Old 05-19-2006, 12:25 AM   #1
vortectoy
Member#: 66510
2003 wrx 18g
JBP
Default Data logging gurus, need your help reading log.
After a crappy night at the track i felt the need to see whats going on. So i data logged a run in 4th gear (This is 4th gear with a US STI transmission). Can anyone tell me what is going on and why I am not hitting full boost. Test was with 71 degree outside temp.
I have an 03 WRX with following mods.
cobb accessport w/OTS 2.5 map
VF34
STI pinks
STI tmic
gutted up/down pipe
STI turboback
US STI 6spd trans
K&N filter
snorkus removed
Engine speed (rpm)
Ignition Timing (btdc)
Knock correction (btdc)
Boost (psi)
Wastegate duty cycle (%)
Air fuel (afr)
Advanced multiplier
Injector duty cycle (%)
Code:
3371	26	9	5.078	44.31	14.47	15	18.7
3374	23	7	5.659	49.41	14.93	15	18.71
3418	21	7	3.918	18.43	14.81	15	18.23
3400	32	0	-3.773	0	11.6	15	6.53
3414	31	0	-6.239	0	14.93	15	5.1
3412	24	0	-7.4	0	18.38	15	5.1
3406	17	0	-8.271	0	18.26	15	0
3485	2	-1	-2.612	18.43	25.5	15	11.89
3374	28	6	1.306	23.53	17.57	15	15.83
3488	30	8	2.612	28.63	12.86	15	20.84
3529	27	9	3.627	33.73	11.94	15	21.83
3488	24	7	4.643	38.43	11.94	15	23.07
3521	21	7	5.514	43.53	11.83	15	24.79
3573	21	7	6.675	48.63	11.71	15	26.68
3618	20	8	7.69	53.73	12.06	15	28.56
3642	18	8	9.286	61.18	11.48	15	31.86
3691	17	8	10.592	65.1	11.37	15	34.64
3776	16	7	11.608	65.1	11.25	15	37.86
3807	15	7	12.624	65.1	11.25	15	38.98
3882	14	7	13.204	65.1	11.25	15	40.58
3910	14	7	13.494	65.1	11.25	15	40.87
3983	14	7	13.639	65.1	11.25	15	42.48
4041	14	7	13.784	65.1	11.25	15	43.1
4094	15	7	13.929	65.1	11.25	15	43.67
4116	15	7	13.929	65.1	11.25	15	44.78
4204	16	5	13.929	65.1	11.25	15	45.74
4254	12	5	14.075	65.1	11.25	15	47.19
4269	13	5	14.075	65.1	11.25	15	48.26
4350	13	5	14.22	65.1	11.25	15	50.11
4386	13	5	14.075	65.1	11.25	15	50.52
4491	13	6	14.22	65.1	11.25	15	52.69
4488	13	6	14.365	65.1	11.25	15	52.66
4554	13	6	14.365	65.1	11.25	15	52.46
4638	14	6	14.365	65.1	11.25	15	54.42
4690	14	7	14.51	65.1	11.25	15	55.03
4765	15	7	14.51	65.1	11.25	15	54.89
4786	16	7	14.51	65.1	11.25	15	55.13
4879	16	7	14.51	65.1	11.25	15	56.21
4915	16	7	14.655	65.1	11.25	15	57.66
4987	15	6	14.8	64.71	11.25	15	58.51
5037	13	4	14.8	64.31	11.25	15	59.1
5057	13	3	14.945	63.53	11.25	15	60.41
5147	12	2	14.8	63.53	11.25	15	61.49
5133	13	1	14.8	63.14	11.25	15	61.33
5223	13	1	14.8	62.75	11.25	15	62.39
5274	13	1	14.655	62.75	11.25	15	64.13
5357	13	2	14.655	62.75	11.25	15	65.14
5338	13	2	14.8	62.75	11.25	15	64.91
5415	14	2	14.655	62.75	11.25	15	65.85
5482	14	2	14.655	62.75	11.25	15	66.66
5506	14	3	14.655	62.75	11.25	15	68.13
5560	15	3	14.51	62.75	11.25	15	68.79
