Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-17-2006, 01:03 PM   #1
mrwrx2002
Member#: 59085
World Rally Blue Pearl
Default CEL Fix
When I installed my downpipe, I installed a CEL fix so that my car will run. When I install the UTEC does this fix stay in the car, or does it have to be removed?
mrwrx2002 is offline   Reply With Quote
Old 05-17-2006, 10:30 PM   #2
mrwrx2002
Member#: 59085
anybody?
Old 05-18-2006, 12:03 AM   #3
Gethin
Member#: 2998
The downpipe CEL fix is for the rear o2. It's either an electronic fix (resistor and cap in the o2 cable itself) or a mechanical fix (plug bung extended to take o2 out of exhaust stream). Both types of CEL fixes can stay when you install the UTEC, you're only piggybacking onto your OEM ECU and you dont touch anything else (excluding the ABC if you use it, but that goes onto your stock BCS).
Gethin is offline   Reply With Quote
WTB: New APS servos for cel fix or other fix Ricowrx Private 'Wanted' Classifieds 0 04-12-2007 04:54 PM
I Need A Cel Fix/helix Fix. Where Can I Get One? skubydew16 Service & Maintenance 5 02-03-2007 08:41 PM
Mechanical CEL Fix...CEL is back after 6k miles baileypicks24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-30-2005 06:36 PM
Help! CEL with CEL fix electricpork Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-31-2004 04:56 PM
Has anyone installed ILP CEL fix...I'm still getting CEL Shaitiger Engine Management & Tuning 0 06-18-2003 03:24 PM
