Old 10-11-2001, 12:21 PM   #1
MINDGAME
Member#: 7500
2002 2.5 TS Wagon
No, it's not a WRX...
Default Engine Internals
Do you think it would by wise to upgrade the internals of my 2.5 before bolting on a turbo?
Pistons seem to be the most popular victim of turbos (well maybe tranny actually), so getting higher quality pistons as well as lowering the compression seems like a start. What else can be/should be done to make a NA engine accomodate a turbo like the ej22t or ej20t? Crank? Rods? Cam?
(FYI- I will be purchasing my turbo from Shiv if he decides to continue with the packages after his first run.)
Thanks.
MINDGAME is offline   Reply With Quote
Old 10-11-2001, 01:05 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the pistons normally hold up until you run lean to the point you get detonation and cast pistons don't take kindly to detonation. I would go witha set of forged pistons but be prepared for them to be a little on the noisy side when they are cold. The rods should hold if you are planning then pushing no more then 9 PSI daily driven.
Jeremy
Old 10-11-2001, 09:11 PM   #3
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Lightbulb
what do you want to do? If you want a bullet proof high horsepower bottom end, forged pistons are a must! connecting rods are a good insurance. you went that far, get the crank knife edged and everything balanced! call cobb tuning they will help! Don't call B-spec!
jeff22 is offline   Reply With Quote
Old 10-11-2001, 09:34 PM   #4
kaos200
Member#: 2692
MINDGAME...HndaTch627 is right, forged pistons are not the quitest of pistons!
However, I suggest them as a safety measure, headwork always is NICE! Springs definitely.
But most importantly, is the Fuel system, and engine management that support the entire system. THOSE my friend are the key. They have been discussed enough in this forum that I believe I can say a search will suffice.
You can also get rods, or you can buy 2.5 rods to shotpeen and use ARP bolts on. BTW I have a set for sale so you can do it to those while you drive your car
kaos200 is offline   Reply With Quote
Old 10-12-2001, 12:03 PM   #5
MINDGAME
Member#: 7500
2002 2.5 TS Wagon
Sorry to sound ignorant, but what kind of noise do forged pistons make? Do they just make the ambient noise of the engine louder, or is there some sort of specific noise associated with them?
The noise that a set of stiff-ass coilovers makes bothers me, but the noise from a loud aftermarket exhaust is music to my ears...
Old 10-12-2001, 01:01 PM   #6
efoo
Member#: 80
ever hear an old Volkswagon beetle with a diesel engine?
that's very much like forged pistons.
clank-clank-clank-clank-clank-clankity-clankity-clankity-clank-clank-clank-clank-clank-clank..
all day long too. I've been around Imprezas with forged pistons in EJ25s. The noise didn't really subside even after a good hour of driving. I don't think the pistons were the wrong size or anything either - just loose by nature.
I sure wouldn't want forged pistons in my daily driver. It doesn't sound nice at all -- not like a deep exhaust.
efoo is offline   Reply With Quote
Old 10-12-2001, 01:11 PM   #7
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
I have heard EJ25 motors with forged pistons too, most of the time with Efoo present They sound, just like Efoo said, like diesel motors. Proper tuning is all you need. I really don't want to open my engine, and am dreading the time when I'll have too.
Cheers,
MattC
MattC is offline   Reply With Quote
Old 10-12-2001, 05:51 PM   #8
MINDGAME
Member#: 7500
2002 2.5 TS Wagon
So if I really want to do a turbo engine right, should i just buy a ej22 short block and build up from there? I mean that engine is made to turbo right...so I should be able to run a higher boost with this foundation. Obviously this route will be a lot more expensive than just modifying my 2.5, but I want considering this car to be a project car.
Old 10-12-2001, 06:12 PM   #9
kaos200
Member#: 2692
the EJ22T is the one that came turbo'd. There are differences between the two. However, If you are going to run more than 10psi, from a nicely sized turbo. ATLEAST install pistons in that motor, if not pistons and hardened/upgraded rods.
Old 10-13-2001, 02:41 PM   #10
5252
Guest
Member#:
Got my bill for my Pauter rods and my JE forged pistons and total seal rings. Ouch mommie. I would have to say no, don't get internals.
Old 10-13-2001, 03:13 PM   #11
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
I have 92.5 mm BPM forged pistons and they don`t sound like you say, they are just like the OEM ones about it`s sound... soemtimes a little clank for 1 minutes when during cold starts
DJIMPREZA is offline   Reply With Quote
Old 10-14-2001, 04:38 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
I disagree with the noise they supposedly make, but they do knock at cold start.
jeremy
Old 10-14-2001, 12:40 PM   #13
kaos200
Member#: 2692
jeremy
well, all I know is... They DO make noise... atleast all the J&E and Weisco etc that Ive heard/ heard of.
Old 10-15-2001, 01:04 AM   #14
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
I don't see why properly sized and fitted pistons would make any more noise then stock, maybe someone could tell me why, but this is something I've never heard of, and yes I've put pistons in a 351W before. If you want to build 300WHP + eng then build the block. I'm in the camp of why do it until you need to my self.
milkman is offline   Reply With Quote
Old 10-15-2001, 04:17 AM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
kaos i wasn't disagreeing with you it was the guy making it sound like a rod is tapping the block, yes JE's are rather noisy but well designed pistons. Any quality material piston will be louder.
Jeremy
Old 10-15-2001, 08:55 AM   #16
outback motorsports
Member#: 4084
Default rods and pistons
we have our own h-beam rods, arp 2000 bolts, lighter than pauters for $500 i-club price. we also stock 6 diff.2.5 piston configs for turbo usage.we stock bearings too see ya steve 714 994 5222
outback motorsports is offline   Reply With Quote
Is it worth upgrading engine internals? wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-20-2001 02:50 PM
Who's good with engine internals? WRXwannbe Bay Area Impreza Club Forum -- BAIC 0 10-23-2001 03:28 AM
Engine internals bigbuyer2477 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 05-24-2001 06:55 PM
engine internals for legacys !? sub soob Legacy Forum 5 04-04-2001 12:35 AM
Automotive engineering international - info on new flat 6 Steve00RS General Forum Archive 0 10-17-2000 07:35 AM
