Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-24-2006, 01:44 PM   #1
wrspssshhhh
Member#: 74756
2008 Infiniti G37
Obsidian Black Pearl
Default VF22 with FMIC Map... Please?
I just finished my stage 4 install, and the generic map from TXS seems to work well, but I know I'm running quite rich and sacrificing a little power.
Does anyone have a little better map to use until I can get in for a tune. Local shops are booked until early July. I would like to go have some fun before then...
VF22, pinks, UP, DP, TXS FMIC, Short ram intake, Walbro 255, TXS RFL BOV
all on a rev 6B utec
Thanks so much!!
wrspssshhhh is offline   Reply With Quote
Old 05-24-2006, 02:15 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
IMHO I'd get a bigger set of injectors before getting a dyno tune as you will for sure max out the pinks without a big bump in fuel pressure.
Other than that I think the map from TXS should hold you over for now. I wouldn't run someone elses map since its probably a bit more on edge and not so good for your particular car. If you want you can remove a bit of fuel but I'd be weary of making changes without a wideband and EGT.
cdvma is offline   Reply With Quote
Old 05-24-2006, 02:48 PM   #3
wrspssshhhh
Member#: 74756
2008 Infiniti G37
Really? How big are we talking?
Old 05-24-2006, 04:57 PM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
650 or bigger. You can run with the pinks...but IMHO its just too close to the end of the injectors. I get 60-66% max IDC on my chopped stockers (~ 840cc).
Old 05-24-2006, 09:18 PM   #5
wrspssshhhh
Member#: 74756
2008 Infiniti G37
awesome. then that's what i'll shoot for. hey, out of curiousity were you at the autocross event at shoppingtown mall? i think i may have talked with you for a while. blue 02 with the fmic
Any body with a ej20,pinks,sti tmic,pump,VF22 base map please help forsakenforlife Open Source Reflashes 3 01-19-2010 10:32 AM
need some help with my map please xxlostxx UTEC 9 06-21-2008 04:00 PM
vf22 map needed with sti injectors please moorebl Engine Management & Tuning 4 12-04-2004 11:10 AM
VF22, FMIC, Issues With Spiking/Creep?? Please Help ctwrxwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-19-2004 11:39 AM
UTEC VF22 FMIC map? JaMa Engine Management & Tuning 1 11-17-2002 03:34 PM
