#1 |
Member#: 102013
Vehicle:2002 WRX |
With respect to reliablity, horsepower, practicality, torque, third vehicle driven four to three times a week.......and taken to the track on sundays.....
Crawford? Axis? ej22t stroker engines? I have 2002 wrx with 20,000 miles....looking for a change. Wondering if I should get all the mileage possible out of the 2.0L with these mods.....then what set up to go with....any ideas....money is not an issue ...no ideas a big issue. FMIC 20g ppg gearset gt spec headers up/down pipe straight thermal exhaust no converters 850cc perrin fuel rail koyo radiator utec lightweight pulleys etc
#2 | |
Member#: 94494
Vehicle:2005 Element 92x Black |
World One is selling built motors, and their stage 2 is exactly that. EJ257 with forged pistons at a great price. WWW.Subarumotors.net One thing you might consider in your build is heads too. Most people who do shortblock swaps in WRX's find the WRX heads/cams too restrictive. If you get your heads p&p'd, and get STI cams, you'll get more power for your setup. I chose to go with full STI heads and swapping my utec for a Hydra, since the Hydra has AVCS control. Something to consider too since you could sell your WRX longblock to help with the cost. I figured out that if I pay for the USDM heads (roughly $1500-$2000 for a good set), my old engine would have a much better re-sale value. EJ205 shortblocks are worht $300 at best. The ECU's aren't worth much either. You might find a RS or Legacy guy who's willing to part all the pieces together, but unlikely. If you move to a built EJ257 shortblock, USDM STI heads, and a Hydra, you could sell your old complete engine with ECU and UTEC for at least $2500, recouping much of your cost. In fact, you might try to buy a used WRX tranny case and have your PPG's installed in those. Most Legacy and RS owners told me they'd pay well over $4,000 for a complete WRX engine with ECU and tranny. For people who are replacing simply for the performance, this saves us a LOT of money. Plus anybody who's driven a hybrid vs a full sti engine will tell you the AVCS is nice. Helps with a smoother power band and spooling your turbo faster. I tried to start a thread about this a while ago, and nobody could seem to grasp what I was talking about. I guess the reason why this doesn't work for most people is upfront cost and the fact that most people replace their shortblock because it's blown, and they need a cheap replacement. |
#3 |
Member#: 59057
AKIC
Vehicle:2004 Impreza, STi. Silver |
Bump UP! The Stage 4 motors sound perrrfect!
#4 |
Member#: 107276
Vehicle:99 V.R.Special WRC blue |
dream spec hey? thatll be the one im building lmao!
try this one, ive left electronics and a few things out but its the basics of my engine build, hope it helps you Based upon 2ltr closed deck RA block Samco coolant hose kit Samco air box hose Samco turbo intake pipe RCM modded oil pump Jun cams 272 profile Verniers to go with above Pulse plasma nitrided inlet valves Nimomic pulse plasma nitrided exhaust valves 16 up rated valve springs 16 uprated titanium retainers collets to match above Custom CNC head polish + port oil catch tank Samco hoses and fitting kit for above RCM blue oil filler cap 14 mm outer head studs12mm inner head studs machining for above light weight pulley set custom omega deep dish pistons fully balanced arrows EN24 h section wrc spec rods (beryllium little ends) big end bearings for above Cross drilled 75 mm stroke billet steel crank custom equal length rotated tubular manifold with tial 44mm external waste gate running a screamer pipe fitting kit for above rotated 3 inch down pipe rcm 3 inch centre section rcm team ice rear box fitting kit for above fuel rail for aero 8 2 x bosch 200 pumps with filters 2 x SX regulator braided fuel lines, aero fittings eight 550 cc injectors (4 to go in custom secondary TVG mounts) JDM STI7 red top inlet manifold (to be spun 180 and fully ported) 100 mm spun induction trumpet k + n 160 mm induction cone Garret custom hybrid GT30R Custom V-mount mount intercooler +rad with hard piping Oil cooler + mounting kit Aqua mist system 2 d water injection system motec m800 ecu zex 55 shot nitrous |
| Thread Tools | |
| Display Modes | |
| FS : Power set up injectors big maf big turbo!! Look inside | hottwrx02 | Engine/Power/Exhaust | 11 | 06-20-2010 07:59 PM |
| Questions about this engine set-up | explosivexover | Factory 2.0L Turbo Powertrain | 3 | 12-17-2005 08:58 AM |
| OT: Could you recommend an engine/driveline set-up? | EcksJay | Off-Topic | 14 | 10-03-2005 11:40 AM |
| rebuild engine + turbo set up?? | sniperSTi | Proven Power Bragging | 1 | 09-11-2004 10:49 AM |
| Whats your Finished/Dream set up? | dubba you are ex | Interior & Exterior Modification | 17 | 06-24-2004 08:42 PM |
