Old 04-28-2007, 05:35 PM   #76
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by Marlons101 View Post
[CDs jammed in changer] ...
See my reply (and any follow-ups) in this thread:
Dead 6 disc w/cd's inside
SVXdc is offline   Reply With Quote
Old 05-14-2007, 01:40 PM   #77
Eluder
Member#: 128706
2016 WRX Sport tech
World Rally Blue
Question, anyone know the part number for the aux jack plate from the 07's? Is it the whole plate and ashtray place holder, or is it just a plate? I want to retrofit the plate in my 06 and feed my Pioneer deck's aux and USB connector through the plate for a clean look (I know some dremelling will be required for the USB). Thanks!
Eluder is offline   Reply With Quote
Old 05-24-2007, 02:39 PM   #78
babs07fxtltd
Member#: 144864
I would very much be interested also in how to get the aux cable (from head unit to the aux plate) out of the car or if it can?
Is the aux connection a standalone circuit with all connections terminated at each plug or does something split off somewhere in the harness?
Reason I ask is a friend wants to install my 07 in his earlier Forester, but it's no use to him if he has no means to hook up the aux input.
babs07fxtltd is offline   Reply With Quote
Old 05-25-2007, 09:38 AM   #79
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
07 wrx tr head unit issue????? crazy!!! makes no sense to me!!!
Well i have had the car for 2 days now and last night i installed my clarion cd player. to make a long story short clarion has 2 constant and 1 switched wires from the back of the unit. I could not remember which wires went where since i did not have the manual. i wired up all the wires except those 3 to test them in the car. i made sure that the 2 hot wires coming out of the dash were not touching anything. I 1st plugged up the antena and as soon as it was in the fuse for the dome light blew. i carefully pulled the antena out and unhooked the wiring harness. i replaced the fuse and began my test again without the antenna plugged in. I found out which wires were constant and not with no issue. I then wired up everything nice and safely like all the other wires. plugged everything up including the antena... no blown fuses this time... the only problem is this - i get hardly any radio stations. Is there something on this car that i am missing.. this is my 1st subby but not my 1st radio install i have done many many in the past and know what i am doing. my other ? is why did it not blow the radio fuse? makes no sense what so ever to me.. please help me if you can. Thanks
boostdog is offline   Reply With Quote
Old 05-25-2007, 12:45 PM   #80
mcdeve8
Member#: 143174
2005 WRX Wagon
CGM
I've heard that there is a power antenna that must have 12V to it. There should be a power antenna lead coming off of the back of your deck.
t4nk indicated this on my deck install faq
http://forums.nasioc.com/forums/show....php?t=1261005
"i just skimmed the post.. but i didnt see anything about the "Power Antenna" wire having to be hooked up. On the subies, if you have the glass painted antenna, you have to provide 12v of power to, or u will get horrible reception. I just used my blue remote wire for this.."
mcdeve8 is offline   Reply With Quote
Old 05-25-2007, 02:15 PM   #81
boostdog
Member#: 149752
2017 wrx
ahhh ha!! i did not realize that.. ok ya there was a blue wire but usually thats for power antenna's... good deal!!! i'll take care of that asap! thanks for the help!
Old 05-25-2007, 02:52 PM   #82
LastResort
Member#: 99289
Go and read Offsets manifesto.
LastResort is offline   Reply With Quote
Old 05-25-2007, 11:18 PM   #83
jayspeedy24
Member#: 130381
can someone one tell me the site where you can buy the stealth sub box for the 07 wrx? thanks.
jayspeedy24 is offline   Reply With Quote
Old 05-26-2007, 01:57 AM   #84
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
According to this post, the part number is 86257SA010.
However, the aux box may be slightly different in different models so there might be more than one part number.
There's a picture of one from a 2007 WRX back in post #22 of that same thread. It's a complete box, not just a plate.
