sedans.
Engine ticking when oil change needed (also burned oil). I had to change my oil at 3k almost exactly. It would start ticking right after that.
I really cant remember anything else. If you have specific questions they are very much the same car and I would be glad to answer anything I can. Send me a PM if you think of anything.
ninethreeeleven is offline   Reply With Quote
Old 05-17-2006, 01:29 AM   #6
crosta21
Member#: 72341
well my trans just blew on the highway on my 91 legacy wagon. and it was at 140,000 miles. LOL so i think im gunna go on this one. The a/c is even sposed to still work but we'll see. Thanks for the help guys!
Old 05-17-2006, 08:06 AM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
good luck!
Wiscon_Mark is offline   Reply With Quote
Old 05-17-2006, 11:28 PM   #8
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Hows the idle?
Lots of the old legacys have rough idles usually caused by poor engine grounds or vacuum leaks. Not too big of a deal, unless the gas mileage is eating a hole in your wallet.
Kawikid20o2 is offline   Reply With Quote
Going to Park City 26th-2nd...Anything to check out? chongl Rocky Mountains Impreza Club Forum -- RMIC 40 01-04-2010 10:38 PM
what to check for when buying used cobb ap v1..? TIA MrMakesitRain Newbies & FAQs 8 06-14-2008 04:05 AM
Business trip to Vega this week - limited free time, anything to check out? Hazdaz Off-Topic 24 03-24-2007 05:55 PM
Looking to buy early 90's legacy, what to look for? AWD>FWD Legacy Forum 59 11-14-2006 07:19 PM
Anything other than BBB to check for auto repair shops? C-daleRidr Off-Topic 2 01-06-2004 04:53 PM
