Old 05-19-2006, 11:16 AM   #1
runvusofme
Member#: 73942
2004 WRX STi JBP
Back to mostly stock...
Question OEM Fog Light Install Help for MY04 STi
So I bought some OEM WRX fog lights from a fellow NASIOC member and I have some questions on the install. So far I installed the fogs and connected the already existing wire harnesses behind my STi covers. Next I took the switch and plugged it into a wire harness next to my intercooler spayer harness. I assumed this was the pre-wired harness for the fogs since it was just sitting behind the dash and fits perfect. When I push the button, the light on the button comes on but the fog lights don't come on.
Did I miss something, ie relay, wrong wiring ??
Thanks guys!!
Justin
runvusofme is offline   Reply With Quote
Old 05-19-2006, 11:47 AM   #2
dbarnblatt
Member#: 7993
1997 SVX LSi
Red
Make sure your headlights are on...
dbarnblatt is offline   Reply With Quote
Old 05-19-2006, 12:17 PM   #3
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
You will also require the relay. The switch is getting power (evident by the green light on the button), but all the switch does is trigger a relay to turn on the fogs. No relay, no fogs.
...and, as almost all of us know, the light on the switch will not come on unless the headlights are turned on.....
jac04 is offline   Reply With Quote
Old 05-19-2006, 12:21 PM   #4
runvusofme
Member#: 73942
2004 WRX STi JBP
I figured I needed a relay. So can I get this relay at any autoparts store ie Advanace, NAPA?? Where do I plug in the relay??
Old 05-19-2006, 12:22 PM   #5
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
yeah the relay is all you'll need. give your local dealer a call to see if they can help source one.
Bishop is offline   Reply With Quote
Old 05-19-2006, 12:26 PM   #6
runvusofme
Member#: 73942
2004 WRX STi JBP
I don't have a local dealer. It's sucks when its time to fix something but good because I'm the only STi around here!!
Does the relay install under the dash or engine bay?
Old 05-19-2006, 12:28 PM   #7
dbarnblatt
Member#: 7993
1997 SVX LSi
Red
Doh!
Old 05-19-2006, 12:42 PM   #8
Bishop
Member#: 59993
Ass, grass or cash
under the dash behind the coin holder.
try givin jaime a call at www.subarugenuineparts.com or ferdie at http://www.southcoastperformance.com/. hopefully they can help.
Old 05-19-2006, 01:49 PM   #9
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Silver w/ JDM Roof Vent
Disregard this post, because I forgot to read. sorry!
Yesitsdrew5310 is offline   Reply With Quote
Old 05-19-2006, 06:00 PM   #10
runvusofme
Member#: 73942
2004 WRX STi JBP
Two Qs:
1) Will any Subaru Relay same size/capicity work? (ie 02 Fog light relay)
2) Which relay spot under the dash is it? I see 5 relay connect with 3 out of the 5 filled.
Thanks
Old 05-19-2006, 06:43 PM   #11
Bishop
Member#: 59993
Ass, grass or cash
sorry but these are the only pics of the relay i had. i sold it to a member here. it came w/my jdm fogs. i'll shot him a pm. we plugged the relay in when we met up for the sale. we reference my panel to his sti panel and jus plugged it where the relay was on mine. sorry if that sounds confusing.
Old 05-19-2006, 08:42 PM   #12
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
^^ Thats the switch, not the relay.
The relay is a small black square and has I believe 5 flat pins coming out of it. You need a Subaru Relay, I don't know what part #. I would call subaru find out the part # and then order it here: https://www.subarugenuineparts.com/oe_parts_cat.html
Old 05-19-2006, 08:54 PM   #13
Zalthras
Member#: 102022
2006 wrb WRX
1987 panda FX16
The relay is to the right of the switch in the picture, you have to scroll the window to the right to see it =D.
Zalthras is offline   Reply With Quote
Old 05-19-2006, 09:00 PM   #14
Zalthras
Member#: 102022
2006 wrb WRX
1987 panda FX16
Two Qs:
Thanks
In MY06 WRX, the front foglight relay is the 3rd one from the bottom, and there are 6 total relay slots (top two are blank in the sedan). You can probably figure out which one by locating a green/red, red/blue, white/black & black/white wires behind it.
Old 05-19-2006, 09:03 PM   #15
runvusofme
Member#: 73942
2004 WRX STi JBP
I found it. I had a friend pull his out since he no longer has fogs and it worked in mine. thanks for everybodies help!!!
Old 05-19-2006, 11:01 PM   #16
Bishop
Member#: 59993
Ass, grass or cash
lovely!! anytime mang. glad i could help.
Fog light install help CorbanDallas North West Impreza Club Forum -- NWIC 6 03-14-2010 03:40 AM
02-03 OEM fog lights / 02-03 WRX STI fog light covers OEM Subaru 2.5_IMP Exterior/Styling 11 06-17-2008 05:15 PM
OEM Fog Light Install thugzlife Electrical & Lighting 1 04-07-2008 03:02 AM
OEM fog lights/Cover..06 impreza wrx sti subaru222 Exterior/Styling 6 10-27-2006 04:19 AM
OEM Fog light (driver's side) for sale skycruise Private 'For Sale' Classifieds 6 04-29-2004 10:18 PM
