Old 05-24-2006, 06:27 PM   #1
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Default Element Hydramist water injection 583 whp UPDATE Runs 10s!
Itís been a long time since Iíve been able to dyno my own car and more importantly publish results from the Element Hydramist water injection system weíve been testing over the last year. What you are looking at is 583 whp using Cam 2 108 octane race gas and the Element Hydramist water injection system. With this system I was able to tune the car like it was running on VP C16 but instead of paying $12/gallon this gas is about $4.60/gallon. The lower 535 HP number is on 93 octane pump gas and water injection which is really impressive.
We changed up a few things on our engine which helped to boost power. First off letís get the specs out of the way:
Engine: Element built 2.5 liter STI OEM Long block
Pistons: CP .020 overbore
Rings: CP
Rods: Pauter
Cams: Axis Racing Kelford AVCS, 272, 10.3 mm lift
Heads: OEM (no porting)
Valve: OEM
Springs: OEM
Bearings: OEM
Gaskets: OEM
Crankcase Vent: Element Competition Catch Can
Engine Management: Element Hydra EMS
Water Injection: Element Hydramist
Turbocharger: Element GT75 Turbo Kit (75 lbs compressor/ .82 turbine housing)
Wastegate: TurboSmart Ultragate
Exhaust: Element 3Ē stainless
Boost Controller: TurboSmart E-Boost 2
Header: Element 4-2-1 stainless
Radiator: Koyo
Thermostat: Crucial Racing
Intake: Element 4Ē
Intercooler: Hyperflow FMIC core
Blow Off Valve: TurboSmart Megasonic
Fuel System: Element 2 liter Competition Surge Tank
Fuel Pump Primary: Aeromotive A1000
Fuel Pump Secondary: Walboro 255
Regulator: Aeromotive
Fuel Lines: -10, -8, -6 AN
Rails: BDL Top Feed WRX
Injectors: 1000cc RC Low Impendence
Transmission: Andrewtech PPG 5 speed Straight Cut Dog Box
Differential: Quaife Front
Clutch: Clutch Masterís Stage 4, lightweight flywheel
All I can say is the Hydramist water injection system is the catís meow! Iím really happy with the pump gas numbers of 535 whp given Iím running summer grade windshield washer fluid which is only about 15-20% methanol. Iíve been using the ďblueĒ stuff for over a year and at $1.68/gallon I wonít be changing anytime soon. Inspection of water nozzles and tank have proven no ill effects and tear down of motor show just how clean the pistons are when using water injection. Not all injection systems are created alike and to safely feed this level of power with water requires a well though out system.
The Cam 2 108 octane power with water injection also worked out well at 583 whp. Running VP C16 at road racing events can get seriously expensive. At one Time Attack we can burn up to 30 gallons of race fuel. At $12/gallon thatís $360 in gas alone but we learned that we can use lower grade race fuel with the Hydramist system but still run the same fuel and spark mapping. At last yearís Time Attack we only spent about $135 on fuel by comparison.
I really would have liked to see more out of the turbocharger but I think we are dealing with one of two limitations or possibly both. I think the .82 exhaust housing is just not going to cut it with at 75 lbs turbocharger and itís highly likely when I switch back to the GT65 setup not only will I have superior spoolup but also the same HP. Going larger will result in a laggy pig so itís likely I wonít even bother. The other limitation may be in the lack of head porting or the stock valves. Before I change those items Iím going to change the wastegate spring so I can go for 40 psi. Iím also going to run VP C16 and give it a 70 shot of N20.
For now Iím happy since canít even drive the car straight anymore.
UPDATE:
60ft 1.818
330ft 4.745
1/8 7.010
MPH 106.40
1000 9.043
1/4 10.762
MPH 133.74
Thanks,
Phil
Element Tuning
(240)246.0302
http://www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 05-24-2006, 06:30 PM   #2
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
so your hitting full boost by 6500rpms?
awesome build up man, but it seems like this would destroy all on a road course but as a daily driver would be lacking...
BREWPUBEAVER is offline   Reply With Quote
Old 05-24-2006, 06:44 PM   #3
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Car sounds like a blast. I was thinking of doing 91 + the hydramist, but you have me tempted to just run 104 + hydramist all day long on my car now Keep up the good work Phil!
-Dan
suby_dude is offline   Reply With Quote
Old 05-24-2006, 06:46 PM   #4
RainMaker
Member#: 93301
06 CGM STI SM#17
Now with alot less verve!
are there any issues with the spark timing that you can use prior to the Hydramist boost trigger point?
I understand that cam2 is cheaper, but one might leave some on the table if you could spool the turbo faster and with more power under the 5-10 psi you start spraying....
RainMaker is offline   Reply With Quote
Old 05-24-2006, 06:49 PM   #5
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Very impressive. Any updated pictures under the hood of your car? I also was not aware that one could run 272's on stock valves and springs.
I cant wait to purchase a Hydramist setup of my own!!!
-Matt
ShaggyGT is offline   Reply With Quote
Old 05-24-2006, 06:58 PM   #6
RainMaker
Member#: 93301
06 CGM STI SM#17
whaaaa????
Old 05-24-2006, 07:04 PM   #7
ShaggyGT
Member#: 19221
Thats what it says:
Valve: OEM
Springs: OEM
I wasnt aware that was possible. I knew it was doable with 264's but not 272's.
