Old 10-10-2001, 11:44 AM   #1
MOD77
Member#: 11039
2002 OUTBACK SPORT
ASPEN WHITE
Default OBS Suspension Jarring
My 2002 Outback Sport is very Jarring when I hit bumps or uneven pavement.
Is that because of the "Heavy Duty" Suspension?
Is there anything that service can do to help with that?
Thanks, MOD7
MOD77 is offline   Reply With Quote
Old 10-10-2001, 06:10 PM   #2
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Check your tire pressure. I was thinking mine wasn't handling corners as well as my 2000 OBS, then realized the tires were overinflated. So I went with the numbers on the door frame, 32 front, 29 rear, and it handles like a piece of cake now.
I'd check that first. Also with the tires overinflated, I was hearing a squeak in the front right suspension. Went away after fixing the pressure.
subymamma is offline   Reply With Quote
Old 10-11-2001, 02:33 AM   #3
MOD77
Member#: 11039
2002 OUTBACK SPORT
ASPEN WHITE
Question obs JARRING
Thanks I will check pressure. I was not sure if it was the 16 inch tires or the "Heavy-Duty Suspension" that was causing the jarring.
Old 10-12-2001, 01:57 AM   #4
MOD77
Member#: 11039
2002 OUTBACK SPORT
ASPEN WHITE
Default Tire pressure was way too high!
Thanks SubyMamma,
I went to my service man and the tires were at 40! Way too high.
At your suggestion I told him 32 in front and 29 in back.
It did help a lot, but is it still a bit jarring over breaks in the pavement. My service man thinks it will settle/soften over time.
Thanks MOD77
OBS Suspension advice CR_TurboGuy Brakes, Steering & Suspension 10 01-24-2004 01:59 AM
2004 Impreza OBS Suspension Exacerbate Brakes, Steering & Suspension 8 12-19-2003 08:42 PM
('93-'01) OBS suspension ideas? Stickee Impreza Forum 14 06-03-2003 01:03 AM
OBS suspension options spt_impreza Canada Region Forum 44 02-11-2003 05:00 AM
Help! need MY'02 OBS suspension mods raptor1 Brakes, Steering & Suspension 4 03-17-2002 06:48 PM
