Old 05-22-2006, 10:24 AM   #1
brcewane
Member#: 63990
Flat Grey
Default DIY: How to change your door card color
I had been asked by a member of our local Subaru club for some information on how I changed my door card color in my 02 WRX. So I figured I would post a DIY so everyone that was interested could use the information.
They weren't that hard to do. Not sure if anyone has taken the door panels off before or not but here are step by step instructions:
Tools/parts needed
- Flat & philips screwdriver
- 3M spray adhesive contact cement
- really small self tapping screws
- Durable fabric
- scisors
- utility knife or razor blade
Door panel removal
- First there are I believe 1 screw, and 2 plastic pop screws to take off the door panel. The screw is located inside the door handle recess on the arm rest. You will see a little plastic tab down in there you need to pop open to expose the screw.
- The 2 plastic pop screws are one at the hinge of the door and one at the rear. (The rear doors may be a little different, I can't remember)
- Now you need to pop the plastic trim off that is around the door handle itself. Do this gently by wrapping some cloth around your flat head screwdriver and gently pry it off. This is important to get off, or it will bust when you take the door panel off
- Once all the these steps are done you will have to grab the panel and pull fairly hard, but not too hard. There are a bunch of push clips all around the door that hold it on. Just keep pulling around the edges until all of these pop free
- Once it is free from the door you can unplug the wiring harness to the power windows and locks
Door Panel Disassembly
- I believe there is only one screw on the back of the panel.. but there are a bunch of plastic pop rivots that have all been fused. You will see where they all are. Basically what you are going to do is separate the top part of the door panel from the bottom
- Unscrew the top screw and then take your flat head screwdriver and pry under all the fused pop rivots and bust them free. This is where your self tapping screws will come into play later
- You may want to wear gloves when doing this because when that screwdriver busts through, the plastic can be pretty sharp. My knuckles looked like I was in a brawl afterwards
- You should now be able to grab a hold of the old fabric that was glued on there and pull it all off. As you are doing this, notice how it was simply tucked up in under the padded area on the top part of the door panel.
Putting on the new Fabric
- If you like, you can use the fabric that you pulled off for a template. I didn't do this but instead took a larger piece and simply cut off the excess when I was done. I didn't want to worry about making sure I put it on exactly right and then risk missing covering some areas.
- Tape, or cover the door panel area that doesn't have the fabric on it.
- Then use your 3M adhesive and spray it on the area that the fabric goes, making sure to get a good coverage to prevent any areas letting loose later
- Once you have sprayed on the adhesive, let it setup for a few seconds. You want it to be tacky and not wet. If it is wet, it can soak through your fabric and make it look blotchy
- Now press on and smooth out your fabric all over the area.
- Use your flat head screwdriver to press the fabric into the seam where the upper padding is on the door to make sure you have it nice and tight in there. Don't press too hard or the flathead could mark or damage the existing covering.
- Wrap the fabric all over the area that the old fabric was on and then cut off all the excess with a utility knive or razor blade. Again be careful when cutting the excess fabric near the upper padding so that you don't cut the padding itself.
- Let the glue dry according to the specification on the spray bottle
Reassembly
- line the top and bottom half of the door panel up based on their pop rivots, and use the single screw that was taken out previously to temporarily hold the two parts together.
- Now is where you take all of the small self tapping screws and screw them into each of the pop rivots that you broke.
- be careful with the length of the screws that you use. You don't want them to come through the other side of the door panel when putting them in. Screw them in really slowly and if you see an sign of them poking through the other side, stop.
- Once the door panel is back together, put it back on the door in the reverse order that you did to take it off, and voila, you are done
End result
Here are some pictures of the end result from my installation:
brcewane is offline   Reply With Quote
Old 05-22-2006, 10:52 AM   #2
RS drifter
Member#: 7891
2005 wrx STI
Aspen MF white!
wow...good work
RS drifter is offline   Reply With Quote
Old 05-22-2006, 11:20 AM   #3
20Sti05
Member#: 92657
2008 I GOTZ MEEZ A
PICKEM UP TRUCK!!!
nice write up
20Sti05 is offline   Reply With Quote
Old 05-22-2006, 06:32 PM   #4
THEW0RX
Member#: 107976
05 WRX Stg 2
WR blue
Wow that looks great! What kind of frabric is that?
THEW0RX is offline   Reply With Quote
Old 05-22-2006, 07:48 PM   #5
brcewane
Member#: 63990
Flat Grey
not sure exactly.. just was asking the folks in Fabric land for something that was durable... and then color matched it
Old 05-22-2006, 08:44 PM   #6
veightkiller
Member#: 78967
2011 335i
nice job!
veightkiller is offline   Reply With Quote
Old 05-22-2006, 08:55 PM   #7
Ghosthound
Member#: 110979
2010 FJ Cruiser
1999 Miata
great work!! what if u got some thin foam and cut out WRX then glued that behind the fabric, then glued the fabric to the logo... if uve seen unique whips, im sure you know what i mean.. i think that would look pretty sick.