5622	15	3	14.51	62.35	11.25	15	69.56
5665	15	2	14.51	61.96	11.25	15	70.09
5769	16	3	14.51	61.57	11.25	15	71.38
5756	16	3	14.51	61.18	11.25	15	71.22
5823	15	2	14.365	61.18	11.25	15	72.05
5864	16	2	14.365	60.39	11.25	15	72.55
5896	15	2	14.365	60	11.25	15	72.95
5995	16	2	14.22	60	11.25	15	74.18
5986	16	2	14.22	59.22	11.25	15	74.06
6019	16	2	14.075	58.82	11.25	15	74.48
6078	16	2	14.075	58.43	11.25	15	73.9
6173	16	2	13.929	58.43	11.25	15	75.06
6158	17	2	13.784	58.04	11.25	15	74.88
6198	17	2	13.784	57.65	11.25	15	74.05
6308	19	3	13.639	57.25	11.25	15	75.36
6345	19	3	13.639	56.86	11.25	15	74.45
6388	19	3	13.639	56.47	11.25	15	74.96
6350	19	3	13.494	56.47	11.25	15	74.51
6449	20	3	13.639	56.08	11.25	15	75.67
6488	20	3	13.639	55.69	11.25	15	74.74
6527	20	3	13.494	55.29	11.25	15	75.19
6556	21	3	13.349	54.51	11.25	15	74.12
6585	21	3	13.349	54.12	11.25	15	74.45
6661	21	3	13.349	54.12	11.25	15	75.31
6702	21	3	13.349	53.73	11.25	15	75.78
6745	22	3	13.204	53.73	11.25	15	74.82
6781	22	3	13.204	52.94	11.25	15	75.22
6781	23	3	13.059	52.94	11.25	15	75.22
6781	23	3	13.204	52.55	11.25	15	73.78
6862	23	3	13.204	52.55	11.25	15	74.65
6843	23	3	13.059	52.55	11.25	15	72.99
6931	23	3	13.059	52.55	11.25	15	73.93
6874	41	0	-0.145	0	11.25	15	32.26
6931	12	0	-8.706	0	12.86	15	0
6579	12	0	-9.431	0	25.5	15	0
6083	12	0	-9.867	0	24.81	15	0
5850	12	0	-10.012	0	24	15	0
vortectoy is offline   Reply With Quote
Old 05-19-2006, 12:56 AM   #2
-Kevlar-
Member#: 82378
im kinda a n00b at this too, but it looks like youre starting to knock around 5k....
-Kevlar- is offline   Reply With Quote
Old 05-19-2006, 08:33 AM   #3
crazymikie
Member#: 56321
2006 Honda El Camino
Green
What do your boost targets and wastegate duty cycle targets look like the 100% columns? Your wastegate duty cycles are increasing towards redline as your boost is falling off. There could be a couple of reasons for this. I'm curious to see what your map looks like first.
Also, your car appears to be pulling timing in a few places (at 4200 rpm and then at 5000 as wrxblubayou said). It would be good to smooth out your timing curve a bit so that it's non-decreasing once you hit peak load.
Are you running on 91 octane gas?
Thanks,
Mike
crazymikie is offline   Reply With Quote
Old 05-19-2006, 06:25 PM   #4
vortectoy
Member#: 66510
2003 wrx 18g
JBP
Im not sure what you mean. As for a map....I just have the off the shelf cobb vf34 91 octane map. The only way to smooth out the ignition curve is to have i protuned right? I am running 92 octane gas.
Old 05-21-2006, 04:19 PM   #5
vortectoy
Member#: 66510
2003 wrx 18g
JBP
anyone else have some info??
