Old 05-16-2006, 08:52 PM   #1
zaarin
Member#: 95404
2002 WRX Wagon
What color is bird crap?
Default Clunk sound like a tight bolt being broken under high torque?!
Here's a good one:
I'm navigating at very slow (parking lot or lower, maybe even parkING) speeds, and I hear a clunk/pop noise, like the sound of a really tight bolt being broken loose under lots of torque. This occurs rarely, but usually while I'm turning AND rolling over a speed bump/jagged gutter/pothole. Clunk/pop NEVER occurs over ~5mph.
What could the clunk/pop be coming from? I have already checked sway bars and endlinks, and strut tower bar, everything else is stock. Symptoms just started about two weeks ago. What else is in the suspension that can make that noise? Hopefully the lower strut bolts aren't loose. Could a spring have gotten unseated or something?
zaarin is offline   Reply With Quote
Old 05-16-2006, 09:34 PM   #2
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Hmmm, what happened two weeks ago?
Oh, right! You jumped your car at rim of the world!
Spring could be unseated, certainly. Broken bearings in your front tophats, perhaps. Lower control arm bushings could be shot/bent. Broken ball joints. Damaged hubs?
Does the noise occur just turning and moving? Are you putting on the brakes as well?
Arnie is offline   Reply With Quote
Old 05-23-2006, 06:01 PM   #3
zaarin
Member#: 95404
2002 WRX Wagon
Yes, well, I'm proud of that. Not many can say they've had all four wheels in the air at the same time.
So, basically anything in the entire front or rear suspension could be broken? The noise only occurs when I'm moving ~5mph or less, and VERY intermitently. Not even half the time, more like 1/10 of the times. So it's really hard to track down. I'd say that when it's happening 1/10 of the time, 1/5 again of THOSE times, it's in the rear. Very distinctively, not questionably so. So again, hard to even tell what kind of driving causes it; the only common factor I can think of is 5mph or less over rough terrain, and turning. (speed bumps, driveways, etc) Sometimes under braking, sometimes not.
I don't even know where to begin with this. I'm kind of planning to ignore it until something gets worse and more easily identifiable.
Old 05-23-2006, 11:40 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....find a place that it happens...take 'car guy' friend.....friend(or you) drive car while the other one walks next to car to isolate the noise.....try with hood/trunk up/open.....ride in trunk or on front of car is necessary.
Old 05-24-2006, 01:12 PM   #5
AshyLarry
Member#: 94890
03 wrx
I'm having the same problem, but I didn't take my car off any sweet jumps. Update the thread if you figure it out cause its bothering me too.
AshyLarry is offline   Reply With Quote
Old 05-24-2006, 01:28 PM   #6
tuskenraider
Member#: 65699
15 WRX
WR Blue
Definately check your wheel bearings/axle nuts(cause of a clunk I had).
tuskenraider is offline   Reply With Quote
is this what clunking sounds like? DieselClown Brakes, Steering & Suspension 2 12-05-2008 10:01 AM
Clunking sound from under car when letting off throttle guitarmaster1195 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-16-2008 01:35 PM
Sounds like I'm going to be attacked Monday linux>windows Off-Topic 213 02-21-2006 10:52 PM
Burns Rally sounds like it might actually be good... Idjiit Off-Topic 4 01-20-2004 01:48 PM
how tight should 14mm caliper bolts be? RotarFreak Transmission (AT/MT) & Driveline 3 02-11-2002 12:30 PM
