#101 | |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
The cars101.com site may help. It has a lot of info about standard and optional features on all Subaru models. If the car the HU was in does not have an aux jack (either on the "ashtray" module or in the center console), then the HU probably doesn't have the input. 2007 was the earliest year that feature appeared. Very few people have seen 2008s yet.
#102 |
Member#: 35584
South East
Vehicle:1965 FFR Roadster Coyote + TR-6060 |
So, I bought a COMPLETE 07 STI limited head unit with the AUX jack, Clarion Sirius add-on, Sirius antenna for the passenger side windshield, and the harnesses. As I understand it from reading dozens of posts in multiple threads, the 14-pin connectors are the same, the CeNET jack goes to the Sirius unit, and the 8-pin-out goes to the AUX jack.
I want to stick this in my 2003 WRX which has the factory AMP/SUB add-on and I'd like to keep it. Obviously the 07 no longer had the AMP/SUB out on it and mine has the connector (not the older T-type). What do I do now if I want to get this to work. Here are the pictures of what I have. Click the thumbs for larger pictures 2003 HU left / 2007 HU right 2003 HU AMP/SUB out on the bottom-left 2007 HU Back 2007 HU Bottom with Sirius Add-on and bracket 2007 HU Top 2007 HU Side AUX Jack CeNET Cable Sirius Ant BTW, Does anyone know WTF you do with the CeNET Pass-thru jack? And if anyone is interested, I'll post pictures up when it is install because I had LightWerkz modify the backlighting to blue to match the rest of my custom interior. |
#103 |
Member#: 35584
South East
#104 | ||
Member#: 25837
South East
You'll find that your sub has what I call the "old style" T-harness — it only connects via the 14-pin speaker/power connector. Your sub will work fine on the 2007 with no mods needed. The CeNET Pass-thru jack would be used for additional CeNET devices, such as a CD/DVD Changers, XM satellite receiver, aux input, iPod interface, HDD Navigation, TV tuner, 5.1 Surround Sound, "and more." Theoretically you can daisy-chain several onto the bus. However, people in another thread discovered that non-Subaru CeNET devices won't work with the Subaru HU. The CeNET data protocol includes encryption that determines which devices will talk to each other. Subaru HUs will only talk to Subaru peripherals. Looks like something for factory testing/programming, especially since it's normally covered up by the car's mounting brackets. |
#105 | ||||
Member#: 35584
South East
And one more question... any idea how to get the HU to clear the HVAC with the Sirius strapped to it. I can't seam to get it to go in and it looks like I'll need to remove the entire center, slide the stero in place from the rear, then reinstall the center console to get it to work in the 02-03 location. |
#106 | |||
Member#: 25837
South East
#107 |
Member#: 130765
E. Canada
Vehicle:2007 2.5i SE Wagon CGM |
SVXdc, I have a 2.5i SE wagon (Cdn model with the double DIN stereo as found in the STi and WRX - like what Chrisarella has, above, miuns the Surius components). From what I am reading, if I want to order a factory sub from SubaruGenuineParts.com, I should order the older (pre-05) sub, and not the newer design?? Is this the one with T-connector that is needed for this HU?
https://www.subarugenuineparts.com/p...roducts_id=242 Or should I get this one? Do you know if it has the T-connecter too?: https://www.subarugenuineparts.com/p...oducts_id=1130 I wonder if they are the same, except for the price... Thanks in advance. ![]() |
#108 | |
Member#: 25837
South East
What I call the "old style" harness (with just the two 14-pin radio connectors) Subaru started using again in 2007, since the subwoofer output was dropped from the 8-pin connector. See the subwoofer posts in the "Stock HU" thread for pictures and more info. As for the difference between those two particular subwoofers, yes, they are probably the same amp/speaker unit with different brackets and possibly "old" vs. "new" harnesses. Subaru does sell at least two different sub units with different wattages, but I think the price difference has always been greater than $7. |
#109 |
Member#: 156729
I just got a new 2008 Impreza 5-door and I want to install the Kenwood KSC-SW1 with the factory HU.
