Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-19-2006, 10:54 PM   #1
SentinelSison
Member#: 112727
Unhappy 2nd Knock Sensor Location, 2nd Knock Sensor Locatoin!
Yes that was said twice. I'm trying to install a bosch knock sensor that came with the tuner pro, but no-one has come up with any pix, or anything that makes sense thus far. Some of you have said that it can be installed on a corresponding location to the stock sensor, but unless you have gone out to the hardware store and bought some adapters or something, you are b-s-ing, cause the one that I just bought will not directly hook up to any one of these locations. This is a simple install, I know, but since the instructions are as everyone has said, VAGUE, I am left with little options but to ask you guys who know much more. So please if anyone has a good write-up of the complete turbo xs tuner pro install, or even just some pix of an install on an 02 wrx, by all means posts them. It will be well appreciated. NASIOC rules!
SentinelSison is offline   Reply With Quote
Old 05-19-2006, 10:55 PM   #2
SentinelSison
Member#: 112727
should have spell checked that stuff, sometimes my keystroke gets a little ahead of me when I'm frustrated. Sorry guys!
Old 05-21-2006, 10:16 AM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Yo... The Bosch sensor is typically mounted right behind the existing stock sensor. Remove your TMIC, to the drivers side of the throttle body is the stock knock sensor. Immediately behind it and to the drivers-side a little, the block will rise with a nice flat solid surface with a bolt hole. Mount in that location using the supplied bolt which comes with it.
Good Luck...
xcntrk75 is offline   Reply With Quote
Old 05-24-2006, 11:06 PM   #4
SentinelSison
Member#: 112727
Yea thats the same thing txs said, I had to run out to get a bolt though, cause the tuner didn't come with it.
'98 2.5RS knock sensor location? hossak8 Normally Aspirated Powertrain 3 06-28-2004 11:36 PM
2001 outback knock sensor location quimbo Engine Management & Tuning 2 06-24-2004 07:36 AM
96 Legacy Outback Knock Sensor location Geoffman72 Service & Maintenance 3 05-25-2004 01:56 PM
Sti - Knock Sensor location dstarcke Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-21-2004 09:44 PM
J&S knock sensor location lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-15-2003 01:09 AM