Old 05-22-2006, 01:19 AM   #6
benw
Member#: 103320
1998 swapped
Forester L
here's a side by side comparison with mine. Pull done in 4th gear, 91 oct. map. Same exact mods except Perrin downpipe and stock WRX transmission:
Code:
Engine Speed (RPM)
Knock Correction (BTDC)
Fuel Injector #1 Duty (%)
Primary Wastegate Duty Cycle (%)
Air/Fuel Sensor #1 (AFR)
Advance Multiplier (020124) ()
Manifold Relative Pressure (Corrected) (BAR)
Ignition Timing (BTDC)
Manifold Relative Pressure (Corrected) (PSI)
3139	9	23.44	50.2	11.6	16	0.47	20	6.91
3156	9	24.91	57.65	11.6	16	0.57	20	8.38
3170	10	26.37	62.75	11.37	16	0.63	20	9.26
3193	10	28.61	67.45	11.37	16	0.7	19	10.29
3215	9	30.17	67.45	11.25	16	0.81	18	11.91
3264	9	34.11	67.45	11.25	16	0.87	16	12.79
3297	9	35.87	67.45	11.25	16	0.94	15	13.82
3299	8	36.6	67.45	11.25	16	0.99	14	14.55
3326	8	37.6	67.45	11.25	16	1.04	13	15.29
3371	8	38.83	67.45	11.25	16	1.06	13	15.58
3409	8	39.27	67.45	11.25	16	1.07	12	15.73
3417	7	40.09	67.45	11.25	16	1.08	12	15.88
3459	7	40.59	67.45	11.25	16	1.08	12	15.88
3493	7	41.73	67.45	11.25	16	1.09	12	16.02
3544	7	42.34	67.45	11.25	16	1.1	12	16.17
3568	7	43.38	67.45	11.25	16	1.11	11	16.32
3573	7	43.45	67.45	11.25	16	1.11	11	16.32
3595	7	44.49	67.45	11.25	16	1.12	12	16.46
3639	7	45.02	67.45	11.25	16	1.13	12	16.61
3662	7	46.09	67.45	11.25	16	1.13	12	16.61
3696	7	46.52	67.45	11.25	16	1.14	12	16.76
3713	7	46.73	67.45	11.25	16	1.15	12	16.91
3769	7	48.24	67.45	11.25	16	1.15	12	16.91
3799	7	48.63	67.45	11.25	16	1.16	13	17.05
3821	7	48.09	67.45	11.25	16	1.16	13	17.05
3872	7	48.73	67.45	11.25	16	1.15	13	16.91
3890	7	48.96	67.45	11.25	16	1.15	13	16.91
3947	7	48.84	67.45	11.25	16	1.15	14	16.91
3972	7	50	67.45	11.25	16	1.15	14	16.91
3951	5	49.73	67.45	11.25	16	1.16	12	17.05
3977	5	50.9	67.45	11.25	16	1.16	12	17.05
4045	5	52.64	67.45	11.25	16	1.17	12	17.2
4058	5	52.81	67.45	11.25	16	1.17	12	17.2
4076	5	53.04	67.45	11.25	16	1.17	12	17.2
4096	5	53.3	67.45	11.25	16	1.17	12	17.2
4216	5	55.76	67.45	11.25	16	1.17	12	17.2
4235	5	56.01	67.45	11.25	16	1.17	12	17.2
4216	5	55.76	67.45	11.25	16	1.16	12	17.05
4269	5	56.46	67.45	11.25	16	1.17	12	17.2
4296	5	56.82	67.45	11.25	16	1.17	12	17.2
4325	5	58.13	67.45	11.25	16	1.17	12	17.2
4376	6	59.74	67.45	11.25	16	1.18	13	17.35
4414	7	60.27	67.45	11.25	16	1.17	14	17.2
4412	7	61.17	67.45	11.25	16	1.17	14	17.2
4467	7	60.99	67.45	11.25	16	1.18	14	17.35
4496	7	62.35	67.45	11.25	16	1.18	14	17.35
4507	7	62.5	67.45	11.25	16	1.18	14	17.35
4559	7	62.25	67.45	11.25	16	1.19	14	17.49
4568	8	63.34	67.45	11.25	16	1.19	14	17.49
4624	7	64.12	67.45	11.25	16	1.19	15	17.49
4638	8	63.32	67.45	11.25	16	1.2	15	17.64
4653	8	63.52	67.45	11.25	16	1.2	15	17.64
4720	8	64.44	67.45	11.25	16	1.2	15	17.64
4729	8	64.56	67.45	11.25	16	1.2	15	17.64
4756	8	64.93	67.45	11.25	16	1.21	16	17.8
4774	8	65.18	67.45	11.25	16	1.2	16	17.64
