Old 07-19-2012, 05:08 AM   #651
Carbondioxide
Member#: 326622
need some help :
I have Impreza 2006 , 2.0L , non turbo , from middle east .
I just changed my orignal radio to an after-market ,, AVH-2350DVD
I read your thread but I'm not sure if I saw my model > I have a probelm with an antenna " remote on " thing . my car does not have antenna or "L" box in the trunk , there is only black box and i'm not sure if it's the antenna amp .
the signal very weak and I thought the problem was in my after-market radio. so I need some help to fix it .
my connection wire is 14-pin this is a picture of it .
and there is 2-pin connection and I don't know what it is ? or what's for ?
I replaced my after-market radio from stereo shop.
Carbondioxide is offline   Reply With Quote
Old 07-19-2012, 06:50 PM   #652
CSVT_2004
Member#: 182213
1999 Contour SVT
If you bought an adapter harness you need to power up the blue wire from that. According to my diagrams Pin 14 White is what powers the antenna amplifier if you have it.... Maybe you just need a new antenna?
As for that box, I can't find that in any of the radio diagrams and it does not look like any of the antenna amplifiers I've ever seen for subaru. That may be apart of the defroster circuit or lighting.
CSVT_2004 is offline   Reply With Quote
Old 07-19-2012, 07:46 PM   #653
cheezmunky
Member#: 167627
2011 WRX Ltd Hatch
I've got a 2011 wrx ltd non-nav stock stereo. Couple of days ago it started sporadically getting a 'check usb device' error on the head unit. Now it always displays the error and the ipod never works in the car. I can use other inputs (radio, etc.) just fine. My older nano also works. The ipod that fails is a 2g 160 gb classic with version 2.0.4. It only contains ~3500 songs. I've hooked it up to my xbox and the xbox can read it just fine. Any ideas?
cheezmunky is offline   Reply With Quote
Old 07-20-2012, 09:13 AM   #654
Carbondioxide
Member#: 326622
Is this good to boost up the signal of FM/AM .
I just fix it from stereo shop for 5$
Old 07-20-2012, 10:57 PM   #655
cheezmunky
Member#: 167627
2011 WRX Ltd Hatch
Ended up doing a manual reset of the iPod and it fixed the problem. Not quite sure what caused it
Old 07-23-2012, 03:27 AM   #656
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by RichM View Post
I have a 2011 Impreza Outback Sport with the CZ624U1 head unit that I'm looking into swaping for one of the 4.3" HD radios from a 2011 or 2012 Forester like this thread.
What model HU should I be looking for so I do not loose any SWC (radio and bluetooth) functionality?
Any of the 2011-2012 HU models with 4.3" screen will be compatible with your 2011's SWC buttons.
The CP635U1 (shown in that thread) uses CAN bus and does not have the new leads for 'bright' mode and VSS, so that one is a good choice.
The CM631UD (Clarion PF-3391A-A, Subaru 86201FJ630, Rear MR63) dropped CAN and has the 'bright' signal and VSS. Your SWCs would work, but it would be a good idea not to connect your CAN wires to that HU.
SVXdc is offline   Reply With Quote
Old 07-23-2012, 08:28 AM   #657
CSVT_2004
Member#: 182213
1999 Contour SVT
What was wrong then?
Old 07-24-2012, 09:25 AM   #658
RichM
Member#: 211092
2011 OBS
Arrow
Thank you David.
What is 'bright' mode?
Am I correct in assuming the CP635U1 uses the CAN bus data to perform speed sensitive volume functions, just curious?
Would the CP635U1 be able to sense a manual transmission being put in reverse in the event I want to hack in a backup camera?
