Old 05-18-2006, 05:13 PM   #1
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Default Problems with brakes, need some help.
I am wondering if anyone has had a similiar problem or knows of what is going on.
I just recently installed new pads front and rear and replaced the rotors front and rear also. The pads are axxis ultimate.
I broke the pads and rotors in and everything felt fine doing this. After break in I got on them pretty hard and they worked really well. The pedal had a nice firm feel to it when pressed, everything sounded good and felt smooth.
I drove the car for a couple days and parked it. I came back a couple days later and my brakes are acting funky on me. When slowing down the pedal will just get mushy after a couple of seconds on the brakes. It kind of feels like ABS is trying to kick in. It doesnt matter if I am barely applying pressure and slowly slowing down or if I am stopping fast.
I checked the fluid and it is above full barely. I didnt have to push the pistons back in for the front pads to fit but I did have to push the back piston in to fit the new rear pads.
Does this sound like air in the system? To much fluid? Something wierd with abs?
I did add a little bit of synthetic brake fluid a little while back because it was low and it was the only thing around. I am not sure if this could mess something up mixing with the other fluid. I didnt think it would.
Sorry for the long post. Any thoughts?
Smoby is offline   Reply With Quote
Old 05-18-2006, 07:38 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
When you changed the pads, did you bleed the brake system?
Did you bleed the system properly, following the factory procedure?
Passenger's Side Front
Driver's Side Rear
Driver's Side Front
Passenger's Side Rear
If not, probably the problem.
If yes, could still have air in the lines. Bleed/re-bleed the brake system and see if this solves the problem.
Have you checked to see if you are leaking any brake fluid @ the bleeders, master cylinder, etc.?
Samurai Jack is offline   Reply With Quote
Old 05-18-2006, 07:43 PM   #3
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
sounds like air in the lines..
Kenji815 is offline   Reply With Quote
Old 05-19-2006, 01:18 AM   #4
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Ill try bleeding the system in that order and see if it helps.
Thanks
Brakes, need some help tjommi Brakes, Steering & Suspension 3 02-26-2009 10:29 AM
problem with 4eat. need your help! shootsbrah Transmission (AT/MT) & Driveline 4 09-04-2007 08:28 PM
hey homeowners, i have problem with AC, need some debugging koloa Off-Topic 12 06-25-2006 09:28 AM
problem with utec need your help dlowman UTEC 6 04-04-2006 08:18 PM
big problems and i need some help fast! kessler89 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-01-2005 03:59 PM
