Old 10-11-2001, 12:23 PM   #1
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Rubber Intake Connectors
Does anyone here know where I can get those rubber connectors that connect the intake to the turbo/throttle body/air filter/etc? My rubber connector split at the track the other week and I got tons of duct tape on it keeping it together.
I tried to go to Home Depot or other hardware stores to adapt their rubber cupplings to the intake but they are either too big or too small. They have 3", 2" and smaller sizes. Nothing in between. I need something in the range of 2.75-2.5" in size. Can anyone tell me what other type of stores I may be able to get these rubber cuppling type connectors at?
Look at this picture. The piece I need is the piece that connects the intake to the throttle body. Thanks!
Kevin Thomas is offline   Reply With Quote
Old 10-11-2001, 12:29 PM   #2
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Use silicon connectors. There's a place in Spokane that sells them, the number is on my website... which is down until Friday.
You could also call turbonetics, they have them and will have them to you by next week. www.turboneticsinc.com That's where I bought all of mine at.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-11-2001, 12:31 PM   #3
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Kevin - the TB is 2.75" I bet your intake is 2.5. You can get a 2.75-2.5 reducer coupling from Turbonetics http://www.turbocharged.com
If the intake is 2.75 also, then you can just get a straight piece of 2.75 silicone boost hose from Turbonetics or http://www.bakerprecision.com
The wait time will be a while, though, because Subaru is just about the only manufacturer who is using 2.75 in anything.
blaster88 is offline   Reply With Quote
Old 10-11-2001, 03:04 PM   #4
subachad
Member#: 8488
Teal
2.75??? Maybe that's why my 3" to 2" reducer is so loose.
Now with the SAAB intercooler though, I really need a 2.25" to 2.75."
Chad
93 1.8T
Old 10-11-2001, 04:03 PM   #5
GGrahnVI
Member#: 7190
GGrahnVI is offline   Reply With Quote
Old 10-11-2001, 05:32 PM   #6
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Abnormally Aspirated
Or here (Innovative Turbo)
the Dabbler is offline   Reply With Quote
Old 10-12-2001, 10:11 AM   #7
Kevin Thomas
Member#: 110
1989 1989 XT6
Default Awe No
Blaster you are right my man. I was measuring the pieces this morning and the Maf sensor as well as the throttle body are both 2.75". I can fit a 3" piece on the throttle body but it seems difficult to do on the Maf sensor. So what I would need is (2) 3"-2.75" reducer couplings: one for the throttle body to intake and one for the intake to maf sensor. I will call Turbonetics and the other shops to see if I can get these pieces. They aren't cheap either. Thanks for the input guys.
2.75"???? But why?
Old 10-12-2001, 11:26 PM   #8
subachad
Member#: 8488
Teal
A quote from my site,
<<For those wishing to save a few $$, you can get the silicone fittings in
many colors direct from the manufacturer in Spokane WA. The company is BelAir Composites:
Belair Composites
3715 Longfellow
SPOKANE WA 99217
(509) 482-0442
There's a good chance this is the company that supplies Turbonetics. I know
they supply Greddy, Majestic Turbo, HKS and many others. Cool guys to work
with, prices a lot better than retail.
Joel >>
Chad
93 1.8T
http://208.129.213.117/subachad/turbo_build_up.htm
Old 10-22-2001, 09:23 PM   #9
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
Yeah, go with belair for silicon, if you want rubber (a ton cheaper and easier to work with) try mcmaster.com there is a lot of navigating the site to do, but less than half the price of silicon, and just as good in my opinion, but not as pretty in color.
paulnose is offline   Reply With Quote
Old 10-23-2001, 01:35 AM   #10
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
I like this quote from the RoadRace Engineering page:
Tuning Tip: Red is a good color for all around performance, however with a big turbo blue gets upwards of 10 hp, unless you have stock cams, then only 5 hp. Purple is best for bottom end power, mix with red for excellent mid-range. For NT cars, shift all recommendations one hue towards a warmer color. Yellow hose should only be used on high compression NTs or turbo cars with welded differentials. Proper Sticker Tuning can be a successful work around for any of these concerns. ;-P
It's also interesting to note that their black hose is more expensive than the colored hose. Maybe that's cuz they sell more colored hose than black.
iodine23 is offline   Reply With Quote
Old 10-23-2001, 01:46 AM   #11
XT6Wagon
Member#: 524
04 STi
Kevin I have a stock XT6 MAF to TB hose if you want it. $10+shipping. I got it with my motor and my setup can't use it. I'll check to make sure it has no splits or other damage if you are interested.
XT6Wagon is offline   Reply With Quote
I NEED Rubber Intake Tube from Turbo to intake doccgsra Private 'Wanted' Classifieds 2 05-17-2009 02:00 PM
TurboXS Manual Boost Controller, GFB Stealth FX BOV, Intake w/ MAF Connector compressro Engine/Power/Exhaust 10 04-18-2009 10:02 AM
this peice. rubber hose/breather line connector next to turbo w/ pic! IIdiceII Private 'Wanted' Classifieds 5 02-18-2008 12:21 AM
WTB: stock, rubber intake hose from WRX / Sti Tobey Private 'Wanted' Classifieds 6 11-17-2004 09:33 AM
