Old 05-17-2006, 03:53 AM   #1
Sypher
Member#: 106366
2006 WRX
Default STI brembos VS Subaru 4 pots/2 pots
just a quick Question, If yah upgrade the Pads and Fluid and lines in the 2006 WRX and slightly lower the car and stiffen up the frame, will the car be able to achieve the same if not better breaking distance VS an STI with stock brembos. I searched and read and basically what Ive come up with is "Yes they will" I just want a definite answer. Im having a debate with a local STI owner.
Sypher is offline   Reply With Quote
Old 05-17-2006, 03:58 AM   #2
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
adding some better tires to your mix will help.
Bishop is offline   Reply With Quote
Old 05-17-2006, 09:58 AM   #3
rkkwan
Member#: 5596
2010 Honda Fit Sport
If you're just worrying about a one-time 60-0 stop, then brakes don't really matter. Tires do. Go do a panic stop and you'll find that ABS should come on pretty quickly, meaning the tires are the limiting factor. Even more so in the wet.
Now, if you're doing track days, then it's a different matter, as heat resistant/dissipation is the important thing in the brakes. Auto-x has yet other factors people consider, like initial bite.
rkkwan is offline   Reply With Quote
Old 05-17-2006, 01:28 PM   #4
Sypher
Member#: 106366
2006 WRX
well I guess it would be more like "Track day" stuff. Basically the only gripe I have with my brakes is that they fade VERY easily. The STI's stopping distance seem to be somewhat shorter as well. But I suppose theres many factors involved in that. idk, I just need a brake set up that wont fade when they get hot. There have been many times where I end up litterally smoking my rotors to the point one of my friends can light a ciggerate off them. At that point my brakes get a very spongy feel and they damn near stop working. I suppose Brake Fluid, And Pads, and lines would help. Oh and tires. But I never get to that point of locking up my tires any way. Its inbetween im worried about lol
Old 05-17-2006, 03:29 PM   #5
Daishi00
Member#: 78952
2005 WRX
CGM
rkkwan is spot on. The reason an STi will stop sooner than your car is because of the better tires. This is not the SOLE reason, but is the major reason why. If you're worried about fading then you can try changing out the brake fluid, getting a higher temperature liking pad or even going to a different rotor type like a DBA 5000 setup. After that it resist fading you'd want to start looking at some type of BBK, but then you're talking mad scratch.
Daishi00 is offline   Reply With Quote
Old 05-17-2006, 05:12 PM   #6
keaniegenie
Member#: 94494
2005 Element 92x
All good info,
Now...does anybody have the answer?
keaniegenie is offline   Reply With Quote
Old 05-17-2006, 05:22 PM   #7
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
There is no answer unless you want to refine your question.
One stop on equal tires and pad compounds.. no difference.
On the track with lots of heavy braking.. STi Brembos no contest.
brembo vs subaru 4 pot thisisthenewsic Brakes, Steering & Suspension 23 01-09-2008 05:03 AM
Rear Hubs & Brake FAQ; 1 pots, 2 pots subaru, 2 pots brembo swapstar Subaru Conversions 31 01-31-2006 11:30 PM
STI Brembos or Subaru 4 Pots? SeattleWRX North West Impreza Club Forum -- NWIC 12 11-01-2005 11:52 PM
Wanted: Subaru non-brembo 4-pot/2-pot calipers projectrally Private 'Wanted' Classifieds 4 04-28-2005 10:59 PM
STi Brembos vs. Subaru 4-pot projectrally Brakes, Steering & Suspension 35 04-27-2005 10:46 AM