RichM is offline   Reply With Quote
Old 07-24-2012, 09:33 AM   #659
mpggomd
Member#: 74167
2011 WRX Sedan WRB
TP Stage 2, w/cust tweaks
I have a question:
I put in my 2011 WRX a Kenwood KDC-HD942U with the Axxis SWC. I soldered all the Axxis wires per the manual and everything works fine. My question is this: sometimes my source input will change automatically or a track will skip automatically. I thought I had a loose wire somewhere but i recently checked and re-checked everything. It's all hooked up right and connected well. What would cause this?
mpggomd is offline   Reply With Quote
Old 07-25-2012, 04:08 AM   #660
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Normally, the radio's display (along with other parts of the instrument panel) are dimmed when you turn on the headlights ('night dimness'). But when you turn the illumination dimmer wheel all the way up, the illumination control module cancels that dimming. That is 'bright' mode. Some older models had a separate button to activate that.
Some of the 2012 (and newer) models have that signal on one of the factory radio harnesses. Cars with the CM631UD have that on pin 11 of the 20-pin power/speaker harness.
Am I correct in assuming the CP635U1 uses the CAN bus data to perform speed sensitive volume functions ?
Yes, and to lock out some functions while driving.
Foresters have both the reverse gear and parking brake signals on the factory 16-pin aux/mic harness. You would need to supply those signals by adding 2 new wires to your car's factory aux harness.
Old 07-25-2012, 04:20 AM   #661
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by mpggomd View Post
I put in my 2011 WRX a Kenwood KDC-HD942U with the [Axxess ASWC]. I soldered all the Axxis wires per the manual and everything works fine. My question is this: sometimes my source input will change automatically or a track will skip automatically. I thought I had a loose wire somewhere but i recently checked and re-checked everything. It's all hooked up right and connected well. What would cause this?
What firmware version does your module have? Look at the white sticker on the bottom. There's a manufacturer's code and a date. The last 3 digits of the code are the version it was originally built with.
Metra is currently up to version 2.28 (for older hardware) and 3.08 (for newer hardware). 2.26/3.06 (released 2/20/2012) fixed an issue with the HU receiving anomalous commands from the ASWC.
Sounds like yours is older. I have Metra's special USB-CAB programming cables available. E-mail me for details (see my profile page here).
Old 07-25-2012, 09:01 AM   #662
mpggomd
Member#: 74167
2011 WRX Sedan WRB
Thanks for the heads up. I'll check it out later today and let you know if i need to buy a cable from you.
Old 07-25-2012, 09:09 AM   #663
RichM
Member#: 211092
2011 OBS
Thanks again David. I appreciate all the info your willing to share.
I don't like the idea of the lockout, but the HD radio and more detailed display along with keeping all the SWC functionality may be a reasonable compromise for me if I find a used CP635U1 at a fair price.
A backup camera hack will have to wait a while. My neck still works, I'm not that old or lazy... yet.
Old 08-09-2012, 01:27 AM   #664
abrok99
Member#: 176873
2000 forester L
silver/ugly ass black
what OEM headunit with an AUX jack can I swap into my 2004 WRX, preferably just a swap in and out.
abrok99 is offline   Reply With Quote
Old 08-09-2012, 02:16 AM   #665
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
2007 Impreza (model "C-124" printed on front, Clarion models PF-2868A-A and PF-2868A-B)
2007-2008 Forester (model "C-123" printed on front, Clarion models PF-2851B-A and PF-2851B-B).
Search for the various threads/posts that discuss connecting to the aux socket on the back (several are in this same FAQ thread).
Old 08-10-2012, 10:28 PM   #666
AdvancedApe
Member#: 316617
2013 WRX Limited
Crystal Black Silica
Hi all. Just a quick question to ask the gurus on this thread. I found an OEM navigation unit from a 2011 STi, and I'm wondering if I would be able to drop it into my 2012 WRX. Would this be a pretty easy thing to do, or would I lose bluetooth and steering wheel controls? I've been doing lots of research, but I have been finding mixed answers. Thanks for the help.
AdvancedApe is offline   Reply With Quote
Old 08-12-2012, 03:34 AM   #667
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Yes you can. It's not too hard. See this.
Also see this for answers about SWCs, BT, USB, etc. (2012 WRX is essentially the same as 2011 WRX).
