Old 05-20-2006, 05:19 PM   #1
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Default What seal is this? (w/ pics)
Well, this oil leak has been getting on my nerves for a few weeks now. It burns off oil everytime I shut the car down, so I'm ashamed of my "smelly car" everytime I park. I took these pictures to show where the leaking is coming from. I'm running Castrol GTX high mileage 10w-40, and yes, I know, the fram is coming off very soon. Up near my college, there are no stores that sell purolator filters.
It looks like, from the pictures, some of those lower bolts connecting the two halves are not tightened all the way, I'm going to check that later today. But what seal is this, and how hard is it to replace? Things I'd have to look out for, things I can fix while I'm in there, etc... If I have to pull the crank pulley when I'm in there, I may just replace it with a perrin lightweight....
Plays_With_toys is offline   Reply With Quote
Old 05-20-2006, 05:21 PM   #2
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
your oil pump seal is leaking. itss behind the water pump. take it to a shop
Russell Rogers is offline   Reply With Quote
Old 05-20-2006, 05:26 PM   #3
2.5WagonGuy
Member#: 109513
looks like the valve cover gasket to me, my car was doing the same thing
2.5WagonGuy is offline   Reply With Quote
Old 05-20-2006, 06:08 PM   #4
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Its not the valve covers, because this is on the front of the motor, and the valve covers are to the sides. I've replaced those recently as well.
Old 05-20-2006, 07:23 PM   #5
Dobes
Member#: 164
2008 Exige S240
Had a similar leak on my car. I thought it was the front main seal or oil pump seal but after removing the timing belt cover I ruled those out since both were clean. It turns out it was power steering fluid that was leaking from the front of my power steering pump, dripping down the front of the timing belt cover, and collecting right where your leak is. Could be something to check. Are you low on p/s fluid?
JD
Dobes is offline   Reply With Quote
Old 05-20-2006, 08:04 PM   #6
2.5WagonGuy
Member#: 109513
i know, but when my valve covers were leaking the oil was blowing around under the car, when i replaced the valve cover gaskets the leak was fixed
Old 05-20-2006, 09:43 PM   #7
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
off topic.. PS.. get rid of that fram filter.. worse thing you can put on your car.
NiTRoN is offline   Reply With Quote
Old 05-21-2006, 12:29 AM   #8
2.5GTLegacy
Member#: 111219
I agreed with Dobes.
It's the Power Steering fluid. you must have a leak in your reservior or a bad P/S pump. It happened to mine and i was also curious about it. Until i check the fluid that's drip to the ground, It didnt smell like oil and a different color. I knew it was the Power Steering.
Check your Power steering lines to see if theres a leak there. And most of the time, It's probly a seal or the pump is bad. i need to get mine fix also lol.
2.5GTLegacy is offline   Reply With Quote
Old 05-21-2006, 01:53 AM   #9
legacytuner671
Member#: 94348
2oo2 StAge 2 WRX
ya my power steering is leaking tooo
legacytuner671 is offline   Reply With Quote
Old 05-21-2006, 02:22 AM   #10
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Hmmmm.... I didn't think it'd be power steering since my hydraulic lash adjusters would act up, and I'd add just a little oil, and poof, they'd stop clacking. So I thought for sure it was oil. But I'll touch the drops and see what kind of viscousity they have, check the dipstick and see what color the oil is there, since this fluid is dark black, and also check some of the lines. I'll look around the valve covers (easy to do since they are a bright blue gasket). Thanks for the prompt replies as always!
Old 05-21-2006, 11:24 AM   #11
2.5GTLegacy
Member#: 111219
Yeah, at first i too thought it was the oil. But maybe yours could be something else.
Old 05-21-2006, 12:04 PM   #12
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
In regards to power steering versus oil, you could clean the entire REALLY REALLY well and watch it closely for where the oil starts to leak from/accumulate.
But inspecting the fluid will probably tell you.
GTWagon_Phreak is offline   Reply With Quote
Old 05-21-2006, 01:05 PM   #13
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Powersteering looks to be topped off. Oil is pretty dirty (probably the fram), so I'll change that out, and clean the area really nice to find out where its coming from. I looked at where that piece of the motor goes (the panel) and it sits behind most of the pulley assembly, so I imagine if it is that seal, it'll be a real PITA to change out.
Old 05-21-2006, 01:24 PM   #14
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
+1
That's how I found out some of the fluid on my steering rack was actually oil blowing back from the drain plug.