-Matt
Old 05-24-2006, 07:22 PM   #8
keaniegenie
Member#: 94494
2005 Element 92x
That's how all these big setups look like at first. Look closely, he's a 300lb by 4500RPM. That's not bad for a 75lb turbo.
keaniegenie is offline   Reply With Quote
Old 05-24-2006, 07:38 PM   #9
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Holy S*** Phil....
whats the whiplash like on the stree LOL, that turbo must kick like a mule.
Wish I would have just went the Hydra route in my STI, but...Hindsight is well, you know the story.
jetfan8178 is offline   Reply With Quote
Old 05-24-2006, 08:04 PM   #10
Physics Junkie
Member#: 65609
Color me impressed. No chance of you bringing these out to cali on the 31st is there?
P.S. Check your email.
Physics Junkie is offline   Reply With Quote
Old 05-24-2006, 08:22 PM   #11
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
granted, but i really like having 450whp @ 4000 rpms
Old 05-24-2006, 08:39 PM   #12
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
I don't really think so at all, cause look at how much power hes puttin down at 3500rpms... 150Ft LBs of torque!!! thats how much my car peaks out at 4600rpms lol it makes me sad.
Lets just say if i were ever to get an STi and fix it up, element tuning would be the company i'd go with! Great Job man, that hydramist looks like a worthy peice.
Caplin 2.5 is offline   Reply With Quote
Old 05-24-2006, 09:08 PM   #13
700hp
Member#: 104164
'95 Impreza 800+hp
9.1 152mph
700hp is offline   Reply With Quote
Old 05-24-2006, 09:15 PM   #14
2004stiwrb
Member#: 70613
i'm @ the dragstrip
with over 600awhp!!!!!!!!
great job phil, looks like a very nice setup.
2004stiwrb is offline   Reply With Quote
Old 05-24-2006, 09:59 PM   #15
desert pirate
Member#: 70033
use thesearchbutton
orotherswillcry
What rods are you using, pretty please?
desert pirate is offline   Reply With Quote
Old 05-24-2006, 10:12 PM   #16
Element Tuning
Member#: 54918
673 WHP Element
It's a big turbocharger with big lag, no doubt about it. On the road I see 20 psi by 4800 rpm which honestly isn't bad given the size of the turbocharger. Once online the power doesn't stop all the way to 8K rpm. To make the lag truly worthwhile I would like to see more HP.
The plot is deceiving however. A stock STI which feels like a really responsive car puts out about 230 whp at 5500 rpm on this dyno. This setup is already making 230 whp by about 4400 rpm. Just food for thought.
Thanks,
Phil
Old 05-24-2006, 10:14 PM   #17
traction issuez
Member#: 86559
2005 RS Wagon
as always beautiful work i wish i was all done so i can start tinkering..
great job phil as always. you have any pictures of the hydramist?
-Mike
traction issuez is offline   Reply With Quote
Old 05-24-2006, 10:17 PM   #18
Element Tuning
Member#: 54918
673 WHP Element
Pauter rods.
Old 05-24-2006, 10:28 PM   #19
Element Tuning
Member#: 54918
673 WHP Element
With a turbocharger this efficient you can run gobs of timing even on pump gas. I'm sure I could pick up a few ponies under 10 psi but the bottom line is that I wouldn't be caught dead under 4k anyway especially when I'm on race gas which means I'm racing
Thanks,
Phil
Old 05-25-2006, 12:43 AM   #20
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
So your reving to 7800rpm on a stock head basically right? How would you feel about a completely stock sti ej257 reving to 7500rpm? Am i playing with fire?
Swine is offline   Reply With Quote
Old 05-25-2006, 01:09 AM   #21
InfamousDX
Member#: 25413
Phil... you are the truth. Is there any official word on this Hydramist setup? I still may go for it....
Old 05-25-2006, 03:13 AM   #22
9vapors
Member#: 92582
-Matt
That also was the first thing to jump out at me, maybe it's a typo? Anyway, great numbers, and when can we buy one???
9vapors is offline   Reply With Quote
Old 05-25-2006, 09:05 AM   #23
ShaggyGT
Member#: 19221
-Matt
Phil,
Can you confirm that you are indeed running 272 cams with stock valves, springs, ect..
-Matt
Old 05-25-2006, 09:58 AM   #24
04blue-meanie
Member#: 65239
2004 ver7 swapped
sr55 inside....
Very impressive, i would also like to have confirmed that it was 272's on an otherwise stock valvetrain. I would really like to see a gt65 curve with the hydromist as well.
04blue-meanie is offline   Reply With Quote
Old 05-25-2006, 11:47 AM   #25
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
i rode in that car the other day, and its as phil put it, "its Balls to the walls FAST".
ImprezaRSfan! is offline   Reply With Quote
FS: Hydramist Water Meth Injection *Price Lowered* sean18337 Engine/Power/Exhaust 24 02-14-2011 02:21 PM
Element Tuning Pro Comp Engine, Hydra EMS, Hydramist, GT75 Kit, 709 WHP, Q16/Methonal Element Tuning Proven Power Bragging 47 05-10-2010 11:17 AM
Element Hydramist Water/Methanol for sale PLATNiUMSTi Engine/Power/Exhaust 1 08-22-2009 04:44 PM
For Sale: Hydramist water injection, new jets.. cheap $400 syoung0298 Engine/Power/Exhaust 15 07-06-2009 10:46 AM
hydramist water/meth injection *feeler* fractur3 Engine/Power/Exhaust 16 09-28-2008 09:47 PM
