Old 05-21-2006, 09:03 PM   #1
legacytuner671
Member#: 94348
2oo2 StAge 2 WRX
Default question
i just found out from someone that i would not be able to drop 18's on my 99 legacy gt....and my question is...is this true????....if so im devastated now
legacytuner671 is offline   Reply With Quote
Old 05-21-2006, 09:37 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
It depends on the width of the 18s, I've seen some that do work, and some that don't.
The issue is rubbing on the fenders.
Wiscon_Mark is offline   Reply With Quote
Old 05-21-2006, 10:49 PM   #3
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
I would NOT drop 18's on my car ever. It would surely dent the hood!!!
janikphoto is offline   Reply With Quote
Old 05-21-2006, 10:50 PM   #4
that one legacy
Member#: 103665
*slaps accross face*
oh hush you, you know what he was talking about!
that one legacy is offline   Reply With Quote
Old 05-21-2006, 11:01 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
they'll fit most likely, width is your biggest enemy.
fibuz is offline   Reply With Quote
Old 05-22-2006, 01:48 AM   #6
legacytuner671
Member#: 94348
2oo2 StAge 2 WRX
no cause i found out through a tire magazine....that for a 99 subaru legacy gt the highest suggested size is 17 for rims. and im like nooooooooo
Old 05-22-2006, 07:17 AM   #7
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
suggested sizes are just that, merely suggestions.
Old 05-22-2006, 02:11 PM   #8
Hiroki Tada
Member#: 8048
Width and offset will be the biggest concern. I would think that a 7.5" width rim that has an offset of 48-52mm would just clear. Maybe you'll need some fender roll.
Hiroki Tada is offline   Reply With Quote
Old 05-22-2006, 02:16 PM   #9
Trin_Starr
Member#: 102416
1995 Legacy L
red
I run 18x7.5 wheels with 215/35/18's tires on my 95 legacy with no issues but I want to go to a 225/40/18 tire because my wheels are bent up pretty badly with the 35 series tires.
I hope my car can take the 225 tire tho - i'll find out this weekend
Trin_Starr is offline   Reply With Quote
Old 05-22-2006, 03:26 PM   #10
Kraziken
Member#: 38629
1999 Legacy GT (STI)
Oh, 18's will fit.
I flopped back and forth on this one. I originally ordered 17's but my brother talked me into going 18's.
I too am running 215's. 225's is pushing it too far I think.
Kraziken is offline   Reply With Quote
Old 05-22-2006, 05:31 PM   #11
legacytuner671
Member#: 94348
2oo2 StAge 2 WRX
so there is a god....nice
Old 05-22-2006, 05:35 PM   #12
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
I don't think there are that many Legacy's that can pull off 18's some of them look really good with 18's but others just look too riced out for me. Choose your rim carefully, what are you planning on getting?
~Mike
pilfflip is offline   Reply With Quote
Old 05-22-2006, 09:17 PM   #13
legacytuner671
Member#: 94348
2oo2 StAge 2 WRX
ok i was thinking about these rims.....
http://www.discounttire.com/dtcs/fin...bp=&vid=006490
and my legacy is silver 99 gt
Old 05-22-2006, 10:42 PM   #14
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
That wheel will look good on a 99 BD/BG. The issue, will be the 48 offset (from this spec sheet - at 18" x 7.5" - http://www.wheelsbymbmotoring.com/MB...rtsWeights.pdf) and the tire size you're going to go with. If you stick with a 215/45 (depending on the specific tire section width that you go with) you might be able to squeeze it under there. If you go any wider, then you're looking at rub on the fenders (remember lower offset moves your wheel outward away from the hub).
Also, the extra weight (21 lbs per wheel PLUS whatever additional you'll gain with the 18" tires) is going to make your car feel really sluggish. That coupled with the extra weight is also going to strain your braking system as you have significantly increased the rotational mass.
Not trying to dissuade you, just keep it all in perspective and plan your upgrades accordingly.
Subietonic is offline   Reply With Quote
Old 05-22-2006, 10:47 PM   #15
that one legacy
Member#: 103665
i've got 225s on my rims, but i've only got 16's. the tires are 225/50/16 to be exact, i have yet to encounter any rubbing issues.
mine's still stock height though, and i was planning on switching to a skinnier tire before i drop it.
Old 05-23-2006, 12:01 AM   #16
legacytuner671
Member#: 94348
2oo2 StAge 2 WRX
not worried about the slugging part too much....soon to be making my legacy an sti sleeper....lol
Old 05-23-2006, 02:30 AM   #17
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
the offset thread in the tire and wheel forum say between 47-50mm offset for the 7.5'' wide rim. so your in the green as far as "possibilty" goes, but if you have worn struts or your car is lowered, or you just like to take corners really fast, you might rub every now and then. as stated, you will feel real sluggish from the 18's. if i were you i would go 17's, plus you'll still be able to clear those massive STI brembo's once your STI swap is done......
~Josh~
Old 05-23-2006, 10:41 AM   #18
Kraziken
Member#: 38629
Going to a plus size rim, you will also offset a bit of tire weight. It's not much but it is some. Going to a larger rim even if it is lighter will lose you some horsepower, because your pushing the weight further out.
In one of the horsepower tv shows I watched, a RSX lost a couple hp on the dyno by going to larger brake rotors, even though the rotors were lighter than stock, because the rotational mass is closer to the edge of the tire.
I think if you select a light weight rim, the effect is minimal.
A lower profile tire has less tire flex, and also improves handling though, at the cost of ride comfort.
I think 17's are probably the perfect size for the BD's, but I can't say I'm sorry I went with 18's. When I look at my car I want to make sweet love to it. I mean... never mind.
Old 05-23-2006, 04:47 PM   #19
legacytuner671
Member#: 94348
2oo2 StAge 2 WRX
kraziken.....i want the same setup you have with your rims....just different rims....and i want the same setup with the motor.....plus if i had your car i would be making sweet love all the time....baby when i get this feeling i need sexual healing!!!!!
Old 05-23-2006, 05:35 PM   #20
Kraziken
Member#: 38629
Heh, I think I've been watching too much Southpark.
Old 05-23-2006, 09:41 PM   #21
Hiroki Tada
Member#: 8048
So yeah,
umm 225/40/18's on 18x7.5 49mm offset on a lowered BE = no rub. i would think you'll be fine with 215's on a BD.
Any FAA peeps in OT ? Pilot certification question (small craft) Wagon Of Fury Off-Topic 7 06-04-2010 09:29 PM
Question from a friend... REX265 Newbies & FAQs 5 06-03-2010 12:53 PM
Turbo question The Surrey Scooby Newbies & FAQs 0 06-03-2010 04:10 AM
Just Bought My WRX !!! Questions...questions...questions.... TheNookie Rocky Mountains Impreza Club Forum -- RMIC 10 09-27-2002 07:35 AM
Questions questions questions... mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 16 04-08-2002 10:08 PM
