Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-22-2006, 05:21 AM   #1
prometheum
Member#: 92003
04 bicycle!
Default 3rd gear pull *csv file using mps utec logger
http://www.whiskeytangofoxtrot.net/hosted/3rd.csv
no knock though, normally see it between 3500 and 4000 though
small 16g
sti pinks
catless up pipe
vishnu TBE
stock intercooler
prometheum is offline   Reply With Quote
Old 05-22-2006, 11:09 AM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Hmmm, Iím no expert here, but notice you never hit your 100% load range? Looks like maybe your TPS may need to be calibrated if you havenít already done so. The procedures are in the UTEC instructions.
xcntrk75 is offline   Reply With Quote
Old 05-22-2006, 02:08 PM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Looks ok. The only downside to not hitting 100% TPS is that you will never get to the rightmost column on your boost map. Just as long as you know that you are ok. I would however recalibrate it since it takes 10 seconds.
Get bigger injectors and UP THAT BOOST!
Code:
2000	-0.4	2.5	97	10	0	0	28.9	9.9	32.6	-1.4	325	2.2
2023	-0.2	2.5	97	10	0	0	28.9	10.6	32	-1.4	325	2.3
2091	0.2	2.5	96	10	0	0	28.5	11	31.5	-1.4	325	2.3
2149	0.4	2.5	96	10	0	0	28.1	11.6	30.4	-1.4	325	2.3
2182	0.8	2.6	97	10	0	0	28.1	11.9	29.7	-1.4	325	2.4
2272	1.3	2.6	97	10	0	0	27.8	12.7	29.1	-1.4	325	2.4
2306	1.7	2.6	97	10	0	0	27.7	13.1	28.3	-1.4	325	2.4
2374	1.9	2.7	98	20	0	0	27	14.2	27.5	-1.3	325	2.5
2433	2.3	2.7	97	20	0	0	27.4	14.6	26.7	-1.3	325	2.5
2495	2.7	2.7	97	20	0	0	27.7	15.3	25.8	-1.3	325	2.6
2523	3.1	2.8	97	20	0	0	27.3	16.2	25	-1.2	325	2.6
2624	3.7	2.9	97	30	0	0	28.3	17	23.3	-1.2	325	2.6
2683	4.1	2.9	97	30	0	0	26.9	19.1	22.3	-1	325	2.7
2782	4.9	3	97	30	0	0	23.8	20.5	21.1	-0.9	325	2.8
2841	5.5	3.1	97	40	0	0	22	22.7	19.7	-0.5	325	2.8
2926	6.2	3.2	97	40	0	0	20.1	24.4	19	-0.3	325	2.9
3005	7.2	3.2	97	50	0	0	19.8	27.5	17.4	1.6	325	3
3075	8.2	3.3	97	50	0	0	18.4	31.4	15.8	1.6	325	3.1
3115	9.4	3.5	97	60	0	0	17.6	35.2	15	1.7	325	3.3
3211	11	3.5	97	70	0	0	16.5	41.7	14.1	1.7	325	3.2
3326	12.7	3.5	96	80	0	0	15.5	43.6	13.5	1.7	325	3.3
3377	13.9	3.7	96	80	0	0	15	46.3	13.5	1.5	325	3.4
3572	14.9	3.7	96	80	0	0	15	50.2	13.5	1.3	325	3.5
3642	15.7	3.6	97	90	0	0	15	51.6	13.4	1.3	325	3.5
3732	15.5	3.8	97	80	0	0	15.2	54	13.5	0.9	325	3.4
3840	15.7	3.8	97	80	0	0	15.5	56.7	14	1	325	3.4
3862	15.7	3.7	96	80	0	0	16.5	56.4	14.8	0.9	325	3.5
4035	15.9	3.7	96	90	0	0	17.1	57.2	15.1	0.9	325	3.4
