Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 07-10-2013, 05:05 PM   #776
Gamebay11
Member#: 361945
2011 Impreza WRX STi
Lightning Red
I know im not posting a radio question just yet, but im trying to get a hold of SVXdc. Ive sent you 2 emails so far trying to order a headunit connector with no response. If oyu could get back to me I would appreciate it very much. With all the help you give out on here Im sure youre just extremely busy.
EDIT: Thank you. Will post many questions im sure when doing my install.
Gamebay11 is offline   Reply With Quote
Old 07-14-2013, 12:30 AM   #777
SpicyPeaNut
Member#: 43310
1978 Brat
I figured I should actually post this here instead on the seperate thread.
So I bought my car with the factory navigation. Can I Swap the factory nav unit with the base model non-nav head unit without purchasing different harness plugs?
I want this:
To replace this:
Will this simply be a "unplug nav unit, plug in non-nav unit." quick and painless swap?
SpicyPeaNut is offline   Reply With Quote
Old 07-14-2013, 12:45 PM   #778
Mr5speed
Member#: 268603
2013 STI Hatch
WRBP
I sent you a PM. Then found this. Didn't know if you are using factory or not.
Subwoofer/amplifier harness
H630SFG510
Regular head unit, no nav.
Mr5speed is offline   Reply With Quote
Old 07-14-2013, 04:54 PM   #779
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
No. See my longer answer in your thread:
Base vs Nav, PnP Question
SVXdc is offline   Reply With Quote
Old 07-16-2013, 11:32 PM   #780
SpicyPeaNut
Member#: 43310
1978 Brat
Svx, did you get my email
Old 07-24-2013, 07:55 PM   #781
BURUTOO
Member#: 349400
2015 WRX Limited
I want this:
To replace this:
I have not yet ordered my WRX so I am curious why you want to replace the optional oem nav system for the stock HU. is the oem nav that bad/not worth ordering?
BURUTOO is offline   Reply With Quote
Old 07-26-2013, 06:01 PM   #782
dallas4u
Member#: 152999
05 FXT MT
Hey... hoping SVXdc or someone can help me with this. I apologize for asking for so much info, but...
I have an '05 Forester XT Premium with the sub. I bought a C123 headunit, the AUX cubby, and have the AUX cable for it. I'm still a little confused on what wires to tap in to and how to get the sub wired in to the AUX harness to get both working. Sorry, just having some trouble wrapping my brain around it. Do you mind helping at all?? Here is a post (by SVXdc) showing the pin outs of AUX cable and radio...
Post #10 from you here
I'm just not sure what wires to cut on which harness and where to splice them. Every time I start to think about it I get confused.
Thanks for any info you can give!!
dallas4u is offline   Reply With Quote
Old 07-26-2013, 07:40 PM   #783
dallas4u
Member#: 152999
05 FXT MT
Ok, well, I believe I'll be cutting the 8 pin plug (which should be 3 wires) from my current '05 harness, then need to somehow wire the two sub out wires to #4 and #8 on the new '08 plug on the AUX harness, then ground to chassis the third wire, but I'm not sure I know which are the two sub out wires on the '05 plug. I can't find a pin out for the '05 Forester with sub.
Old 07-28-2013, 09:14 PM   #784
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by velcro View Post
I have an 07 Forester with the single CD ("type A") radio, with no AUX button. Is there any way to hack an AUX input (1/8" female) into this radio?
Thanks!
No easy way. There are a couple of threads that describe how to solder wires onto the HU's PC board, to connect your aux device into same place where the the CD, tape, or FM audio comes in. I'm fairly sure some were mentioned earlier in this thread.
It may be easier to find the double-DIN 2007 that has the aux input (nidek C-123 or C-124).
Old 07-28-2013, 09:24 PM   #785
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Your 2005 Forester's 8-pin harness only has 2 wires, for the subwoofer, on pins 4 and 8 (same locations and functions as on the C-123, except it's a different physical plug/socket).