IronMonkeyL255 is offline   Reply With Quote
Old 05-22-2006, 12:40 PM   #15
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Alright, today I'm going to hit the engine hard with the degreaser and figure out where the oil is coming from. I know its oil for sure now, because my oil was topped off and after a cruise with some local subaru guys, it was alot lower, and all over the underside. Also my lifters were making noise until I topped it off.
It looks to be either that front seal, or the oil pan itself. After that cruise, the headers were covered in a thin film of oil, and following along the oil pan back towards the y pipe it got sludgier and then the most oil was collected on the y pipe itself.
Old 05-22-2006, 02:31 PM   #16
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Your front engine seals are leaking. Make sure you replace the timing belt at the same time to prevent spending more money later.
RexyGirl is offline   Reply With Quote
Old 05-22-2006, 05:27 PM   #17
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Yeah... timing belt and front seal were replaced at 123k miles. I'm at 137k now. So that really sucks... Maybe they have a longer than 12k mile warranty...?
Old 05-22-2006, 08:27 PM   #18
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
i have the same leak, let me know what you find out.
legacydreamz is offline   Reply With Quote
Old 05-22-2006, 09:14 PM   #19
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
geez. I just looked through the service records. The front crank seal has been replaced 5 or 6 times, and the front timing belt cover seal has been replaced 3 times. Is this normal? Seems like the oil leak was a consistent problem.
Old 05-22-2006, 09:37 PM   #20
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
it's the cam seals.
if they aren't done with the timing belt, they will leak in time.
thus you have a bleeder.
i do too.
i'm gonna fix mine in two weeks when i'm back in NC.
while you're in there, make sure to change all 5 seals, that way you won't have to go back in.
edit:
use either a felpro or OE seal. the rest will still leak like a bish.
ooberdoob is offline   Reply With Quote
Old 05-22-2006, 09:44 PM   #21
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
This is sounding more and more fun. Seems my motor has a problem with seals. I also know the cam seals were replaced twice (since the timing belt was replaced twice). Well... I'll call around see what it costs to get the seals replaced, or what a timing belt job costs (and then I'll ask if those seals are replaced in that maintenance).
Old 05-22-2006, 09:53 PM   #22
ooberdoob
Member#: 70418
drive a lifted TJ.
dealer hear told me $700
eitehr learn how to do a timing belt or bend over.
i'm choosing to learn.
i'm goin gto school for automotive anyhow, so it's not really a big deal... i'm really antsy to do it, i just need to get to NC to do it.
Old 05-22-2006, 10:30 PM   #23
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
Where in NC?
Old 05-22-2006, 11:17 PM   #24
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
It's likely the O-ring gasket and rear case seal on the Oil Pump. Plan to replace both the O-ring and reseal the back of the Oil Pump case, as well as the front main seal since you've got it apart anyway and you'll likely ruin the FMS when you re-install the oil pump. Might as well do the valve cover gaskets while you have it apart since most of the stuff will be out of your way.
Check out this article on the repair vs replacement process... http://endwrench.com/images/pdfs/OilPumps.pdf
Here's the timing belt guide for:
SOHC - http://endwrench.com/images/pdfs/2.2SingleOverWin01.pdf
DOHC - http://endwrench.com/images/pdfs/2.5Timing.pdf
HTH
Subietonic is offline   Reply With Quote
Old 05-22-2006, 11:28 PM   #25
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
I've never known a 2.2 SOHC to have so many issues with its seals. Sounds like someone (Dealer tech?) didn't know what they were doing when the previous seals were replaced. Especially with those few miles on a 96. Only exception would be if it is consistently run low on oil as the seals will dry out/crack/leak if not properly lubricated from the back side.
Good luck with your repair. It's fun. I believe your 2.2 is a non-interference engine so you should not have any issues with the cam pulley alignments like you do on the new 2.2 SOHC and 2.5 DOHC engines.
Rear Diff axle seal ... is this normal? Bad Noodle Transmission (AT/MT) & Driveline 9 02-11-2010 10:12 PM
What plane is this/Is this plane real? skimmilk68 Off-Topic 17 05-04-2008 05:51 PM
What hose is this, and why is it coming loose? CirrusWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-11-2002 03:32 PM
What rim is this and what color is it? pio!pio! Brakes, Steering & Suspension 7 06-13-2002 09:04 PM
What the...is this the same car? (sorry about huge pics) '83 DL WGN General Forum Archive 16 11-05-2000 02:58 PM
