Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 05-21-2006, 07:05 PM   #1
plymouth37
Member#: 88453
1973 wrx 2.0 turbo
914 porscharu
Default any experiance with vishnu performance?
I am interested in a 300hp computer upgrade from vishnu for my 2004 wrx. is any one running this or another vishnu system? what do you think of it? thanks!
plymouth37 is offline   Reply With Quote
Old 05-22-2006, 06:09 PM   #2
aprazma
Member#: 77619
2009 Cayman S
I had the Vishnu Stage 1 which consisted of the uppipe, turboback, pulley, and Ecutek reflash. (Now have added DB16g, meth, and a few other things.) It is a very good package, and a lot of fun. Really fast turbo spool, smooth power band, 3rd gear becomes a power gear and 5th gear can be used for passing.
But the Ecutek reflash map for this stage is not as good as custom tuning by Shiv. On the reflash before custom tuning, I was running lean from around 3000-3400 rpm on an 05 WRX with 91 octane.
aprazma is offline   Reply With Quote
Old 05-22-2006, 08:16 PM   #3
teiva-boy
Member#: 22825
You are better off finding a local tuner in your area if you have one. If you are stuck on a mail order, look elsewhere then Vishnu. There are quite a few other comparable tuners that cost less, and are not as conservative as he is.
/Past tuned by Shiv himself customer...
teiva-boy is offline   Reply With Quote
Old 05-22-2006, 08:53 PM   #4
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
I think any shelf map you download or get from someone (mail order) is going to be conservative. It's not safe for them to send you an aggressive map since not every vehicle is the same.
As for engine management I think one of the best routes is to get an ecutek, the same thing Vishnu uses, and then have someone local tune your car.
You can find use ecutek computers on this forum in the private for sale section. Used, it'll be cheaper and then it's just up to you to take it to a tuner, plug it in, and have them tune it for your car. Just make sure you get one compatible with your model year and tranny.
djoye is offline   Reply With Quote
Old 05-23-2006, 04:31 PM   #5
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
[quote=djoye]I think any shelf map you download or get from someone (mail order) is going to be conservative. It's not safe for them to send you an aggressive map since not every vehicle is the same.[quote]
You are sort of correct. It really depends on how well the tuner knows how the ECU operates and the modifications that have been done to the vehicle. A tuner that understand what the ECU does can push the envelop further because they can manipulate the ECU to follow a set of rules for different weather conditions or emergency conditions. It is being able to readapt the ECU to the new modifications is what takes a lot of work. Once you have done that, then making reliable power even on a shelf map is not hard.
plymouth37, if you are looking for a mpa or even want to drive over here for a tune let us know.
Cheers,
William T. Knose Jr.
Lead Programmer
Crawford Performance / I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Anyone have any experiences with Tcharged Performance in Ogden, Utah? DoctorNick Rocky Mountains Impreza Club Forum -- RMIC 18 05-01-2009 01:40 PM
Any audiophiles have any experience with Digital Music Servers? Neek Off-Topic 10 02-16-2007 12:45 PM
Any of you guys know or have any experience with RX-8? Starscream Off-Topic 89 01-01-2007 08:48 AM
Any have any experience with MILITEC-1, a metal strengthener and oil additive? fengshui-fu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-12-2003 12:52 PM
Any Of you old dsm guys have any experience with the blitz boost controller? bill harvey New England Impreza Club Forum -- NESIC 0 01-19-2001 11:48 AM
