#1 |
Member#: 92860
Vehicle:02 wrx yellow |
i am trying to make the boost run a little higher. it is at 15 lbs right now and i cant make the numbers on the boost map any higher than 500, and it doesnt seem to go any higher than 16 lbs. any suggestions?
#2 |
Member#: 92860
should i play with the boost gain
#3 |
Member#: 35020
VIC
Vehicle:2002 WRX - stage WTF 1992 JDM WRX Satan Black |
have you installed the ABC and opened it a couple turns??? That seems like the most likely culprit to poor boost resolution. Or have you taken out the brass restrictor pill in the line off of the compressor cover?
#4 |
Member#: 94097
Vehicle:2004 WRX Hybrid GT35 11.2@130.7 |
500 is max out dude.
#5 |
Member#: 35020
VIC
you should be able to hit 16psi with the ABC and stock restrictor pill easily at about 2-300 in the boost map depending on how many turns the ABC is open.
| Thread Tools | |
| Display Modes | |
| XEDE Vishnu STi Stage 1 maps off Vishnu's website, boost map is wrong? | STi City | Factory 2.5L Turbo Powertrain | 14 | 02-03-2004 11:02 PM |
| UTEC Closed Loop Boost Maps | peterex | Engine Management & Tuning | 45 | 01-16-2003 12:07 AM |
| A thought on link boost maps | Midwayman | Engine Management & Tuning | 14 | 09-18-2002 01:22 PM |
| Factory Boost map? | zmw | Factory 2.0L Turbo Powertrain | 4 | 12-19-2001 03:42 AM |
| Unichip Boost map | ellisnc | Factory 2.0L Turbo Powertrain | 0 | 08-18-2001 06:54 AM |