Old 05-26-2007, 02:00 AM   #85
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by mcdeve8 View Post
I've heard that [the car has] a power antenna that must have 12V to it. There should be a power antenna lead coming off of the back of your deck.
I also mentioned that in posts 2 and 3 of the "Stock head unit" thread.
Old 05-26-2007, 02:03 AM   #86
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Are you talking about the kind you mount under either of the front seats? Subaru factory sub or after-market?
Old 06-15-2007, 01:39 AM   #87
mgetchis
Member#: 151210
So I'm installing a carpc and I need to find the 12v switched line. From my research it runs .5amps when the key is turned.
Does anybody know which color/wire this is on the harness? I have an 06 impreza
Yes I know i can find out moy rapido with a 12v test light and the keys to my car, but i'm super planning this out and would rather have at least some idea of which one it is. I'll be wireing it to a carnetix p1900 then to my mac mini and touch screen.
mgetchis is offline   Reply With Quote
Old 06-15-2007, 08:56 AM   #88
LastResort
Member#: 99289
The very first post in this thread, points directly to the information you are looking for.
http://forums.nasioc.com/forums/showthread.php?t=749402
Old 06-16-2007, 12:43 PM   #89
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
From post #2 of the "Stock HU" thread...
Here's the pin-out for the radio connector, with wire colors in the Impreza/WRX
The pin-out is definitely the same for the 2006 (and 2007 and 2008). Some of the wire colors may have changed, but since you're going to have to pull your radio to get to the wire, you'll be able to look at the plug and see which wire goes to the pin you need.
(mgetchis' post was originally in that other thread, but I asked the mods to move it over to this "questions" thread).
Old 07-16-2007, 12:20 AM   #90
Starguard
Member#: 148783
1993 Impreza Sedan
Thumbs up Thank you!
The information on the head unit installation (especially the wiring/pinout diagram) was invaluable! We wouldn't have been able to install my aftermarket one with out it. The color defaults were especially helpful since the guy who had my '93 Impreza before me had really left a rat's nest behind him. he had clipped off and by passed most of the wiring harness. Thanks to the FAQ I now have a working radio that I don't have to reprogram everytime I turn off the car!
Starguard is offline   Reply With Quote
Old 07-18-2007, 06:19 PM   #91
miros
Member#: 154350
Here is my solution using an aftermarket DVD player with AUX IN on the front panel and an external FM modulator to piggyback sound to the Subaru's OEM stereo (sorry, forum won't let me post full link, paste it to browser):
scoobymods.com/forums/showthread.php?p=29833#post29833
The DVD player replaces the original DIN pocket under the factory stereo. My DVD has also an additional AUX IN available from the backside, so you can wire it under the dash to the ash tray, cup holder if you are looking for some fixed solution (like ipod dock).
miros is offline   Reply With Quote
Old 07-20-2007, 09:40 AM   #92
babs07fxtltd
Member#: 144864
Originally Posted by Mike2.5i View Post
On the stock '07 head unit, is there a (stock) subwoofer input in the bottom right hand corner thats square and has (I think) 10 pins?
07 Radio has two plugs.. Aux and Sirius...
From all the pieces of info I've seen.. The two plugs on the back of the head unit are the Aux input, and Sirius connection (I guess the Cenet bus).
On the 07 Aux Harness (plug to cable to plug to plate)....
From the Forester forum, one guy was able to remove the aux cable (radio to plate)... It comes out, but it's a funny looking thing in the forester.. not the simple short cable I've seen in here. There's a ground that splits off. I haven't tried it in mine yet.
07 radio in earlier Forester with sub-plug ????
A couple guys in the forester forum are wondering about trying to install an 07 radio (with aux, but without dedicated sub-out plug) in an earlier forester that has a plug for the sub.
Can anyone help us out with the diagram for the 07 XT forester with the sub output? Is this one of those T-harness situations where the 6x9 is fed off the main speaker leads from the main output from the head unit?
