Old 10-11-2001, 01:06 PM   #1
Teamugi
Member#: 7771
Default Ultimate racing up-pipe
Anyone got one of these from them?
Teamugi is offline   Reply With Quote
Old 10-11-2001, 04:27 PM   #2
Mike Kress
Member#: 9291
almost yellow
got one laying in the garage waiting on my mrt turbo back to get here so i can do both at the same time. noticed it came with out studs so hope the old studs come out of the stock pipe ok.
Mike Kress is offline   Reply With Quote
Old 10-11-2001, 04:48 PM   #3
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
Good luck Mike! Having done an up-pipe mod myself (Vishnu) It looks like getting the old studs out could prove to be a hassle. I'd save yourself some time by trying to get some new studs with the right material spec for the job.
Scoob.
Scoob is offline   Reply With Quote
Old 10-11-2001, 04:52 PM   #4
shiv
Member#: 607
Scoob-- You didn't get studs with my up-pipe? Did you buy from me?
shiv
vishnu perf. systems
shiv is offline   Reply With Quote
Old 10-11-2001, 04:56 PM   #5
Imprezd
Member#: 3357
I think you mis read Shiv.
Imprezd is offline   Reply With Quote
Old 10-11-2001, 04:56 PM   #6
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
Sorry Shiv.. I should be a bit clearer... I got studs with my up-pipe, thanks! It's just I got to see up close my original up-pipe, and wouldn't like to try to get those studs out to put it a new one!
BTW... My up-pipe is TOP NOTCH!
I got it from lbk16. He was gonna fit it, but his turbo housing studs were ruined by his dealership, and couldn't fit it (He couldn't even get his exhaust off!). I took it off his hands there and then. I have this reputation, where if somebody shows me something, I have to have it!
Scoob.
Old 10-11-2001, 05:05 PM   #7
Mike Kress
Member#: 9291
almost yellow
Thanks!! Think I'll e-mail Johnson at ultimate and ask him about the studs. Seems like a nice guy. Probley have to wait a week or two for the mrt to get here anyway. This is the up-pipe that Jorge at projectwrx used. Thanks again.
Old 10-11-2001, 05:40 PM   #8
shiv
Member#: 607
Ah.. no problem. I need to work on those reading skills !
shiv
Old 10-12-2001, 02:24 AM   #9
Teamugi
Member#: 7771
cool Mike, keep my posted as to how it goes and what you think. Thinking about a Up-pipe, I like Shivs but I don't have the money yet and Ultimates is slightly cheaper.
Old 10-12-2001, 04:36 AM   #10
Verist
Member#: 6501
Look at Shiv, wanting to know if it was his kit that did not come with them, he was just itching to remedy the problem and make it right. That is cutomer service folks, that is why I'll be getting mine from him in the near future.
Regan-
Verist is offline   Reply With Quote
Old 10-12-2001, 11:12 AM   #11
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
Yup, it's good to have guys out there that are genuinely concerned about customer satisfaction.
Scoob.
Old 10-12-2001, 12:42 PM   #12
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
I have a UR up-pipe, and for the record the old studs came out easy enough.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 10-12-2001, 01:13 PM   #13
DanMan
Member#: 5009
I have one half way in.
http://www.i-club.com/forums/showthr...0&goto=newpost
And getting the studs out of the stocker really wasn't all that hard, just used an extra nut as a lock and crancked it off. WD-40 is a godsend.
Otherwise its a very nice unit.
Dan
DanMan is offline   Reply With Quote
Old 10-12-2001, 02:12 PM   #14
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
Sounds like it may be easy then!
Scoob.
Old 10-12-2001, 07:17 PM   #15
DJWRX
Member#: 10340
Scoob.
Easy to get the studs out. Not an easy install. I wrestled with mine for about 7 hrs the other day. And it still has a small exhaust leak. I'm having fitment problems at the U.P./manifold juncture. Danman, and anyone else that is doing this install, post about your over all fitment. I'd like to know.
-tim
DJWRX is offline   Reply With Quote
Old 10-12-2001, 07:39 PM   #16
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
The key to fitment and leaks is to tighten everything from the bottom and work your way up and back... also USE NEW GASKETS!!!!!!
Once those things are crushed you have a 50/50 chance of not leaking... you either do, or don't...
I leaked at that exact same spot until I replaced the gasket... then no problems.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-14-2001, 12:48 PM   #17
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
I agree it's a PITA of a job to do. We took 5 hours to put my Vishnu pipe on. No leaks though, and fit was exceptional. We had to loosen the engine mounts and lift the motor slightly to get the OEM pipe out. It worked out quite well, coz we didn't take the turbo off.
My only problem was not getting the EGT probe tight enough. I posted the solution in the Uppipe install underway thread by DanMan...
Old 10-15-2001, 07:19 AM   #18
Mike Kress
Member#: 9291
almost yellow
Johnson at Ultimate e-mailed me back last night and said the old studs should come out of the stock pipe ok. If I had any trouble or ques. be sure and call or e-mail him. I'll be doing mine soon as my mrt sys gets here.
ultimate racing up pipe? n e good? Go_Rex_Go Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-21-2006 04:43 AM
Ultimate Racing Up Pipe and APS 3.5 Exhaust? WRXSTi0487 Newbies & FAQs 2 05-16-2006 08:54 PM
FS: Ultimate Racing up/pipe, downpipe, catback, FMIC, and T04E turbo (Rotated mount) Need4Boost Private 'For Sale' Classifieds 3 04-19-2006 10:16 AM
Just installed the Injen CAI, Ultimate racing up-pipe install w/ dyno time to follow All8up Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-07-2002 09:45 AM
Ultimate Racing Up pipe install AGAIN, problems AGAIN DJWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-26-2001 11:13 AM
