Old 05-19-2006, 02:50 PM   #1
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Default Crowfoot + torque wrench = adjust torque?
Question...
When using a crowfoot wrench attachment with a torque wrench, should you adjust the torque settings higher/lower? Or is the difference negligible?
My educated guess would be to lower the number a bit because of the slightly longer lever arm...
[i ask because i'll be using it on very torque sensitive parts, flare nuts on an aluminum caliper]
Old 05-19-2006, 03:10 PM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
dont bother using it. if its a flare nut they dont need it. jsut tighten untill they are tight. Dont monkey it too much
sidewayz is offline   Reply With Quote
Old 05-19-2006, 05:30 PM   #3
sprior
Member#: 114312
2005 sti
wrxblue
in theory, it's ok to use a crowsfoot with a torque wrench. Think of it as a couple. The torque on the bolt exerted by the crowsfoot must be the same as the torque on the crowsfoot exerted by the wrench since in the end there is no movement. There are some losses due to alignment accuracy dropping off, but it's a small difference.
sprior is offline   Reply With Quote
Old 05-19-2006, 06:38 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 05-19-2006, 07:50 PM   #5
Psydotek
Member#: 44168
2003 Yellow WRX
Originally Posted by Uncle Scotty
Nice pdf. Thanks!
[for those of you who didn't read it, it said no correction required for a standard crowfoot attachment.]
Old 05-19-2006, 09:17 PM   #6
vorpalbunny
Member#: 98999
'01 Outback
If you are reeeeaaaalllly worried, just have the dogbone or crowsfoot 90 degrees from the wrench. (wrench perpindicular from crowsfoot--clear as mud).
vorpalbunny is offline   Reply With Quote
Old 05-21-2006, 01:13 PM   #7
ICanRunLikeanSTI
Member#: 84729
05 WRX STI
Default there is an equation for this
there is an equation for this... i forgot what it is but i know there is only... you only need it it you are extending the torque wrench. you dont need it if you are using the torque wrench and the crowsfoot at a 90 degree angle. the only reason i know this is because i am a helicopter crew chief for the US Air Force. let me know if you still need help. i can find out the equation for you if you still need it.
ICanRunLikeanSTI is offline   Reply With Quote
Old 05-21-2006, 05:54 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 05-21-2006, 07:19 PM   #9
Psydotek
Member#: 44168
2003 Yellow WRX
Bah, when it came down to it, the crowfoot didn't even fit on the flare nut. The caliper body was getting in the way. Just had to use a plain flare nut wrench and go by feel. Here's to hoping there's no leaks.
Old 02-04-2011, 04:07 PM   #10
DonWryBoutIt
Member#: 268034
http://www.finishing.com/118/94_crows_foot_torque.shtml
I wrote up a post on this website that details the correction when using a crows foot. Right now it is the really long last post.
Cliff notes version... use the following equation.
Wrench torque = Torque Spec * (Wrench length / (Wrench length + Crows foot extension length))
*Torque Spec is the torque you are trying to achieve. Wrench torque is what you should set the torque wrench at. Crows foot extension is the length b/w the center of the torque wrench's drive and the center of where the nut/bolt will be in the crows foot.
DonWryBoutIt is offline   Reply With Quote
Old 02-04-2011, 04:13 PM   #11
rexspeedworthy
Member#: 26965
2013 XV crosstrek
Dude's been waiting five years to fix his car.
rexspeedworthy is offline   Reply With Quote
Old 02-05-2011, 02:33 AM   #12
Psydotek
Member#: 44168
2003 Yellow WRX
Holy crzapples...
Well, um, no leaks yet.
HELP: Need to borrow torque wrench that can torque up to 181lb/ft psyber_0ptix Mid Atlantic Impreza Club -- MAIC 11 01-20-2006 02:42 PM
Using gear wrench in conjunction w/ torque wrench for top strut nut BIGSKYWRX Brakes, Steering & Suspension 10 01-07-2005 08:44 AM
Ok to use torque wrench as main lugnut wrench? BurntJamb Tire & Wheel 15 07-02-2004 08:29 PM
('93-'01) gahhh...need help w/torque wrench RigdenZW Impreza Forum 11 05-15-2001 05:56 PM
Sorta OT: Need to buy torque wrench, recomendations? HomerJay General Forum Archive 10 11-13-2000 07:47 PM