Old 08-07-2007, 11:12 PM   #93
xxxxfactor
Member#: 144622
2005 WRX
Crystal Gray Metallic
help...and yes i've tried searching.
I have an 05 wrx sedan and noticed it comes w/ a factory supplied amp. I don't have the sub and was wondering if the factory amp supplied needs to be by-passed prior to installing an aftermarket hu?
thanks
xxxxfactor is offline   Reply With Quote
Old 08-08-2007, 01:43 AM   #94
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Are you talking about a factory amp that drives the 4 main speakers? I've only heard of that in Subarus with McIntosh systems, but wasn't aware of that being offered on your model and year.
With the McIntosh system, the HU itself still has the same 14-pin connector, but the 4 speaker outputs there are dead (and the car's wires stop short before reaching the speakers). A separate umbilical connects to the Mc amp. It has the same style 14-pin connector which has the 4 speaker outputs plus a speaker-level subwoofer output.
If that's what your car has, and you don't want to use the amp, then yes you'll need to bypass the amp. You'll just need a second 14-pin wiring adapter ("forward" harness) to connect to the speaker wires (the harness that was originally plugged into the amp).
If you do want to use that amp (leaving it driving the car's speakers), you'll have to get the McIntosh umbilical cord, cut off the HU end and solder on four RCA plugs. Then plug that into line outputs on your new HU. Here's the pin-out (orientation is viewing the socket on the rear of the amp):
Pinout of 13 pin din Amp Connector on McIntosh HUs (on SubaruOutback.org)
If that's not what your car has, then can you post pictures of the front and back of your stock HU and this amp you're talking about?
Old 08-08-2007, 08:33 AM   #95
LastResort
Member#: 99289
I have an 05 WRX, it does not come with anything other than a headunit, speakers, and possibly a sub.
Old 08-08-2007, 07:51 PM   #96
xxxxfactor
Member#: 144622
2005 WRX
Well from the 05 install that I found that SVX also posted on, this pic shows an amp. I haven't attempted install yet because I haven't received the harness in the mail. See pic below
Old 08-08-2007, 08:59 PM   #97
LastResort
Member#: 99289
No, it's instructions that you only need to remove the screws indicate in blue, if you are replacing deck and installing an amp.
There is no amplifier outside of the headunit.
Old 08-15-2007, 07:05 PM   #98
Fail Wagon
Member#: 133584
would it be possible to get an old style subwoofer and a new style and plug them both in? so one ran off of the rear speakers and one ran off of the front?
Fail Wagon is offline   Reply With Quote
Old 08-26-2007, 10:31 PM   #99
zsimpreza
Member#: 157079
2007 Impreza 2.5i
Obsidian Black Pearl
I can't seem to find out if there is an Aux input for the base stereo with single CD player. Anyone know?
zsimpreza is offline   Reply With Quote
Old 08-28-2007, 12:54 AM   #100
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
People have plugged in two subwoofers without any problems.
However, both the old- and new-style T-harnesses listen to the rear speakers.
Some really old harnesses connected to the front speakers. I don't know which cars those were sold with.
If you really want one sub on the fronts and one on the rears, the easiest way to do that would be to re-pin the speaker wires on one of the T-harnesses (swap fronts and rears). The radio will still send the front outputs to the front speakers and rear to rears, but that sub will now be listening to the front signals.
I say "easiest," but extracting the pins (especially from the reverse plug) is a real bear. Some people might prefer to just snip the 4 speaker wires (rears where they T off) and re-attach to the other 4 speaker wires (fronts).
Stock head unit information -- pin-outs, aux inputs, and more SVXdc Car Audio, Video & Security 12 01-23-2007 02:27 AM
Question about factory head units nsnguyen Car Audio, Video & Security 7 04-30-2004 02:26 PM
Question about using head unit to power back speakers STI-o-MY Car Audio, Video & Security 0 12-01-2003 03:06 PM
question about my head unit creature546 Car Audio, Video & Security 1 10-03-2002 07:48 PM