If your OEM HU is the model CZ624U1 (printed on the front), your factory radio harness still has the two CAN bus wires. So the Navi's car performance functions should still work (some markets outside North America still offer that OEM Kenwood Navi on 2012 WRX and STI, so I don't think there would be any issues).
Old 08-14-2012, 05:07 PM   #668
Jawknee5
Member#: 112334
05 STI
Hey guys,
I have a 05 STI with the stock head unit in it. My question is; does the 05 headunit have AUX? I'm thinking of getting a Parrot unit to utilize bluetooth and playing music off my iPhone. I've never taken out the head unit before and I remember that the 06-07 had an AUX in the back of the headunit but I'm not sure if the 05 does too.
thanks in advance.
Jawknee5 is offline   Reply With Quote
Old 08-14-2012, 10:01 PM   #669
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
If it doesn't have a button on the front labeled "AUX" then no aux input on the back.
You can search for various hacks to connect an aux device (e.g., "Jazzy" mod). Or switch to a newer HU (perhaps even aftermarket, for better sound and more features).
Old 08-19-2012, 06:41 PM   #670
sevnseat
Member#: 210746
Default Stupid Kicker Subwoofer...
Ok - I've been searching the threads and have probably missed it. I just picked up a 2012 STI after my 04 WRX had served faithfully for years. I love the car but I'm too old to enjoy the kicker subwoofer in it. Can I just unplug it with no ill effects (besides the people next to me in traffic staring as they get the bass from NPR?)
sevnseat is offline   Reply With Quote
Old 08-20-2012, 03:56 AM   #671
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by sevnseat View Post
I just picked up a 2012 STI ...
Can I just unplug [the OEM kicker subwoofer] with no ill effects ... ?
Yes, except where you really need to disconnect it is behind your HU.
The Kicker sub's harness includes high-pass filters for the outputs going to the main speakers. So if you simply disconnect the sub in the trunk, the T-harness will still be blocking bass from going to your main speakers.
You don't have to de-install the harness, just unplug it and connect the car's factory radio harness directly to your OEM HU (as it was before the sub was added). You can download the installation instructions from Subaru's site. See the link in post 1 of my 'Subaru stock HU info' thread.
See this thread for pictures and more information about the Kicker sub:
New 2011 11" Trunk Mounted Subwoofer
Old 08-20-2012, 06:32 PM   #672
sevnseat
Member#: 210746
Thanks, That's what I needed to know! I appreciate it.
I'm a little happier at least that I didn't pay for it after reviewing that thread!
Old 10-23-2012, 11:12 PM   #673
FrankWhizzite
Member#: 317178
2009 Impreza
Spark Silver Metallic
i have an 09 2.5i that im changing the head unit in, when i pulled it out, i noticed that there was a plug in the back (not the main harness) with wires that i believe were red, black, and white. what do i do with these??? if i can snag a few pics, i will asap...
FrankWhizzite is offline   Reply With Quote
Old 10-27-2012, 03:10 AM   #674
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Probably the harness from your factory 3.5mm aux jack. That will have a white, 8-pin plug, with 4 wires populated. The factory colors should be Yellow, Blue, Black, and Black/Orange. If you would like to retain your factory aux jack with the new HU, I make an adapter for that. E-mail me for details (see my profile).
Old 11-04-2012, 12:21 AM   #675
Ultimateone
Member#: 48025
17 SWP STI
SVXdc, check your email please - ready to order asap.
Ultimateone is offline   Reply With Quote
Stock head unit information -- pin-outs, aux inputs, and more SVXdc Car Audio, Video & Security 12 01-23-2007 02:27 AM
Question about factory head units nsnguyen Car Audio, Video & Security 7 04-30-2004 02:26 PM
Question about using head unit to power back speakers STI-o-MY Car Audio, Video & Security 0 12-01-2003 03:06 PM
question about my head unit creature546 Car Audio, Video & Security 1 10-03-2002 07:48 PM
