Old 05-17-2006, 04:24 PM   #1
Wookie768
Member#: 90055
2005 WRX
Default VF series turbo rebuildable?
was looking into buying a vf22 (50k miles)
said that there is a little shaft play not much
i was gonna buy it , rebuild and pnp but he told me there not rebuildable from his knowledge
Wookie768 is offline   Reply With Quote
Old 05-17-2006, 04:25 PM   #2
hondaeater69
Member#: 60324
they are rebuildable. . problem is finding new parts to rebuild them with, i don't belive IHI sells kits of these sorts.
Old 05-17-2006, 04:27 PM   #3
steelythefez
Member#: 101545
1997 Legacy GT
Redder
rebuilds consist of a new chra... so you are looking at 400bux for that.
steelythefez is offline   Reply With Quote
Old 05-17-2006, 05:16 PM   #4
djviper
Member#: 107276
99 V.R.Special
WRC blue
http://www.owendevelopments.co.uk/index.asp
have a word with them mate, they build the IHI wrc turbos and sevice em so if they cant it cant be done
djviper is offline   Reply With Quote
Old 05-18-2006, 05:35 AM   #5
scoooby03
Member#: 110654
Not a good idea to rebuild turbos. Unless it is factory rebuilt.They are very precision components and will vary in nitty gritty specs. Better off buying a slighty used one. Good Luck!
scoooby03 is offline   Reply With Quote
Old 05-18-2006, 05:42 AM   #6
prometheum
Member#: 92003
04 bicycle!
isn't that the main part of the turbo?
prometheum is offline   Reply With Quote
Old 05-18-2006, 07:13 AM   #7
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Call Jerry at Deadbolt, they are away right now till the 23 for a show. He can do what you want. I believe he can turn it into a PE1820. But for what its worth he charges $45 to inspect them. Jerry has top notch customer service and is a down to earth guy. He will answer all your questions. web site is boostplanet.com. phone# 828-606-9104.
breathinez is offline   Reply With Quote
Old 05-18-2006, 08:36 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yeah, cuz nobody but the little elves who put them together in santa's secret workshop could ever hope to get it right.
Old 05-18-2006, 08:52 AM   #9
scooby24
Member#: 56414
2004 Forester XT 5MT
cost vs. benefit
Lots of good used ihi turbos out there. I don't suppose if there even IS a kit...that it would be what I would call a reasonable price.
scooby24 is offline   Reply With Quote
Old 05-18-2006, 09:45 AM   #10
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
Hey newbie. While I agree with you... it's prob best off to buy a slightly used one. Turbo's are very simple to rebuild. precision components ah maybe but putting one together isn't that hard at all. It can be done in less then 2 hours easy.
Bundyboyz is offline   Reply With Quote
Old 05-18-2006, 10:52 AM   #11
steelythefez
Member#: 101545
1997 Legacy GT
Redder
Yes thats the main part of it. IHI doesn't sell the bearing kits etc. I have two pe1820's that needed new bearings but the only option was a new CHRA. So basically you keep the housings and get a new center section. Jerry quoted a new vf22 chra at 400 bux. If you want to convert it to a pe1820 then it is another 300 bux on top of that for the compressor wheel and the machining necesarry to get it to fit in the housing. In short, if you are buying a IHI turbo thats on its way out consider the fact that when it goes all that you are left with is a compressor housing and turbine housing.
WTB: VF series turbo, big 16 or 18G turbo WRX_scott Private 'Wanted' Classifieds 2 08-20-2007 03:37 PM
Effect of turbo inlet hose on VF series turbo... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-27-2006 10:00 AM
VF series turbo size compared to Mitsubishi.. Jake Steed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-13-2002 11:50 PM
VF- series turbo specs ataac_flat04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-31-2002 04:07 PM
VF Series Turbos APS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 07-02-2002 11:21 AM