I can provide a harness with the proper 8-pin connector to fit your 2005's factory harness. E-mail me for details.
You need to ground the new HU's aux enable pin (pin #6). If you're using an Impreza aux interconnect harness (intended for the C-124, which does not have the sub out), cut the wire going into the HU's pin #4, and ground the segment that goes to the aux pod. Use the other segment (going into the HU's pin #4) for your subwoofer.
You'll need to add a new wire to the HU's pin #8. I can supply a wire with the proper pin to snap into that plug. Again, e-mail me for details.
If you use an aux interconnect harness salvaged from a 2007-2008 Forester, it will have all of the pins wired that you need. You just need to connect the two subwoofer wires from your 2005's harness to pins 4 and 8 going into the HU, and ground a wire that goes to the aux pod's aux enable switch. There's a thread on the Forester forums which discusses that.
Old 07-29-2013, 12:44 PM   #786
dallas4u
Member#: 152999
05 FXT MT
Sending you an email right now... thanks!
Old 08-16-2013, 12:57 PM   #787
RyaanJaansen
Member#: 283845
While reinstalling the stock H/U, I disconnected the wrong section of wiring coming from my AUX/12V. Anyone have any ideas where this wire plugs into? I searched through the console and couldnt find anything.
RyaanJaansen is offline   Reply With Quote
Old 09-08-2013, 06:04 PM   #788
VASubaru
Member#: 367801
Default Installation of Clarion CX501 in 2003 Outback Wagon
I want to replace the stock 6CD changer/radio in my 2003 Outback wagon with a Clarion CX501. I understand I will need a wiring harness but have been unable to figure out what to order. Do I need to order and installation kit as well? If so, does anyone know where I could find the correct installation kit? I also want to know how to find out where the antenna connection is on the stock head unit.
Many thanks to anyone who can help me out with this!
VASubaru is offline   Reply With Quote
Old 09-08-2013, 06:54 PM   #789
VASubaru
Member#: 367801
I found the answer to my antenna question here: http://forums.nasioc.com/forums/show...57030#poststop (SVXdc Antenna connection 04-10-2005, 01:32 AM).
Old 09-08-2013, 07:54 PM   #790
Thekidboulay
Member#: 364233
What can fit a 2011 outback sport
Thekidboulay is offline   Reply With Quote
Old 09-10-2013, 12:10 AM   #791
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
What model and year car?
What do you mean by "the wrong section of wiring coming from my AUX/12V" ? Are you talking about the factory harnesses for the 3.5mm aux jack and accessory outlet ("cigarette lighter outlet") in the armrest center console? Where did you disconnect things? Can you post pictures?
Old 09-10-2013, 12:20 AM   #792
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
(I'm assuming you're talking about aftermarket head units).
Just about any double-DIN will fit. You'll need a dash kit for 2008-up Impreza/WRX/STi, or one of the JDM-style replacement bezels. See this post.
Any 2008-up Impreza, and 2009-up Forester OEM HU will fit. If your steering wheel includes the phone/Bluetooth buttons, you'll want to find an OEM HU from an Impreza or Forester that also had those buttons.
Old 09-14-2013, 11:23 PM   #793
speedenthusiast1371
Member#: 108140
Those 20A backup light fuses will get you everytime
Last edited by speedenthusiast1371; 09-15-2013 at 01:22 AM. Reason: Figured it out
speedenthusiast1371 is offline   Reply With Quote
Old 09-15-2013, 03:21 AM   #794
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by speedenthusiast1371 View Post
I have a 13 Base WRX that I attempted to replace the stock HU in. I disconnected the battery, ...
Now after I connected all of the wires from my metra harness to the harness for my kenwood ddx 770, I went to connect it back to the car and now Im getting no power. I reconnected the stock radio and still nothing. No power.+ I've checked the fuses and and everything else.
