Old 03-14-2001, 12:54 AM   #1
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Question Simple ???: What Mod Would Increase Gas Mileage?
I just wanted to know what mod would increase mileage for my 91 Legacy Turbo. I had a problem with the mileage awhile ago but sorta fixed it by putting in higher octane. I'm still not getting what I am suppose to. I'm averaging around 15 mile per gallon and 150 per tank. This really sux. I bough one of Larry's Filter Conversion kits: WIll this help? Also, isn't there something I should do after 140,000 miles to my turbo? Maybe the fuel isn't flowinf right because the Turbo is getting old? I dunno. Any help would be great.
ejicon is offline   Reply With Quote
Old 03-14-2001, 06:24 AM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
Find a local shop that has a MotorVac machine, it's worth the price to clean out your engine.
What they do is connect the machine inline by your fuel filter and mix fuel with a detergent while the car is idling. This cleans the inward fuel lines, fuel rails, injectors, valves, pistons, exhaust valves and might even clean the cat.
I think i paid $130 for it on mine, but i noticed an immediate difference in power once it was done. If you search the web, you can find a lot of good info on it.
An underdrive pulley might perhaps save gas, but probably not much.
DLC is offline   Reply With Quote
Old 03-14-2001, 07:46 AM   #3
subarurabbit
Member#: 4083
2011 OB 3.6R
Post
What about normal stuff?:
allignment,
tune ups,
proper tire pressure.
I have gotten better gas mileage in my wagon with Amsoil airfilter TS-74.
Roger
subarurabbit is offline   Reply With Quote
Old 03-14-2001, 09:02 AM   #4
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Also change your fuel filter, if you haven't. They should be changed about every 15-20k.
Also switching to synthetic lubricants can gain you some mileage.
gavin is offline   Reply With Quote
Old 03-14-2001, 07:11 PM   #5
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Post
Simple! Lighten up on the right foot :-)
Seriously, some suggestions:
- if you raise the gas octane, for a quicker adjustment reset the ECU so it doesn't have to learn. Try going even higher - use 87 octane, but half a bottle of 104+ Octane Boost (yellow bottle, about $3 each, cheaper than running 93 gas but gives about 95 octane).
- underdrive pulley (already mentioned). Too early for definite results on my installation, but prelim seems to show a bit better mileage. Dale Teague showed 2-3 mpg improvement with his.
- synthetic oil and rear diff fluid.
- also, depending on where you live, we're experiencing the last of the winter oxygenated gas, which gives poorer mileage anyway.
rrubel is offline   Reply With Quote
Old 03-14-2001, 08:31 PM   #6
subarurabbit
Member#: 4083
2011 OB 3.6R
Post
regular gas here is about 1.50, super is 1.70. that is a .20 difference. It would take 15 gallons to reach equilibrium with 104 booster.
I'd stick with premium.
Roger
Old 03-15-2001, 12:34 AM   #7
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Unhappy
So do the 87 octane and 104 booster or just stick with 92.. WOuld it matter if I go back to 87.. I dunno.. I'm spending WAY too much money on gas... 150 miles to the tank is tragic... If I'm getting crappy MPG's now, why not just save myself 20 cents a gallon and swich to 87. No? Hmmm!!!
[This message has been edited by ejicon (edited March 15, 2001).]
Old 03-15-2001, 12:45 AM   #8
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Post
nice.. Thanks all..DLC.. I'll look into that Motor Vac Thing. It shouldn't be the air filter or the fuel filter. I just got a smog check and my car past with flying colors. If one of the two or both were bad, I would have failed the test in a minute. I don't know if it's the sparks.. I let my car running this afternoon for a good 20 minutes and it idled regularly. That vac treatment should do the work...
[This message has been edited by ejicon (edited March 14, 2001).]
Old 03-15-2001, 06:16 AM   #9
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
Why would you run such a low octane fuel in your turbo? Premium Unleaded is recommended in the manual and everything else i can find on the turbos. You might not have problems, but why risk it?
I really doubt it's the fuel itself, it sounds like something in the system is mucked up.
Old 03-15-2001, 07:48 AM   #10
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
hey... actually u know what?
when i installed my intake, i got much better gas mileage...
no.. really i did... dont ask me why... that's for a tech head to explain... hehehee
j. www.subiegal.com
Old 03-15-2001, 09:00 AM   #11
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
An intake should gain you some mileage. The engine can get more air more quickly, so it runs more efficiently, and burns less fuel. However, that only holds true if you can resist the urge to keep your foot out of the accelerator .
As for the octane thing, running too low will cause your ecu to retard your timing to prevent detonation. A common misconception is that higher octane is more combustible. It is actually less combustible.
Also, don't use octane boosters unless you really have to. You get a lot of varnishing from the stabilizers.
Old 03-15-2001, 09:36 AM   #12
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
Intakes are nice and all, but remember, he's having these problems on a Turbo, not an NA 2.5.
I really wish there was a Turbo intake worth more than $25 in Home Depot plumbing parts and $3 in gas money (yes, i mean you JC Sports).
Old 03-15-2001, 09:44 AM   #13
subarurabbit
Member#: 4083
2011 OB 3.6R
Post
I am going to put an Amsoil filter on my turbo Legacy. And synthetic fluids too.
Roger
Old 03-15-2001, 03:09 PM   #14
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Post
"regular gas here is about 1.50, super is 1.70. that is a .20 difference. It would take 15 gallons to reach equilibrium with 104 booster."
A bottle will do two tanks or 30 gallons. BTW - this particular brand *claims* to not leave deposits in the engine. It's mostly used by our local dragstrip jockeys.
Old 03-15-2001, 09:26 PM   #15
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Smile
Yeah.. it's true... I shouldn't degrade my gas.. I guess I was feeling a little tipsy when I said that.. I'm gonna check out that motorvac thing, get an oil change and maybe change the sparks. I'm gonna install the intake after that...
Old 03-15-2001, 09:48 PM   #16
Prostho
Member#: 3388
1992 E34
Mauritius Blue
Post
I agree our car drinks gas!! i get 225miles to a tank with some occasional fast driving.. which is a bit on the high side, considering that i use 92octane Shell Gold. But some have found that on highway, using 4th instead of 5th for cruising, they actually get better milage! i don't do much highway driving so i won't know.. 99% of my driving is in city in 4th or 3rd..
Prostho is offline   Reply With Quote
Old 03-16-2001, 06:06 AM   #17
subarurabbit
Member#: 4083
2011 OB 3.6R
Post
Is the car a stick or an auto?
Roger
Old 03-16-2001, 10:56 PM   #18
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Post
Yeah.. you're right....
Old 03-17-2001, 12:33 AM   #19
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Post
Auto.....
Old 03-17-2001, 12:45 AM   #20
subarurabbit
Member#: 4083
2011 OB 3.6R
Post
isn't the rating 18/23?
Roger
Increasing Gas Mileage cmiovino Normally Aspirated Powertrain 38 03-06-2008 12:04 PM
A turbo that increases gas mileage FunkerVogt Off-Topic 14 09-22-2005 12:24 PM
Acetone in fuel increases gas mileage? fuzzycuffs Off-Topic 2 04-05-2005 03:49 PM
What mods will help gas mileage?? mike270 General Community 35 01-29-2002 07:01 PM
WRX: ways to increase gas mileage? brewdude Newbies & FAQs 30 10-17-2001 01:34 PM