4814	9	65.72	67.45	11.25	16	1.2	17	17.64
4845	7	66.15	67.45	11.25	16	1.21	15	17.8
4861	7	66.36	67.06	11.25	16	1.2	16	17.64
4876	7	67.62	67.06	11.25	16	1.2	15	17.64
4944	7	67.5	66.67	11.25	16	1.21	15	17.8
4960	7	67.72	66.67	11.25	16	1.2	15	17.64
4980	7	67.99	66.67	11.25	16	1.2	16	17.64
4967	6	67.81	66.27	11.25	16	1.2	16	17.64
4996	6	68.22	65.88	11.25	16	1.19	16	17.49
5067	6	69.18	65.88	11.25	16	1.19	16	17.49
5092	6	69.52	65.49	11.25	16	1.18	16	17.35
5088	6	69.47	65.49	11.25	16	1.18	16	17.35
5126	6	69.99	65.1	11.25	16	1.18	17	17.35
5162	6	70.47	65.1	11.25	16	1.17	17	17.2
5187	6	70.81	64.71	11.25	16	1.17	17	17.2
5201	6	71.01	64.71	11.25	16	1.16	17	17.05
5274	6	72.01	64.71	11.25	16	1.16	17	17.05
5308	7	72.47	64.71	11.25	16	1.17	18	17.2
5319	7	72.62	64.71	11.25	16	1.16	18	17.05
5319	7	72.62	64.71	11.25	16	1.17	18	17.2
5369	5	74.44	64.71	11.25	16	1.16	16	17.05
5403	5	74.93	64.71	11.25	16	1.17	16	17.2
5399	5	74.87	64.71	11.25	16	1.17	17	17.2
5450	5	75.58	64.71	11.25	16	1.17	17	17.2
5446	6	75.52	64.71	11.25	16	1.17	17	17.2
5490	6	77.3	64.71	11.25	16	1.17	17	17.2
5523	6	77.76	64.71	11.25	16	1.18	17	17.35
5568	6	78.39	64.71	11.25	16	1.17	17	17.2
5535	6	77.93	64.71	11.25	16	1.17	17	17.2
5614	6	79.04	64.31	11.25	16	1.17	18	17.2
5626	6	79.22	64.31	11.25	16	1.17	18	17.2
5669	6	79.82	63.92	11.25	16	1.17	17	17.2
5725	6	80.61	63.53	11.25	16	1.16	17	17.05
5708	6	80.36	63.14	11.25	16	1.17	18	17.2
5708	6	80.36	63.14	11.25	16	1.16	18	17.05
5756	6	81.04	62.75	11.25	16	1.15	18	16.91
5760	6	79.88	62.35	11.25	16	1.15	17	16.91
5837	5	82.18	62.35	11.25	16	1.14	18	16.76
5864	6	82.56	62.35	11.25	16	1.15	18	16.91
5827	6	80.8	61.57	11.25	16	1.15	19	16.91
5896	6	81.76	61.57	11.25	16	1.14	19	16.76
5910	6	81.95	61.18	11.25	16	1.14	19	16.76
5896	6	83.02	61.18	11.25	16	1.13	19	16.61
5929	6	82.21	60.39	11.25	16	1.14	19	16.76
5976	6	82.86	60.39	11.25	16	1.13	19	16.61
5943	6	82.41	60.39	11.25	16	1.12	19	16.46
5976	6	82.86	59.61	11.25	16	1.12	19	16.46
6029	6	83.6	59.61	11.25	16	1.12	19	16.46
6058	6	84	58.82	11.25	16	1.11	19	16.32
6029	6	83.6	58.43	11.25	16	1.12	19	16.46
6043	6	83.8	57.65	11.25	16	1.11	19	16.32
6102	6	84.62	57.65	11.25	16	1.11	20	16.32
6112	6	83.45	57.65	11.25	16	1.11	20	16.32
6158	6	84.07	57.25	11.25	16	1.1	20	16.17
6122	6	83.59	57.25	11.25	16	1.09	20	16.02
6117	6	83.52	56.86	11.25	16	1.1	20	16.17
6193	6	84.56	56.08	11.25	16	1.1	23	16.17
6173	6	84.28	55.69	11.25	16	1.09	20	16.02
6224	6	84.98	55.29	11.25	16	1.09	23	16.02
benw is offline   Reply With Quote
Xbox360 Gurus! Need your help/input! ITSME4G63 Off-Topic 5 11-24-2006 01:54 AM
OT IT gurus - need your help Leadfoot77 Off-Topic 14 11-11-2005 06:17 PM
Insurance agents/gurus, need your help. aod Off-Topic 16 07-20-2005 12:58 PM
SQL gurus, need your help! Alpine Off-Topic 44 02-16-2005 10:29 PM
IT and or SCSI gurus need your help ChosenWon Off-Topic 7 11-07-2003 12:36 PM