Edited to:
Yep, the fuse in the engine bay that powers the +12V Battery lead on the radio harness. Also powers the clock, courtesy lights, keyless entry, and more. Depending on year, it may be labeled "audio" or "backup". Backup means 'memory backup', not reverse gear lights.
You'll see that designation on HU service manuals, too -- "BU" or "B/U" for the pin with +12V Battery.
Old 09-15-2013, 02:17 PM   #795
speedenthusiast1371
Member#: 108140
Thanks for the reply. I looked around for 45 min on my car trying to figure out what happened. I took more of the dash apart to see if one of the factory connections came loose before I started to look at the forums. In hindsight, I wish I would have seen your posts for the axxess... I said screw it and put it in a bag for the next time i feel like taking everything apart
Old 09-16-2013, 02:29 PM   #796
rlowery78
Member#: 181076
2013 STI Hatch
SVXdc - Need to order a harness, followed your instructions several days ago... Ready to pay you... Just need an invoice.
Sorry for placing junk in your informative thread.
rlowery78 is offline   Reply With Quote
Old 09-18-2013, 07:52 PM   #797
Seegy24
Member#: 319426
2012 STi
Plasma blue pearl
Ok Maybe someone can help (SVXdc) didn't see this thread when I ordered all the stuff to put a new head unit in my car. Everything is going good until I go to add the steering wheel controls. They want you to splice into the factory wiring and I don't want to do that. I know you sell the correct harness but didn't know that until now (already have other harness all wired in) I was wondering if you could point me in a direction to get the 3 pins I need and put them in my wiring harness. I cant seem to find them anywhere. Maybe easternbeaver, but I am also not sure which one I need for sure?
Seegy24 is offline   Reply With Quote
Old 09-25-2013, 12:37 AM   #798
ScoobieDriver87
Member#: 367026
2013 Impreza Sport
Pearl White
I have a 2013 impreza sport and was wondering if I would be able to simply run my rcas into the back of my head unit or will I need to do something else.
I am a complete noob at this so any help will help greatly.
ScoobieDriver87 is offline   Reply With Quote
Old 09-25-2013, 11:09 PM   #799
Jmhm17
Member#: 224097
2012 WRX Hatch - DGM
Stage 1 - Tuned by Bren
I have a 2012 base WRX and I understand I have pretty decent stock speakers they are kicker wozen cones with bigger magnets. I am looking to amp them with the stock head unit what is the max RMS wattage on the stock speakers? I do not want to blow them and replace them.
Also how do you get the signal from the stock HU to the amp?
Jmhm17 is offline   Reply With Quote
Old 09-26-2013, 12:09 AM   #800
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by Seegy24 View Post
I ... put a new head unit in my car. Everything is going good until I go to add the steering wheel controls. ...
I was wondering if you could point me in a direction to get the 3 pins I need [for the SWC wires] and put them in my wiring harness. I cant seem to find them anywhere. Maybe easternbeaver, but I am also not sure which one I need for sure?
I'm not aware of anyone selling the pins, other than the manufacturers (who require a minimum order of a reel of ~10,000 terminals).
The only place you'll find wires with the proper pins is by cannibalizing another of the same harness (and there are at least 3 different "flavors" out there, each with different, incompatible pins), or from me. Sorry.
If you order another significant item from me (such as an ASWC or an aux adapter harness), I can probably provide the 2 or 3 SWC wires with the proper pins to fit your harness.
For people who haven't ordered a harness yet, it's easier just to order a whole one from me.
Stock head unit information -- pin-outs, aux inputs, and more SVXdc Car Audio, Video & Security 58 03-20-2015 09:18 PM
Question about factory head units nsnguyen Car Audio, Video & Security 7 04-30-2004 02:26 PM
Question about using head unit to power back speakers STI-o-MY Car Audio, Video & Security 0 12-01-2003 03:06 PM
question about my head unit creature546 Car Audio, Video & Security 1 10-03-2002 07:48 PM
