Old 05-17-2006, 10:36 PM   #1
hokiewrx
Member#: 18505
2004 STi
Default stumble and then after or backfire - UPDATED HELP!
Hi I'm running Stage 2 (catless) + header + typhoon on my STi. I'm also running a UTEC that's been tuned by TurboXS. I've had something occur a couple of times that I'm trying to figure out if it's harmful and where to look.
What will happen is it seems like maybe around the crossover point all the sudden the car stumbles (almost like it's going to shut off) and then I get a big pop out of the exhaust and then I can continue along my merry way. I'm not getting any knock.
This has happened more when the car is warming up, but has happened when the car is perfectly warm too. It happens under lighter throttle and mid-range rpm's (I think?) It's definitely not a full throttle thing.
TIA.
hokiewrx is offline   Reply With Quote
Old 05-17-2006, 11:45 PM   #2
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
that's a utec feature
overdose is offline   Reply With Quote
Old 05-17-2006, 11:55 PM   #3
hokiewrx
Member#: 18505
2004 STi
uhh, how is a stumble and afterfire a feature persay? it's pretty violent, like i hit a brick wall for a second.
Old 05-18-2006, 12:12 AM   #4
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
cause utec sucks and nobody's ever REALLY been able to smooth the crossover, to some extent it's ALWAYS noticable
accessport ftw
Old 05-18-2006, 12:31 AM   #5
WR^2X
Member#: 37617
Riiiiiight. Cobb Fanboi.
WR^2X is offline   Reply With Quote
Old 05-18-2006, 12:44 AM   #6
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Originally Posted by WR^2X
Please... My crossover is much smoother than what he's describing.
This car has actually been tuned by TXS, or you're using a TXS OTS map?
probably so, but you can't say "100% seamless", i know you can't
Old 05-18-2006, 12:59 AM   #7
maestro
Member#: 53021
'04 Forester - sold
'72 Datsun 240Z
accessport ftw
I once had a UTEC tuned by TurboXS... same issue.
Now I have EcuTek.
maestro is offline   Reply With Quote
Old 05-18-2006, 07:19 AM   #8
hokiewrx
Member#: 18505
2004 STi
It's been tuned by TurboXS.
BTW overdose - I'm running firmware that has NO crossover issues, or hesitation. My car drives exactly like stock. This little fuel or whatever issue it is is my only issue.
Old 05-18-2006, 07:28 AM   #9
WR^2X
Member#: 37617
Really? Which firmware would that be?
Do some logging with logger #1 and post the results, then we can do a better job helping you.
Old 05-18-2006, 10:37 AM   #10
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
It's vaporware firmware, every firmware release since OLF was released "fixes crossover hesitation" doesn't it
Old 05-18-2006, 10:48 AM   #11
WR^2X
Member#: 37617
Old 05-18-2006, 11:17 AM   #12
Freon
Member#: 88322
2009 BMW 135i
In your timing table, put "ECU" into your 10% column from 0 to 3500 rpm. Seriously, try it.
Freon is offline   Reply With Quote
Old 05-18-2006, 12:09 PM   #13
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Your opinion of the UTEC has no place in this thread. hokiewrx, you might get better answers in Engine Management and Tuning.
sure it does, my point is it's never going to fully go away so while you may make it better, it's always going to be noticable or just as bad at certain psi vs. tps
Old 05-18-2006, 02:58 PM   #14
hokiewrx
Member#: 18505
2004 STi
Dude while I appreciate your input, seriously drop the UTEC bashing thing. Just because you had a bad experience doesn't mean we need to hear about it. I started the thread to seek legit help.
My maps are at http://1dot0.itsensellc.com/sti/06-05-12_utec/. I pretty much stick with map 2 which is the same as map 1 with the exception that it lowers the boost.
I'm running v1.4. You'll find the screenshot at that same link. It's unfortunately an unreleased firmware that you can only get directly from TXS. But, it did solve all those nasty crossover issues I was having with 1.1c. I think this version may have built on the version that is coming. Data logging I will try, but it's hard because it probably happens 1 out of 7 or 8 times I'm driving and it's a PIA to hook up the laptop everytime I go somewhere ;-)
DISCLAIMER - if you choose to run any of the maps I've linked in this post you do so AT YOUR OWN RISK. Don't come crying to me when you blow your motor up.