After searching this forum and others I figure I need to order one of these: Subaru Subwoofer Wiring Adaptor ("Forward" Harness). But, I also need some way of getting the correct t-harness for the factory stereo without shelling out the money to get the factory sub woofer .Any ideas? Thanks |
#110 |
Member#: 99289
#111 | |
Member#: 25837
South East
Since you don't have the sub T-harness, you'll spend less by just getting forward and reverse WRX harnesses and combining them with the Kenwood's harness to make your own T. That will also enable you to connect the KSC-SW1's "remote on" wire to the +12V accessory (switched) lead — your best option, since the factory HU doesn't have an amp remote on output. |
#112 | |
Member#: 130765
E. Canada
#113 |
Member#: 153631
Vehicle:2007 STi OBP |
So if I am to understand this correctly, an aftermarket HU in an 07 STi will use the pinouts as listed on the "WRX-pinout" page on geocities (which I cannot link to yet) correct? There is a note about "factory colors" in the first para and I wanted to make sure that was the correct diagram to use. Thanks in advance!
#114 | |
Member#: 25837
South East
On the 2007 car's harness, some of the factory colors (column "A") may have changed slightly from that table, but I think most (if not all) are the same as 2002-2005. But instead of worrying about the factory wire colors, you'll save yourself a lot of potential grief by using an aftermarket wiring adapter for your installation. |
#115 | |
Member#: 153631
I got a harness, I just wanted to make sure it was wired correctly before I install. |
#116 |
Member#: 139955
NESIC
Vehicle:# OneBoston |
USDM 2000 LGT, CD+Tape with Weather Band..CD player quits after 1 maybe 2 tracks on all disks..I can instantly switch to FM and itll work..I can run FM all day long..
Anyone know whats up? |
#117 |
Member#: 25837
South East
Sounds like your CD transport has died (which is a common problem). But several people have brought theirs back to life with a CD lens cleaner disc.
#118 |
Member#: 35584
South East
UPDATE: I got my 07 STI limited stereo installed into my 03 WRX wagon... factory Sub/Amp works, iPod works, Sirius works.
#119 |
Member#: 151807
SCIC
Vehicle:2004 Forester XT Silver |
Yes you could, but why? An aftermarket amp is going over power the stock "woofer" and you will probably kill it rather quickly.
#120 |
Member#: 160042
I have a 08 outback wagon legacy. Does anyone know where the heck they hid the antenna wire??? I'm looking for it so I can hook up my premier HU. I got a Subaru to motorolla adapter, but I can't find the stinking antenna wire...
#121 | |
Member#: 25837
South East
Did your Outback not have a HU? Otherwise you should have found the antenna connector plugged into the HU (obviously). On Legacy HUs, the antenna connector is at the end of a pigtail. So the car's mating connector might indeed get buried in the rear of the dash opening. It might help if you post pictures of the rear of your factory HU and the dash opening. |
#122 |
Member#: 160042
I haven't had the chance to yank the HU out yet, I just figured out where to pull the hvac cable off at... but from looking behind it, I don't see the antenna plugging into the hu... I looked at all the wires coming off and didn't see it. I will post pics if I cannot find it tonight, thanks for the reply though.
#123 |
Member#: 62386
Vehicle:2008 Honda S2000 Chicane Silver |
I have a 07 STI. My question actually has to do with burning MP3 cds for my factory headunit. It has the option to switch folders and what I did was burn a cd with 5 different folders on it. Now I play the cd and it starts playing only one of the folders plays. Do I have to put all those folders in a main folder and then burn it? Before you flame me, I did search and RTFM, I just can't find it explaining this issue.
Thanks, Colin |
#124 |
Member#: 168513
2007 WRX - Philly, USA
I have a Kenwood KSC-SW1 subwoofer. It came with a 10-pin connector chord, romote chord, and RCA cables. Can I use this sub with the stock HU? |
#125 | |
Member#: 25837
South East
You won't need the RCA cables, since the stock HU does not have line-level outputs. Since the HU also lacks an output for a speaker amplifier remote control, you'll need to connect the KSC-SW1's remote-on wire (Blue/White) to the car's +12V accessory (key-switched) power. If you get "forward" and reverse Subaru 14-pin harnesses, you'll be able to make all of these connections behind the HU without cutting any factory wires, similar to how the Subaru factory subwoofer ties in. Just be sure to get harnesses with all 14 wires, or else the HUs' illumination will stop working. |
| Thread Tools | |
| Display Modes | |
| Stock head unit information -- pin-outs, aux inputs, and more | SVXdc | Car Audio, Video & Security | 49 | 04-11-2013 08:49 AM |
| Question about factory head units | nsnguyen | Car Audio, Video & Security | 7 | 04-30-2004 02:26 PM |
| Question about using head unit to power back speakers | STI-o-MY | Car Audio, Video & Security | 0 | 12-01-2003 03:06 PM |
| question about my head unit | creature546 | Car Audio, Video & Security | 1 | 10-03-2002 07:48 PM |
