Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-18-2006, 05:04 PM   #1
_sti_05
Member#: 72313
2005 STi
Default Stock Mode
Searched couldnt find anything, how do you go back to stock mode when you have a utec. getting rid of it and need to go back to stock mode, can i just remove it or is there something i need to switch.
Thanks!
_sti_05 is offline   Reply With Quote
Old 05-18-2006, 06:24 PM   #2
da n00b
Member#: 65951
02' e46 ///M3
Imola Red
On the back of the Utec or if you have the remote switch set it to 0 and then you could remove it.
da n00b is offline   Reply With Quote
Old 05-19-2006, 02:18 AM   #3
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Are you removing the utec completly?
The utec will just unplug from the stock ecu.
If you want stock mode while the utec is installed, put the switch on "0"
Smoby is offline   Reply With Quote
Old 05-19-2006, 02:50 AM   #4
xolosis
Member#: 103373
Exactly what they said. If you were using the 'Remote Switch' the Map Selector Switch should have been on 0 anyway. If you don't then turn the switch on the UTEC to the 0 position.
If you remove the UTEC the factory harness plugs straight back in to the stock ECU hence stock mode.
xolosis is offline   Reply With Quote
Old 05-19-2006, 11:23 AM   #5
_sti_05
Member#: 72313
2005 STi
ok got it thanks!
Stock mode with TBE? Rugy AccessPort 2 01-21-2008 03:32 PM
Is UTEC controlling my boost even in stock mode? Zumble UTEC 7 03-01-2007 01:59 PM
Stock Mode with larger injectors? Zumble UTEC 4 02-09-2007 04:22 PM
Change Stock mode. TheAntiRice Engine Management & Tuning 4 09-11-2004 10:10 PM
MINT '03 sonic yellow WRX $19,500 in stock mode 8k miles Stang2WRX Private Vehicle 'For Sale' Classifieds 36 05-03-2004 11:47 PM
Message Board Statistics All times are GMT -4. The time now is 02:46 AM.
