Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 05-24-2006, 03:26 AM   #1
benw
Member#: 103320
2005 wingless
aspen white
Default P0457 CEL Code Resolved: fuel filter was the culprit
I've had the P0457 (loose gas cap) CEL since I've owned the car. I replaced the fuel filter, and haven't seen the code since. All the lines were tight previously, something internally to the filter must have been wrong but it appeared OK.
Just wanted to share this with you. The much described symptoms of bad gas cap, loose lines at charcoal canister, and loose lines near blue fitting under alternator all checked out OK for me.
Ben
benw is offline   Reply With Quote
Old 05-24-2006, 09:29 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Wish mine was caused by that. I get that cel everytime I take an extended trip on the highway. Everything is tight and in order.
Old 05-24-2006, 09:56 AM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....ya got a pinhole leak in something....
those are the biggest PITA
Uncle Scotty is online now   Reply With Quote
Old 05-24-2006, 12:25 PM   #4
benw
Member#: 103320
2005 wingless
aspen white
I was afraid my problem was in the fuel tank or something. I was doing the 60K mile maintenance tune up and it cleared my code.
Hopefully this holds true for some of you other people!
Old 05-24-2006, 02:25 PM   #5
eddie1982
Member#: 114569
2004 JDM
Headache
Post
at least it wasn't in the fuel tank
eddie1982 is offline   Reply With Quote
Old 07-01-2006, 01:55 PM   #6
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
I have P0457 CEL pop up last night...
I checked the blue t fitting behind alt. and nothing were loose.
I went under the car to check all connection on the charcoal canister and everything was fine too.
I always turn the gas cap until it click 3 to 4 times...
Walbro pump was replaced about 6 month ago when I upgraded my turbo and no problem
My question is, do I need to check fuel pump? or something else??
02 WRX with 55K miles...
I used my AP to reset the code... hope it is not coming back on...
BTW, the car idels weird (rattles pretty bad) when cold just couple days ago and exhuats was getting louder than before. Is that something to do with this code??
ImpreziveWRX is offline   Reply With Quote
Going to an inline fuel filter/relocating the filter? verc Service & Maintenance 4 03-10-2009 10:40 PM
2 P0457 CEL codes MRF582 Service & Maintenance 7 12-09-2005 11:35 PM
P0457 CEL code Ken Service & Maintenance 3 12-09-2005 03:54 PM
Best fuel filter for the buck? and where to buy? Down_south Service & Maintenance 4 05-23-2004 12:46 PM
Where is the fuel filter on the new STI? aspera STi Forum Archive 0 01-12-2003 03:11 AM