Ghosthound is offline   Reply With Quote
Old 05-22-2006, 09:04 PM   #8
Sanchez
Member#: 51002
2005 Pig STi
Turbo Negro
holy crap, that's a great write up. I might consider this actually...
Sanchez is offline   Reply With Quote
Old 05-22-2006, 11:27 PM   #9
dpflipstyle
Member#: 100173
2002 Wrx
you should make it a sticky
dpflipstyle is offline   Reply With Quote
Old 05-23-2006, 07:37 AM   #10
brcewane
Member#: 63990
Flat Grey
Yeah, I know what you mean.. I think I've seen a DSM guy do that before
Old 05-23-2006, 08:23 AM   #11
rallyken
Member#: 92395
02 WRX
I did this with my civic awhile back with red fabric the only problem i had was the 3m adhesive in the summer got hot and would come unstuck and bubble.
rallyken is offline   Reply With Quote
Old 05-23-2006, 09:26 AM   #12
brcewane
Member#: 63990
Flat Grey
That sucks... So far mine has held up for 2 summers. Just got around to putting up a DIY now
Old 05-23-2006, 01:40 PM   #13
rallyken
Member#: 92395
02 WRX
Ha obviously you knew what you were doing LOL Me= nooblet. Maybe it was the fabric i used yea ill blame it on the fabric.
Old 05-23-2006, 01:57 PM   #14
darroj
Member#: 113645
2004 PSM WRX
Stage 1ish
well, there goes my weekend thanks for the great write up!
darroj is offline   Reply With Quote
Old 05-23-2006, 03:26 PM   #15
AudioNerd
Member#: 91586
2008 Sti
Spark Silver
I did this to my wrx last summer and haven't had any problems yet, other that some fading of the suede I used.
AudioNerd is offline   Reply With Quote
Old 05-23-2006, 04:30 PM   #16
B16A2NR
Member#: 88676
I really want to know what kinda fabric you used. I went to the fabric store and bought about 6 samples of blue I thought would work. None of them looked close enough to use. Does your door card fabric better match the front or rear sti seats? I noticed the front sti suede seats are a slightly darker blue than the rear sti seat. Can somebody with an sti check for me?
B16A2NR is offline   Reply With Quote
Old 05-23-2006, 05:13 PM   #17
brcewane
Member#: 63990
Flat Grey
I actually just took in a body part from the car and color matched it as close as I could to it..
Old 05-27-2006, 05:27 PM   #18
brandonbeeb
Member#: 92614
Hey guys just finished doing mine i was originally the one who asked about this on our local thread but here are some pics. There pretty close to the colour of the car but in the sun they look lighter. when i was doing mine found some sti fabric on the back of doors lol
brandonbeeb is offline   Reply With Quote
Old 05-27-2006, 09:29 PM   #19
brcewane
Member#: 63990
Flat Grey
Looks good.. hopefully I will see it in person at the June TSC meet.
Old 05-28-2006, 02:22 AM   #20
vrexxx
Member#: 105315
02 wrx
wrb
you guys can buy the blue micro fiber fabric, it feels like sued, its the closest to the sti, i just bought some today and planning to do the seats and roof with the doorcards also, you can find it in your local fabric store, joanns, a.c. moore, etc. you can also use vinyl
vrexxx is offline   Reply With Quote
Old 05-28-2006, 02:24 AM   #21
fluxcapacitor
Member#: 93843
X Evo X
1.21 Gigawatts of Boost
just did this mod today and came out GREAT! ill post pics soon
fluxcapacitor is offline   Reply With Quote
Old 05-28-2006, 02:30 AM   #22
B16A2NR
Member#: 88676
Pics would be great. I'm in fullerton and would love to know what fabric you purchased and where, so I can go there and get some.
Old 05-28-2006, 02:47 AM   #23
fluxcapacitor
Member#: 93843
X Evo X
well i got the fabric at joanns, i got 1 yr of it and its more than enough for 4 doors. Took me about 3 hrs to do and the color came out real close to the sti door color.
Old 05-28-2006, 03:12 PM   #24
Unseenpunk
Member#: 115601
2015 WRX Premium CVT
Dark Grey Metallic
looks good
Unseenpunk is offline   Reply With Quote
Old 07-13-2006, 01:17 PM   #25
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Bump for me doing this today or tomorrow, I'd like to do the seats to, anyone have ideas?
wrxfactor is offline   Reply With Quote
Tutorial: How to change your clock to blue, red or whatever color you want lennyTR Electrical & Lighting 45 09-03-2014 03:11 PM
DIY: How to relocate your watersprayer for FMIC blackout801 Interior & Exterior Modification 7 06-09-2009 06:32 PM
DIY: How to redo your grounds on your GC Impreza L.. Impreza Forum 1 11-05-2008 03:10 AM
How to remove rear door cards? MF-DIF Interior & Exterior Modification 4 12-09-2007 08:04 PM
How to change a door window. Kosmic Interior & Exterior Modification 5 06-09-2006 02:33 AM
