Old 05-22-2006, 10:14 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Impression: Borla header vs. Ported and coated exhaust manifold
With help of my buddy, we were able to take off Borla header and put ported exhaust manifold on today. Install went longer than expected because bolts were badly rusted and one of stud came off.
Impression:
Borla header: lack of low-end torque, but makes up with improved top-end power. Raspy sound that replaces famous boxer engine sound. Ideal for all out power.
Ported and coated exhaust manifold: good low-end torque and midrange power. Porting helps to improve top-end power slightly below power range of borla header. Car is noticeably louder with deep boxer rumble. Ideal for every day driving. In 1st and 2nd gear, car feels extremely smooth and powerful similar to feeling I had when I drove my buddy's STi.
My car is getting Protuned again on 6/7/06. Will post dyno chart for comparison (Borla vs. Ported stocker). Car dyno'd 262whp and 272wtq with Borla header. 80whp and 140 wtq @ 3000rpm.
Old 05-22-2006, 10:38 PM   #2
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
make sure to get some graphs of boost while you are dyno'ing.
jdgrimm is offline   Reply With Quote
Old 05-22-2006, 10:54 PM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Please post a link in this thread when you do get tuned
Old 05-22-2006, 10:56 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Of course. I'll keep the boost the same at 17.5psi.
Old 05-23-2006, 12:03 PM   #5
eddie1982
Member#: 114569
2004 JDM
Headache
port looks good
eddie1982 is offline   Reply With Quote
Old 05-23-2006, 12:44 PM   #6
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
how long did it take you to swap im putting mine on soon
bren wrx is offline   Reply With Quote
Old 05-23-2006, 01:07 PM   #7
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
took about 2 hours... damn stud.
Old 05-23-2006, 06:03 PM   #8
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Spent some more time today driving around. Top-end power is reduced noticeably while low-end power is significantly improved. Car just doesn't pull hard anymore. It's possible that my car was custom tuned to work specifically with Borla header. My tuner (XX-Tuning) said that aftermarket header won't require a retune, but it's worth to recheck it.
Will find out when I get a protune again.
Old 05-23-2006, 06:18 PM   #9
Chuck H
Member#: 20442
Tuning makes a HUGE difference when you go back and forth between a header and the stock manifold. I had an EcuTek tune on my car with the stock turbo and stock manifold setup, but complete aftermarket turbo-back exhaust and uppipe. It made 227 whp on a heartbreaker DynoDynamics dyno and spooled insanely fast. Then I bought an unequal length header, had it ceramic coated (equivalent to Crucial Racing coating) and lost 40 hp and approximately 1000 RPM of spool. Had it re-tuned and managed to get back all but 7 hp, but I still spooled 500 RPM later. And the tuner had to play all sorts of games to spike the boost to even get back that much spool. Even with the ceramic coating the EGT's were just too low, and the header was letting the exhaust cool off too much.
I've since upgraded to a VF34 turbo and better intercooler. I'm almost curious enough to wrap the header and try it again, including running one step colder plugs and having the tuner play games with ignition timing and A/F mixture to try to keep the EGT's higher, but I'm not sure it's worth the $200 for tuning time just for an experiment. The VF34 with ported/ceramic coated stock manifolds spools about the same as the stock turbo did with the header. And I'm not willing to give up another 500 RPM of spool if that's what putting the header back on would do for me, even if it does mean a few more top end hp.
Chuck H is offline   Reply With Quote
Old 05-24-2006, 02:11 AM   #10
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I am thinking about going back to Cobb OTS map to see if it makes any difference. It may be safer to run OTS map until I get a new tune...
Old 06-06-2006, 08:37 PM   #11
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I am getting a Protune again tomorrow. Will post two charts for comparison purposes.
1. With Borla header (262 whp, 272 wqt)
2. Ported and coated stocker ???
All parameters will stay the same (will try my best) including boost level, etc.
Old 06-06-2006, 08:46 PM   #12
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
get dyno'd elsewhere, JM2C.
Old 06-06-2006, 08:49 PM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Why do you think that way I should get a tune elsewhere?
Old 06-07-2006, 07:50 PM   #14
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Very strange things happened today. When I brought my car in for dyno at XX-Tuning today, baseline boost level was recorded to be around 19psi, up from 17.5psi. In April, car was tuned to run at 17.5psi...
Only thing that I did to my car since previous Protune was getting ported exhaust manifold and panel K&N filter. I highly doubt that those two mods would increase boost level up to 1.5psi.
Anyway, baseline dyno number (first chart) pretty much matched previous dyno number (2nd chart) with Borla header (261whp) in terms of HP, but torque was a little bit off. This may be expected as this map was not designed for ported exhaust manifold.
After correcting AF ratio and tweaking various parameters Chris was able to bring whp up to 282whp level at 19psi tapering off to 16psi at redline.
06/07/06 Protune with ported exhaust manifold:
Protune from April with Borla header:
Old 06-07-2006, 07:56 PM   #15
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It's important to note that baseline numbers from first chart is done with ported exhaust manifold and K&N panel filter although map was originally made to run with Borla header.
I don't think we can draw any conclusion based on these two charts as there are several variables:
1. Different tuners (previous tuner could never make >262whp even at 22psi).
2. dirty paper filter vs. K&N panel filter (previous tune was done using filthy air filter).
Old 06-07-2006, 08:05 PM   #16
richde
Member#: 79498
2013 XV
so the end numbers were about the same, what about the spool characteristics, peak torque come sooner?
richde is offline   Reply With Quote
Old 06-07-2006, 08:20 PM   #17
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It is possible that ported exhaust manifold allowed car to improve low-end torque (~40 wtq @ 3250rpm) and horse power. However, it could also be that tune was more efficient in extracting power out of engine.
Old 06-07-2006, 09:09 PM   #18
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
looks like a better tuen with more boost to me
Old 06-08-2006, 12:24 AM   #19
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
definitely must be the port job
look at torque at 3k rpms...thats what a pnp'd mani will do for you along with a good tune
+30-40wtg is crazy
Old 06-08-2006, 12:31 AM   #20
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Oh, I got my exhaust manifold ported by jdgrimm.
Old 06-08-2006, 01:41 AM   #21
totalburnout
Member#: 72861
I've been talking Justin up all over these forums.
There's also a link in the Car parts review thread.
totalburnout is offline   Reply With Quote
Old 08-22-2006, 03:45 PM   #22
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I've received several PM's about my P&P'd exhaust manifold. Here is a bump for those who PM'd me.
fs:uppipe and ported and coated exhaust manifold yut_to_that Engine/Power/Exhaust 4 06-16-2010 09:40 PM
fs: perrin uppipe and ported and coated exhaust mani yut_to_that Engine/Power/Exhaust 5 06-16-2010 07:56 PM
Pnp'd and Coated Exhaust Manifold jdgrimm Private 'For Sale' Classifieds 2 06-15-2006 09:38 AM
Ported and Coated Exhaust manifold from jdgrimm txl146 Car Part Reviews 5 05-19-2006 10:28 AM
WRX Ported and Polished Exhaust Manifolds mrbigisbudgood Private 'For Sale' Classifieds 10 04-28-2006 03:26 PM
