Old 05-18-2006, 09:54 AM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Sti long block with 02 WRX ecu
I have a built 2.5 short block and was looking to put some STi cams in my WRX heads. I have the opputunity to buy a complete set of STi heads and was wondering if they can be used with an 02 wrx ecu. I know the avcs will not wire up but will I be able to get the 02 cam sensor to fit? Will the 02 cam gears work? Also if I did eventually get a JDM 02 ecu that supported the avcs will I be able to make that work?
Any other issues I might have? I know the Sti oil pan is different than the WRX but is this more related to the suspension ?
LiquidForce is offline   Reply With Quote
Old 05-18-2006, 12:43 PM   #2
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Yeah the sensor will fit, you have to drill and tap the sti heads up front to make this work. Just check http://elementtuning.com/technical/ej25_install.htm for addition info.
Token-Negro is offline   Reply With Quote
Old 05-19-2006, 07:31 PM   #3
keaniegenie
Member#: 94494
2005 Element 92x
If you don't wire the AVCS, there won't be much a diff. WRX heads and USDM STI heads flow about the same. The two big diffs are AVCS and the cams. Since you have STI cams in your heads, don't bother unless you get a ECU to control AVCS.
keaniegenie is offline   Reply With Quote
Old 05-19-2006, 08:32 PM   #4
Starkiller
Member#: 82741
2007 350Z Silver
Does the later version of UTEC support AVCS?
Starkiller is offline   Reply With Quote
Old 05-19-2006, 08:39 PM   #5
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Neither Utec, AP, nor ECUTek will control AVCS. You'll need a Hydra or another form of standalone EM, or an ECU that supports AVCS, but beware of using a newer one than you car, as it will have other things programmed into it that can cause CELs.
wrxfactor is offline   Reply With Quote
Old 05-19-2006, 11:44 PM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
OMGHi2U well your incorrect
ecutek, actually has the cam advance maps, ie..avcs..
so double check...for those motors that come from the factoy
with avcs...
ecutek uses factory rom files as base maps...
Old 05-20-2006, 03:26 PM   #7
shouldaboughtanSTI
Member#: 100782
i also thought that if you get an Aussie,or japanese Utec..It will control AVCS..Jason
shouldaboughtanSTI is offline   Reply With Quote
Old 05-20-2006, 06:06 PM   #8
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Originally Posted by jaxscuby
well your incorrect
with avcs...
So you're telling me my 2002 WRX ECU will control AVCS on the EJ255 motor that I have swapped in there? I'll email my tuner because I don't believe that for a minute. Maybe if a 2002 WRX ECU was originally programmed for AVCS, but it's not.
Oh and BTW, it's you're
2.5 long block with 05 wrx ecu Paras99 Newbies & FAQs 3 11-13-2009 01:22 PM
Which EM for STi long block in 02 WRX? rjw5164 Open Source Reflashes 4 11-08-2009 08:00 PM
FS: 06' STi Long Block with Broken #4 Ring Land WRXPCT04 MAIC Private Classifieds 10 09-24-2009 06:19 PM
WTB long block for 02 wrx impreza resolver Private 'Wanted' Classifieds 3 08-31-2009 12:16 AM
2006 Sti long block with 32k miles FDrif73r Engine/Power/Exhaust 1 05-12-2009 01:00 PM
