Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-19-2006, 03:21 AM   #1
Inprogress
Member#: 65166
2008 EVO X
Default Already have ECUTEK, thinking about adding UTEC...
I've got a "tuned" ecutek reflash and was recently noticing some high EGT's and some jerking/hesitating in the lower rpms. I was considering tossing on the UTEC and tuning it with the Ecutek reflash. How would this work? Can I just hook up the UTEC and take it to the dyno and start making adjustments?
Would the current ecutek values be the 0 values on the utec?
I wouldn't really mess with anything besides the fuel and timing right or is there more with this combo?
Please do chime in.
Inprogress is offline   Reply With Quote
Old 05-19-2006, 09:32 PM   #2
xolosis
Member#: 103373
I running this exact setup, EcuTeK Custom Tune TEK3 and UTEC over the top. Didn't have to do anything special and just worked first time.
0 values or -100/ECU in UTEC means the ECU has control hence your EcuTeK Tune.
You can ajust Fuel, Timing and Boost plus theres ther feature like launch control, spare solenoid for water spary etc.
Great combo...
xolosis is offline   Reply With Quote
vf34 @ 20psi - thinking about adding Aquamist and pushing 24psi MicahMicahMicah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-27-2008 05:05 PM
Already Have Ecutek, thinking about adding UTEC... Inprogress Engine Management & Tuning 7 05-19-2006 04:37 PM
Was thinking about adding a 06STi Off-Topic 17 10-18-2005 07:52 AM
Thinking about adding a turbo and some other stuff... finnRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-24-2002 11:20 AM
Thinking about adding NOx. Just how strong is our drivetrain? tmat3 Transmission (AT/MT) & Driveline 0 08-08-2002 02:08 PM