Freon - So let the ECU handle timing from 0-3500rpm in the 10% load column? You think that has something to do with it?
Thanks!!
Old 05-18-2006, 04:38 PM   #15
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
you can let ecu control it or try to "mimmick" what the ecu wants to run in those lower load zones so it's nice and smooth
Old 05-18-2006, 04:47 PM   #16
Freon
Member#: 88322
2009 BMW 135i
The problem is the 10% load column has to cover from who knows how much vacuum up to 1-2psi. The 20% column covers a very narrow range, just 1-2psi up to 3-5psi. Same is true for the remaining columns. So you cannot put a meaningful timing number in the 10% column like you can 20-100.
10% takes over as soon as TPS is met. It does NOT wait until you hit 0psi! That's why it transitions like crap. A good timing number for 10% load could be anywhere from +46 to +26 or so. But a good timing number for, say, 20% is probably a narrow range, say, +26 to +23, or whatever depending on the RPM, etc. Either way, the window of a good number is much narrower. Basically, you cannot mimmick the ECU in the 10% column since there is just too much variance in airflow to cover. You'll see the ECU running anywhere from +46 deg to about +26, since that is all the way from lots of vacuum to about 1-2psi.
Doing this got rid of over half the transition issues I ever had. I have no idea why the TXS base stage 1 and stage 2 maps do not do this right out of the box. It should be in the canned maps, IMNSHO.
Old 05-18-2006, 04:56 PM   #17
hokiewrx
Member#: 18505
2004 STi
Ok, so what is the worst case scenario? Obviously letting the ECU run timing as it see fits doesn't seem to really pose any big risk other than loss of low end power potentially?
Old 05-18-2006, 05:22 PM   #18
bboy
Member#: 56468
04 Improved STI
Dirty White
Exactly. How can timing be exactly the same for -520 mm all the way to 1 psi? Let the ECU mimic itself.
Old 05-18-2006, 06:51 PM   #19
hokiewrx
Member#: 18505
2004 STi
Is that 3500rpm inclusive or exclusive?
Old 05-18-2006, 06:54 PM   #20
WR^2X
Member#: 37617
Well I hope TXS releases this 1.4 firmware soon. We've been waiting for quite awhile.
Old 05-18-2006, 07:06 PM   #21
bboy
Member#: 56468
04 Improved STI
Dirty White
I'd try inclusive, but I'm just learning this UTEC stuff. Coming from a Hydra it's soooo convoluted.
Old 05-18-2006, 07:10 PM   #22
hokiewrx
Member#: 18505
2004 STi
Unfortunately the 1.4 firmware is a dead end release from what I understand. But TXS is cooking up something new and hot too so I think patience will reap huge rewards!
Old 05-19-2006, 10:47 AM   #23
hokiewrx
Member#: 18505
2004 STi
So far so good on the timing changes... actually, the car drives a lot better I must say!
Old 05-19-2006, 02:42 PM   #24
Freon
Member#: 88322
2009 BMW 135i
3500rpm is somewhat arbitrary. Use whatever works for you but I suggest trying around 3500, give or take.
Old 05-19-2006, 04:50 PM   #25
brutalsti
Member#: 103623
2005 STI
Silver, wingless
you did something dude... turbo xs would'nt have let that car go like that. my utec never does that.
brutalsti is offline   Reply With Quote
02 WRX starts then dies after a backfire bmv68128 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-21-2009 10:05 AM
02 WRX starts then dies after a backfire bmv68128 Service & Maintenance 0 04-20-2009 10:27 PM
Hydra first starts and then after. HOK Other Engine Management 12 11-18-2006 04:48 AM
take off stumble worse then hesitation Max Umbarger Service & Maintenance 12 12-31-2004 04:18 AM
Car stumbling and hesitating after dealer service. zuczek Canada Region Forum 21 09-01-2004 02:31 AM