4089	16.1	3.8	97	90	0	0	16.9	58.9	15.7	0.9	325	3.5
4177	16.1	3.8	97	80	0	0	16.6	57.7	16.4	0.5	325	3.6
4329	15.9	4	97	80	0	0	15.6	63.2	16.5	0.7	325	3.6
4474	15.7	3.9	97	90	0	0	15.8	63.7	16.4	0.5	325	3.7
4559	16.4	4	97	90	0	0	15.9	67.6	16	0.5	325	3.7
4585	16.8	4	97	90	0	0	16.8	70	16.8	0.5	325	3.7
4649	17	4.1	96	90	0	0	18.1	70.9	18.1	-0.7	325	3.7
4852	16.8	4.1	96	90	0	0	18.8	72.6	18.5	0.4	325	3.7
4873	16.4	4.1	96	90	0	0	20.4	74.9	18.5	-0.3	325	3.8
4990	15.9	4.1	97	90	0	0	21.7	75.5	18.5	-0.9	325	3.7
5081	15.7	4.1	97	80	0	0	20.7	74.2	19	-1.1	325	3.8
5175	16.1	4.2	97	90	0	0	22.2	74.4	19.1	-1.1	325	3.8
5274	15.7	4.2	97	90	0	0	22.3	80.6	19.5	-1.2	325	3.8
5367	15.9	4.2	96	80	0	0	22.1	79.1	19.6	-1.3	325	3.9
5491	16.4	4.3	97	90	0	0	22	82.1	19.5	-1.2	325	3.9
5509	16.4	4.3	96	90	0	0	22.4	82.9	19.5	-1.1	325	3.9
5688	16.4	4.3	97	80	0	0	22.8	85	19.6	-1.2	325	3.9
5727	15.9	4.3	97	80	0	0	22.7	85.4	19.9	-0.9	325	3.9
5847	15.5	4.3	96	80	0	0	23.2	87.4	20.1	-1.1	325	3.9
6253	15.3	4.3	96	80	0	0	23.5	86.7	20.6	-0.8	325	4
5984	15.5	4.3	96	80	0	0	23	90	20.6	-0.8	325	4
6184	15.5	4.3	97	80	0	0	24.1	90	20.7	-0.9	325	4
6127	15.3	4.4	97	80	0	0	24.4	90.2	21	-0.9	325	4
6301	15.1	4.3	96	80	0	0	26.5	88.6	21	-0.9	325	4
6397	14.9	4.4	97	80	0	0	26.5	88.5	21	-0.9	325	4
6510	14.5	4.4	97	80	0	0	26.4	89.5	21.4	-0.9	325	4
6548	15.1	4.4	97	80	0	0	26.7	91.9	20.7	-0.9	325	4
6613	15.1	4.4	96	90	0	0	26.9	92.1	20.5	-1.2	325	4
6640	15.3	4.4	96	80	0	0	26.7	94.2	21	-0.9	325	4
6693	15.3	4.4	97	80	0	0	27.2	92.3	21.1	-0.9	325	4
6720	15.1	4.4	97	80	0	0	27	92.8	20.7	-0.8	325	4
6788	15.3	4.4	96	90	0	0	27.8	91.7	20.5	-1.2	325	4
6872	15.3	4.4	96	80	0	0	27.9	92.4	20.8	-0.8	325	4
6930	15.7	4.4	97	80	0	0	28.4	89.8	20.7	-0.8	325	4
6930	15.3	4.2	31	80	0	0	39.9	22.3	20.9	-0.9	325	2
6561	9.4	2	0	20	0	0	10.5	10	ECU. 	-1.8	ECU.  	1.9
6195	2.9	2.1	0	10	0	0	11	10.1	ECU. 	-1.8	ECU.  	1.9
5931	-4	2.1	0	10	0	0	10.8	9.9	ECU. 	-2.1	ECU.  	1.9
cdvma is offline   Reply With Quote
Stage 2 STI 07 log E-Tuned 3rd gear pull Defmxtones AccessPort 2 06-17-2009 02:40 PM
Stage 2 STI 07 log E-Tuned 3rd gear pull Defmxtones Open Source Reflashes 17 06-03-2009 10:14 AM
2nd and 3rd gear pull log economy AP map vf30 boost too high ? bozz AccessPort 4 04-30-2008 03:02 PM
Did a few 3rd gear pulls on my 03 WRX if you guys want to see :) *LOGS druxboyz Commercial ECU Reflashes 11 01-14-2007 09:39 PM
Converting .txt to .csv files? gongzero Off-Topic 11 12-10-2004 12:10 AM
